Turbo Cleaning ! - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 08-16-2009, 08:00 PM Thread Starter
Send a message via AIM to blizzardwarrior7
Turbo Cleaning !
Going to be taking my turbo out tommorow, to do some major cleaning...Just wanted to know if anyone had any hints on how to make removal less painful, or any hints on the cleaning aspect of it...
2006 F250 cc/sb sct, studs egr delete, 100 shot injectors, fass fuel pump, twins, rough country 4-link 8" Lift, 38"x15.5" Dick Cepeks, 20x12 Rockstars, 4" Dual Exhaust, Ranch hand bumpers Front & Rear
2002 F350 XL RC/LB Pro Comp 6.5" Lift, 37"x13.5" SuperSwamper M16s, Stage II's, GTP38 turbo, DP Tuner, AFE intake, 5" exhaust, JW Slush Box, AIH Delete, CCV Mod, Zoodad mod, 5.6k mod, FPR Shim, ATS Flex Plate, ATS Torque Converter, AirDog FP-150, Fluidampr.
2006 Ram 2500 QC/SB Smarty, 5" straight pipe, edge, Leveling kit, 35x13.5" mickey ATZs
2006 International CXT DT466 300 hp 860 tq Diablo powerpuck, 6" straight pipe into 7" single stack
blizzardwarrior7 is offline
post #2 of 9 (permalink) Old 08-16-2009, 08:50 PM
InetDev's Avatar
You will need some nickel anti-seize, most stores do not stock it. It's good to 2400-degrees.
The directions say to cut down 2" 3M pads to 1". Harbor Freight has a 1" size kit. Get that.
There are a lot of helpful how-to's on the subject. I just followed those when I did mine. Also, remember the order for the VGT vanes when you take them out. They should go back in the same place.
Good time to upgrade the two oil tubes (one under the turbo, one above), and the HPOP fitting.
2005 F350 turbo diesel Lariat 4x4 ext cab, short bed, SCT x2, MBRP turbo back, WeatherGuard box, the "beagle hauler".
1965 Factory Five Spyder GT, the 2nd one built out of 39 total. No top, no windows, no radio, no mufflers. Yeah, it's sweet.
InetDev is offline
post #3 of 9 (permalink) Old 08-17-2009, 08:49 PM Thread Starter
Okay well got it all out and cleaned, and installed again....Bad news....NO BOOST at all......Seems like the turbo instnt spooling at all.........Does anyone know which position the actuator cam is supposed to be in when you reinstall the turbo? I kind of think its not in the right position....Thanks
post #4 of 9 (permalink) Old 08-17-2009, 09:31 PM
Look here, Diesel Technician Society ,this came from here with more 6.0 info , Diesel Technician Society - Articles ,if you have issue's in the future with head gasket's go here,click on the link at the top of the video to see all 6,if you click on the video it self you will ONLY see the 1'st one, it start's out with a side by side of the 6.0/7.3, YouTube - 6.0 vs 7.3 POWERSTROKE FORD DIESEL 1 OF 6
2002 F350 4 door Dually XLT lariat PSD Crew Cab 4R100 4.10 VDH4 Prepump, In-Tank, Crossover,Tymar air intake, Edge Evolution, Magellan 6000T GPS, White Night backup light's, DPPI Guages, Walker "Big Truck" Muffler, b&w turn over hitch, pulling a 2004 Sunnybrook 31bwks triple slide 5th wheel. , Total Gross 20900#.truck wt empty 7420# all at the scale, born 05/02/02. bought 06/18/02 & the wife's 2007 eddie bower expedtion 5.4,6 speed automatic ,power everything,redfire & tan.
poppie is offline
post #5 of 9 (permalink) Old 08-17-2009, 11:31 PM
Did you verify that the shaft would turn after you clamped the turbine housing back on? The housing to turbine blades has a tight clearance so alignment is critical.
misterc is offline
post #6 of 9 (permalink) Old 08-18-2009, 11:07 AM Thread Starter
Yea everything is turning fine, everything turns easier than it was prior to cleaning it. It just wont build any boost at all....If I step on the gas it rev to about 23-2500 rm and than starts running rough. Uppipe leak maybe? Maybe just need to check the clamp?
post #7 of 9 (permalink) Old 08-18-2009, 02:20 PM
OT
OT's Avatar
Blizz..Unless its something obvious on outside, I suspect you'll be taking t. apart again..maybe didnt get housing/pin lined up or ? Good luck!
btw..were u having a boost problem before cleaning?
03 F250 XLT SC/SB 4X4 6L (stock) TqS. SRW 3.73's BD:02/11/03. 01 TL 23' SGII
OT is offline
post #8 of 9 (permalink) Old 08-18-2009, 06:18 PM Thread Starter
Before the first cleaning, the truck would only build up to 18-20 psi max.
After the first cleaning the truck wouldnt build any boost at all.
Cleaned it again today, now the truck builds up to about 25-28 boost max, but it takes quite a while for it to hit 10 psi....After that it hauls ass.
post #9 of 9 (permalink) Old 08-18-2009, 11:30 PM Thread Starter
Any Ideas? Id love to have this working soon ?
