turbo back PSI sensor - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 12-08-2005, 05:05 PM Thread Starter
what impact does the backpressure sensor have on the engine or exhaust system? I have deleted my muffler and cat on a 05 f350 and was wandering if i may have to do this? would it change the way that the exhaust sounds? how much power i am making? things of that nature.
"Now if his backpressure sensor is not capable off or responding wrong to the drop in backpressure he could be experiancing power loss..Did you reset the computer by disconecting the batteries"
MoBe88 is offline
post #2 of 3 (permalink) Old 12-08-2005, 05:15 PM
FamilyRide's Avatar
Re: turbo back PSI sensor
Well, it's a Exhaust Back Pressure Sensor. (EBP) So you do the math. [img]/ubbthreads/images/graemlins/laugh.gif[/img]
If resetting the ECM helps, then driving will too, as it adapts.
2004 EB Excursion, 4x4, 6.0, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto, V code front springs, bubba lights and newly added so called bullet proofing, including PMax turbo.
FamilyRide is offline
post #3 of 3 (permalink) Old 12-08-2005, 09:04 PM Thread Starter
come on fellas i know there has to be more info than this. help me out
MoBe88 is offline
