Turbo Cool down timer??? - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 12-14-2010, 07:40 AM Thread Starter
mlsteele's Avatar
Anybody running a cool down timer on their turbo? If so what brand is better or easier to hook up and is it really worth it. Sometimes I forget to let the EGT cool down before I shut the engine off.
Steele
______________________________________________
2012 F-250 Lariat 6.7L Crew Cab, Ingot Silver
20"wheels, 3.55 EL gear, Dual Alternators, FX4, Upfitter Switches, Bullet Liner, Weather Tech mats, Reacon side mirror smoke lens, SCT Live Wire TS with PIP tunes, 4" Delete Pipe
My Wife took ownership of:
2006 F-250 Lariat 6.0L Crew Cab, Black w/ Chrome package, Chrome bug guard and door latches
18" stock wheels, Nitto Tera Grappler, 4" Turbo Back MBRP, AccuFab Power Elbo, Edge Insight Monitor, Tinted Windows, Rhino Liner, Husky Floor Mats, B&W Turnover, Air Horn, ZooDad mod, Recon's all around, ARP studs, EGR Delete, SCT from IDP, and a heavy foot
Turned 100K miles 12-23-11
-Bullet Proofed 103K
-New Head Gaskets 58K
-New EGR Cooler 29K
mlsteele is offline
post #2 of 6 (permalink) Old 02-07-2011, 10:00 PM
Unhappy Newish truck First Diesel
I would like to try and revive this thread. I just bought an '05 F250 with the 6.0. Its my first diesel. Ive heard its a good idea to let the engine idle after driving to let it cool down. Then some people say they have never heard of such a thing and im just wasting my time and money letting it idle everytime I go somewhere.
Is it important to let the exhaust cool for every day driving or just when its working hard? If so should i bother with a timer and what would be a good brand to work with. Im getting a remote start installed on wednesday. Cant wait cause im sick of running outside every morning 10 min early just to warm my truck up.
thanks guys
New_2_Diesel is offline
post #3 of 6 (permalink) Old 02-07-2011, 10:08 PM
party_boy114's Avatar
I have the Viper 5901, i put it in about a month ago and love it! I has the turbo timer< i have mine set for 1 min, you can activate the timer with the remote or with an optional installed push button that grounds out the turbo timer wire momentarily that activates the timer.
Tho it doesnt moniter the egt and sets accordingly, the timer works great as well.
06 F-250 6.0L PSD SD Lariat Crew FX4 White
Winnipeg, Manitoba, Canada
Insight CS (ICP psi, RPM, Boost, VGT%, Trans. ECT, EOT, EGT)
Ipr egr dlt. w/stainless up pipe, new oem oil cooler
Updated stand pipes/dummy plugs
Stc fitting update
Blue spring mod
MBRP 4" tb cat. dlt. w/5" Tip
Coolant filter w/ elc coolant
Trans:Mercon LV w/ '08 pan filter and oil pan
HFCM Drain plug
Hydronic 5 Espar Heater,
High Idle Mod,
Rotella T6 5w40 year round,
Viper 5901
'11 Tailgate & Rear Bumper
Bushwacker Fender flares
party_boy114 is offline
post #4 of 6 (permalink) Old 02-07-2011, 11:02 PM
Feedback Score: 2 reviews
Here is one The Turbo Diesel Lifesaver, I just wait tell it down to 350* then turn it off may take from 1 min to 5 or 6 minutes when pulling my 5er in the summer.
http://www.dieselsite.com/index.asp?...ROD&ProdID=879
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS with Expandable pyro
AutoMeter Fuel Pressure Gauge 0-100
Sinister Fuel Pressure Adapter
Updated Fuel Reg. Kit 3C3Z-9T517-AG
WOT 58lbs Idle 62-64lbs Just Right
HFCM Water Separator Drain Plug Upgrade
Ford Cetane boost every fillup
Amsoil By-Pass(Amsoil 5w40)
Fumoto Oil Drain Valve
Dieselsite Coolant Filtration System
Dieselsite Boots
Delo ELC Coolant
Tow Command
Upfitter Switches
Pulling a 14,000 lb Alpenlite 5er
Roll-N-Lock bed cover
97 F350 4x4 PSD CC LB (sold it)
1700 Super Chip
PacBrake&ATS converter lockup
3" dp-4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A pillar EGT,Boost,Trans
2 Stroker is offline
post #5 of 6 (permalink) Old 02-10-2011, 03:03 PM
Red face Important?
So the timer is pretty important even if your not pulling anything? Should everyone one have one including the people that buy a diesel and dont really need it. LOL
post #6 of 6 (permalink) Old 02-10-2011, 04:56 PM
mwe-maxxowner's Avatar
Send a message via AIM to mwe-maxxowner
I find it easy enough, and certainly cheaper, just to make it a habit to watch my egt gauge each and every time I turn my truck off. I just let it get below 300 degrees and turn it off. Most of the time during normal driving, my truck is at or below 300 degrees by the time I get pulled into my parking spot and double check to make sure it's in gear so it doesn't roll away.
My truck is a 7.3, though, maybe the 6.0s take longer to cool down?
87 f250 4wd LB ex cab 460 bored .60 edelbrock intake, towing cam glasspacks-6 mpg 8 on good day- my pride & joy once towed my '85 j-co j-crane 28' 5er
99 F250 7.3(engine stamped june of '99) 250K white ex cab lb, 2wd
jl audio slash 4ch amp, jl 8" sub, focal components front, infinity coax rear, 10 disc changer
-tymar intake, no muff
-bullydog egt, autometer boost
-f5 chip w/80t, 80e, 60t, 100, 140 extreme(140 is amazing!)
Garrett 38r
Chrome fender trim, 265 nitto terra graps, nerf bars, billet grille, '06 headlights, chrome door handles, louvered 5er tailgate
mwe-maxxowner is offline
