Turbo on at low speed - Diesel Forum - TheDieselStop.com
Old 08-08-2009, 04:44 PM   #1 (permalink)
The turbo on my 2004 F-250 now kicks on at even low speeds when trying to accelerate or even stay at speed. This is pretty new but doesn't affect performance or mileage. Is this a problem that needs attention?
Rootsource is offline
Old 08-08-2009, 04:55 PM   #2 (permalink)
Turbo
You should hear your turbos whistle pretty much every time you step on the throttle. The exhaust operates your turbo charger, there should not be any boost psi at all at idle or at a coast while moving. Are you seeing any boost at idle??
FK000@aol.com is offline
Old 08-09-2009, 09:42 AM   #3 (permalink)
Turbo
No boost at idle. Only when foot on accelerator.
Old 08-09-2009, 02:45 PM   #4 (permalink)
OT
OT's Avatar
Root..when u say "t. now kicks on/pretty new" what are you comparing too? As mentioned..t. is exhaust driven (assuming alls ok) pushing down on acc. cause's t. to start making boost.
03 F250 XLT SC/SB 4X4 6L (stock) A/T. SRW 3.73's BD:02/11/03. 01 TL 23' SGII
OT is offline
Old 08-09-2009, 04:33 PM   #5 (permalink)
My Photos: (6)
Send a message via AIM to blizzardwarrior7
What did it do before? The turbo is exhaust driven, meaning that if the engine is on, than the turbo is on.
2006 F250 cc/sb sct, studs egr delete, 100 shot injectors, fass fuel pump, twins, rough country 4-link 8" Lift, 38"x15.5" Dick Cepeks, 20x12 Rockstars, 4" Dual Exhaust, Ranch hand bumpers Front & Rear
2002 F350 XL RC/LB Pro Comp 6.5" Lift, 37"x13.5" SuperSwamper M16s, Stage II's, GTP38 turbo, DP Tuner, AFE intake, 5" exhaust, JW Slush Box, AIH Delete, CCV Mod, Zoodad mod, 5.6k mod, FPR Shim, ATS Flex Plate, ATS Torque Converter, AirDog FP-150, Fluidampr.
2006 Ram 2500 QC/SB Smarty, 5" straight pipe, edge, Leveling kit, 35x13.5" mickey ATZs
2006 International CXT DT466 300 hp 860 tq Diablo powerpuck, 6" straight pipe into 7" single stack
blizzardwarrior7 is offline
Old 08-10-2009, 04:44 AM   #6 (permalink)
Turbo
For the first 90,000 miles you would only hear the turbo whistle/whine at highway speeds or if accelerating fast. Now you can hear it at virtually any speed. This only began after the dealer replaced the turbo at the end of the 5 year warranty.
Old 08-10-2009, 10:28 AM   #7 (permalink)
fireguywtc's Avatar
If your truck is running fine, don't worry about it.
07 F-350 xlt 6.0 PSD LB CC SRW 4x4, black on tan, A/T, 5" exhaust w/4" downpipe
67 F-250 Project truck, currently in a billion pieces
70 F-250 4x4 (highboy)
Past trucks: 04 F-250 xlt 6.0 PSD SB extcab 4x4, 6spd, all stock and 97 F-250HD xlt 7.3 PSD extcab LB 4x4, 5spd, Superchips tuner, 4" turbo back exaust, K&N CAI, 02 intercooler installed, Sold
fireguywtc is offline
Old 08-10-2009, 07:44 PM   #8 (permalink)
Turbo
Thanks. That's what I was hoping to hear.
