Old 08-14-2006, 07:51 AM   #1 (permalink)
Turbo Farts???
While pulling a trailer back from the deer lease this weekend, we started getting a strange "missing" type of condition. This took place when under a load going up hills and when the engine was running below 2000 rpms. It started acting like a miss and you could hear a noise under the hood like air swooshing. Also you could see the boost gauge fluxuating whn this happened.
Is this the turbo farts?
DouglasS is offline
Old 08-14-2006, 08:31 AM   #2 (permalink)
Re: Turbo Farts???
go by some cetain booster from ford. it sounds like you have a inj. acting up.
certified ford dealer 7.3L,6.0L & 6.4L diesel tech & foreman
dvtech is offline
Old 08-14-2006, 12:00 PM   #3 (permalink)
Re: Turbo Farts???
By any chance an 03 or 04?
2007 F350 White King Ranch Crew Cab 4x4
7" EDGE 4 Link Suspension, Fox Remote Reservoir Racing Shocks all the way around with Duals up Front, and Dual Steering Stabilizer. 37" Toyo MT's on 20" wheels.
Fully polished MBRP T304 turbo back exhaust finshed off with a 6" x 18" tip from ITP Diesel...Thanks Dennis!
Future mods, DePricol White Faced Gauges and a 24 volt inverter and power supply mounted in the bed,
NFA_Fun is offline
Old 08-14-2006, 12:07 PM   #4 (permalink)
Re: Turbo Farts???
My 05 has done this from Day 1 on long grades when in OD either pulling or empty. Usually happens just before it downshifts to the next lower gear. As soon as the downshift happens, the turbo farting stops.
2005 F-350 FX4 XLT 4x4 CC/LB Torqshift with Diamond Back ATV Truck Cover, Zoodad Mod
Banks Power PDA with Monster Exhaust and Accufab intake elbow from Innovative Diesel
35x12.5x18 Toyo MT with 2.5" leveling kit, 2005 Weekend Warrior FB2200 for the toys
tzurick is offline
Old 08-14-2006, 12:22 PM   #5 (permalink)
FamilyRide's Avatar
Re: Turbo Farts???
On the soap box. [img]/ubbthreads/images/graemlins/laugh.gif[/img]
Access gas/pressure can be released via:
A "fart" which exits the "rear" which is the trucks exhaust.
A "burp" or "cough" which exits the front/mouth which is the trucks intake.
Turbo Burp or Turbo Cough makes more sense. You could never even hear if the turbo farted. :biggrin"
Off the soapbox. [img]/ubbthreads/images/graemlins/laugh.gif[/img]
Mine's doing it more but also other issues as the EP sensor has failed again and the dealer did not replace it - only reflashed it and it's not the same flash as the new recall.
If you were truly lugging it, it would be normal as mine always was. Mine's no longer normal, although in all fairness, the tuner may have been calling for too much boost in these conditions. I'm hopefully going to tow this week with it stock and I'll see.
2004 EB Excursion, 4x4, 6.0, everything but step tubes and 2nd row chairs, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto sitting on V Codes and Revo 285's.
FamilyRide is offline
Old 08-14-2006, 12:31 PM   #6 (permalink)
Re: Turbo Farts???
I guess they call it a turbo fart since the exit of the turbo (its rear end) is fluctuating which in turn feeds the intake. I would call an engine fart a miss that you would hear in the exhaust.
tzurick is offline
Old 08-14-2006, 06:27 PM   #7 (permalink)
Re: Turbo Farts???
Sticky VGT vanes will cause this, the PCM wants a little less boost, the controls are stuck and when they break free it goes to far. The boost then drops way off making the noise your hearing. Then the PCM wants to close the turbo up a little, again it goes too far and starts cycling. It will buck and fart all the way up the hill. Take a look at my other post on how to clean the turbo, or maybe now that Ford has a TSB on it, they'll do it for you.
2000 F-350 Lariat SC PSD SRW 4X4, Six speed, Dark toreador red, Ball Bearing Turbo, Coolmist Stage 2, Banks Big Hoss 5 chip, Big Head Actuator and 3.5 down pipe with Dynomax exhaust, PacBrake Exhaust brake, AIS Air Filter, Jordan brake control, 20K Reese fifthwheel Hitch, Reese folding gooseneck hitch, Rhino lining born 5/00
1998 35' Challenger fifthwheel double slide with 3600 Onan MicroQuite Generator,Washer/Dryer.
Wife drives a Black 2003 Excursion 4x4 Limited, 6.0 PSD
diesel_doctor is offline
