Turbo Boost Fluctuation - Diesel Forum - TheDieselStop.com
Old 05-20-2005, 06:16 PM   #1 (permalink)
When my truck is cold, my boost gauge jumps from 10 lbs to 12 lbs back and forth while holding the accelerator steady. I can hear the turbo surging at this time. It takes about two miles before smoothing out. Anyone know what may cause this? It is only when cold.
2008 F350 CrewCab Longbed, Black on Black, 12 inch Modified Rize Lift, King Coilovers in Front, King Reservoirs Front and Back, 40 inch Nittos, Amp Steps, 4.88 Gears
Doctorsmack03 is offline
Old 05-20-2005, 08:57 PM   #2 (permalink)
dbennett48's Avatar
Re: Turbo Boost Fluctuation
I would guess it is your oil. What oil are you using?? You may want to try a synthetic oil to see how it runs when it is cold. I had the romps when cold and I changed to a syn oil and that cured it.
Dave
2004 F-350. Standard Cab, 4X4, 6.0 with Torqshift, 3.73 w/LS. <font color="red">(((XM))) Satellite Radio.</font> Lo Jack, 6608 lbs wet. Born on 8/4/2003. Engine 07/23/2003. 3" Lift. Grover Air Horns!!!
http://community.webshots.com/album/85108545NlXNsD
1993 F-350 4X4 7.3 IDI with 5 spd. Gone now.
1976 Kenworth C-500 with Detroit Diesel 8V92TA with 3 spd Jake, SQHD's and RTO 12513 10 Wheel Dump Truck. Sold.
dbennett48 is offline
Old 05-21-2005, 09:44 AM   #3 (permalink)
Mine does it when it is warm also, I hear it is the exhaust back pressure sensor. My egr plug is "broken" but it did not help any. I have yet to replace the ebp sensor, because I hear there is a updated one and I dont know the part number.
2003 F-250 FX4, 4x4, 6.0, T/S trans, AFE stage I w/pro guard 7, MBRP duals, lost kitty, Di-pricol, Sirius Satellite Radio, original flash, 33,xxx miles trouble free and counting.
dbaumle is offline
