turbo connector hose clamp torque spec - Diesel Forum - TheDieselStop.com
post #1 of 14 (permalink) Old 05-16-2009, 06:08 PM Thread Starter
Send a message via AIM to Larry202br
I discovered the blue flexible connector between the turbo and the pipe from the intercooler was abraded, and was failing. I had to replace it ($75!!!). There was a warning on the hose that said do not overtorque. Can anyone tell me the torque spec for the clamps? Thanks in advance!
2004 F-250 Lariat, srw, short bed, 4x4, Purchased in Feb. of 2006. 6.0, auto, 3.73.
Larry202br is offline
post #2 of 14 (permalink) Old 05-17-2009, 10:45 AM
Banned
9 ft/lb (108 in/lb)..... you're welcome....
GrampyJim is offline
post #3 of 14 (permalink) Old 05-17-2009, 08:40 PM Thread Starter
post #4 of 14 (permalink) Old 02-13-2014, 07:45 PM
Actually I use 109 in/lb. 9 ft/lb is correct. When I convert 108 in/lb it comes 8.999999679171601. So I go 109 which comes out to 9.0833330095343. To me almost 9.1 is better than being short of 9. Also, I do not know why, but when I put a new boot on I have to torque it several times to get everything squished down to where I like it.
Convert inch-pound to foot-pound force - Conversion of Measurement Units
68Portagie19 is offline
post #5 of 14 (permalink) Old 02-13-2014, 09:00 PM
dieselmac's Avatar
9 ft*lbs = 108.0000 in*lbs. FYI, ft/lbs or in/lbs isn't the correct unit. The "/" means divided by, torque is a force times (*) a distance.
Your torque wrench is not accurate enough to be worried about 9 or 9.1 ft*lbs, although I understand your point.
I agree on re-tightening after a heat cycle or 2.
Scott
SOLD -- 2006 F-250 PSD, Lariat
Mods: All the usual stuff
2015 F350, 4x4, Platinum
"Let us endeavor so to live that when we come to die even the undertaker will be sorry" - Mark Twain
dieselmac is offline
post #6 of 14 (permalink) Old 02-14-2014, 09:28 AM
You are correct on the / versus *. Easier and faster to type. I mean the same thing. Actually I must be an old, thick Portagie. From the old school where you round up. 9ft lb = 108.0000038502 when you go to the web site. That is why I use 109. Thank you for the reply. Glad you where able to understand my ramblings.
The biggest problem I have with my clamps is the one on the tube. Once I get the turbo torqued down it usually stays. The one on the floppy tube seems to come lose more often. The floppy tube needs to be attached to the motor some how. It would work becasue there is enough give in the cooler boot. Also, the motor does not move that much. Anyway Monday I tow the Wicked Kitty over to Betabel and after that heat cycle I may give it one more twist on the wrench. I use to use a 1/4 ratchet and tighten them as tight as possible, and with the glue I add, they stayed in place. Now using a torgue wrench they are much tighter and I should have more piece of mine. Also I have added A CCV so the oil has disappeared.
post #7 of 14 (permalink) Old 02-14-2014, 09:36 AM
Blue Boot
The old blue boot that causes the heartache can be a tricky thing to install. I found out the hard way, $82.00 dollars later, that you have to center the clamp over the ring inside the boot. I also found out the ring is not centered between the lines. On my boots so far the clamp has to up against the line near the mouth of the boot. Even on top of the line works. I installed the clamp to close to the inside line, and since it is off the center of the ring, it started to slide toward the turbo. When that happened another boot from my friends at Ford.
post #8 of 14 (permalink) Old 02-14-2014, 09:44 AM
Band_Member's Avatar
My Photos: (64)
Not to derail the thread, I see Grampy Jim is banned
That's too bad since IIRC he was a great source of info and advice.
To keep on topic, I personally would break out my smaller torque wrench on the boot clamps and torque down to 108 inch pounds.
2005 F250 XLT SC, LB
6.0 Torqueshift 3.73LS 4x4 T/C
Trk Bld: 02/05/05 KY
Eng Bld: 02/03/05 Indianapolis
2825 Hrs +/-, 101K Miles - No Major Probs other than brakes
DC Power 185 Alternator
ZOODAD, SEIC,
Atlas 40 FICM @ 90K
4" Banks Turbo-Back Duals
3.5" Ready Lift
Bilstein 5100's
315 - 70R17 Duratrac's
Centramatics
Bodiak Front Receiver
SG2
Coolant Filter
HFCM Plug Upgrade
FP Gauge
Zerex Red ELC
Band_Member is offline
post #9 of 14 (permalink) Old 02-14-2014, 10:13 AM
dieselmac's Avatar
He's been banned for a number of years. Apparently it was a life sentence.....serious interwebz stuffs.
Scott
post #10 of 14 (permalink) Old 02-14-2014, 10:34 AM
interwebz
People still use that word???
Matthew
2005 F-350 ext. cab long box, FX4
Blue Spring
BCP High Idle Mod
DS Bypass Coolant Filter
Rotella Ultra ELC
Rotella T6 Synthetic; 0w-40 (winter) & 5w-40(summer)
EGR Cooler Delete
Bulletproof Oil Cooler, Oil Filter, & Amsoil Bypass Oil Filter
276 000km/172 500 miles as of April. 1 2015.
Canadian Mind is offline
post #11 of 14 (permalink) Old 02-14-2014, 11:02 PM
dieselmac's Avatar
I'm slow to catch on.
Scott
post #12 of 14 (permalink) Old 02-15-2014, 10:10 AM
I am stuck on 109. Just an old stuck Portagie. Anyway I got band from one web site because I was not P. C. Pissed off one of the old timers because I would not kiss His feet. Happens I guess.
post #13 of 14 (permalink) Old 02-15-2014, 10:22 AM Thread Starter
Yes, grampy Jim was wealth of information. He replied to my original post back in 09. Sad to see him gone.
Sent from AutoGuide.com Free App
post #14 of 14 (permalink) Old 02-15-2014, 10:25 AM
Now I'll understand what it means when I see a "Free Grampy Jim" bumpersticker.
It does make me wonder how a guy with over 5k posts gets banned though. A guy so senior doesn't seem like the type to make the types of bashing, personal assaults that usually get people banned. It makes me wonder if any of us are really safe...
'06 F250 4x4 - 5" Flo Pro exhaust, SB Filter intake, Accufab elbow, Edge Evolution (monitoring only), SCT w/ ID custom tune, FASS 195 pump, Gillette Diesel EGR cooler delete, Sinister Diesel coolant filter, ELC coolant, updated turbo drain tube/oil feed line/STC fitting/oil cooler, ARPs w/OEM HGs, Elite coolant lines, ITP RR fuel system, RCD 175/30 injectors, Powermax, BD CCV, FICM.com FICM w/ ID tune, Elite UP, BPD water pump - 13.069 @ 101.94
'02 WRX - Outback rear disc swap, EBC green pads, DBA pillar vane rotors, TXS UP/TBE/TMIC, Perrin LW crank pulley, PPG billet steel shift forks, ACT Streetlite flywheel & clutch, K&N filter, STi Group N motor/trans mounts, TiC/Kartboy rear diff mounts/subframe lock bolts/outrigger stiffeners, Kartboy SS & all shifter bushings, custom PDX tune for Cobb AP - went 14.1 on a terrible 60ft before most of these mods; shooting for 13.50s
TKOPerformance is offline
