Truck still Buzzes - Diesel Forum - TheDieselStop.com
Old 11-29-2007, 06:49 PM   #1 (permalink)
Truck still Buzzes
Took in my 2005 F250 for it's 35000 mile checkup and asked about getting the latest inductive flash. They said if there is no obvious problems, they will leave it with the current "why is your truck making that buzzing noise after you shut it off" flash. Is there any reason to pay to go to the inductive flash or should I leave it as is? Does going to the inductive flash give me any advantages?
dalem is offline
Old 11-29-2007, 07:14 PM   #2 (permalink)
Re: Truck still Buzzes
My dealer told me the same thing. They wouldn't upgrade me either to the newest flash unless I have issues. Still Buzzing.........
2005 F-350 FX4 XLT 4x4 CC/LB Torqshift with Diamond Back ATV Truck Cover, Zoodad Mod
Banks Power PDA with Monster Exhaust and Accufab intake elbow from Innovative Diesel
35x12.5x18 Toyo MT with 2.5" leveling kit, 2005 Weekend Warrior FB2200 for the toys
tzurick is offline
Old 11-29-2007, 07:47 PM   #3 (permalink)
weasel79's Avatar
Go in and complain about hard starting, rough running, no power in the morning. I have heard guys saying this and it works. Im just going to pay the $70 bucks and have it done.
2003 F-250SD XLT X-Cab short box March 03 6.0L Torque shift, manual 4x4 superwinch hubs, 121,000 miles,315/75/16 BF Goodrich mud terrains, autometer boost/fuel psi/tranny temp, AFE 4" straight pipe, tire clearance and guage photos
weasel79 is offline
Old 11-30-2007, 12:44 PM   #4 (permalink)
Basically they can not upsell warranty repairs. A recallibration is usually billed as one hour shop rate, or as part of the diagnostic proceedure for a running concern.
Now, if your truck has a concern, and its over the 3/36, there is a $100 deductible on the 5/100 portion. So, if shop rate is at or under $100, it'll cost you for the recall anyway.
OMC
OMCUSNR is offline
Old 11-30-2007, 01:34 PM   #5 (permalink)
OT
OT's Avatar
Curious..
Q..Did you have a cold start or other running issue that was corrected with (f.i.buzz) reflash? I'm assuming you did & it corrected you issue. So, why reflash..
If it's just the noise you don't like (no running/start issue) then as mentioned, I also think it'll cost you to reflash. So any advantage is no noise after KO, right? Just a guess.
FWIW..Last I read, ITEC still using f.i. buzz after shutdown & not the 2nd updated heating f.i. I never had a real cold start (not counting early on romp's) problem, but got 1st one along with a reflash for other problem's. Still, can't help but wonder what does heating coil's do to life of f.i.? Even the buzzing. Did mfg. know their f.i. were going to get really twiked (so to speak) later on? I'm thinking no. Maybe make's no diff. but time will tell.
btw..like c.rich sang..who know's what goes on behind closed doors? [img]/forums/images/%%GRAEMLIN_URL%%/crazy.gif[/img]
03 F250 XLT SC/SB 4X4 6L (stock) A/T. SRW 3.73's BD:02/11/03. 01 TL 23' SGII
OT is offline
