Turbo Overboost Condition - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 10-29-2011, 06:13 PM Thread Starter
b_macd88's Avatar
Twice now while towing, I have had my turbo shut off on me. Both times happened when boost was around 28 psi. My edge computer gave me a code stating "turbo Overboost condition". I took it to dealer and they said they could not figure it out so they reset the computer. About 2 months after this it happened again. Any ideas? Was I pushing it too hard at 28psi or does it sound like something else might be going on....thanks in advance for any advice.
2006 F350 6.0L PSD 4x4 LB SCC
Edge Insight CS w/pyro
Diesel Turbo Lifesaver
Sent from my iPhone using Autoguide
2006 F350 PSD Crew Cab XLT 4x4 Long Bed
Nitto Trail Grapplers
Garrett Powermax Turbo
BPD EGR Cooler
BPD Fan clutch saver
BPD Water Pump
Banks Intercooler
Banks High-ram intake manifold
Upgraded HPOP
Upgraded fuel pressure regulator (blue spring)
Upgraded turbo oil drain tube
6.4 banjo bolts upgrade
Royal Purple engine oil
Edge Insight CS monitor with pyro
Dfuser frame mount coolant filter kit(frame mount due to banks intercooler)
b_macd88 is offline
post #2 of 6 (permalink) Old 10-29-2011, 06:20 PM
Feedback Score: 2 reviews
Well when pulling my 14k 5er i never hit 28lbs of boost try and keep it around 25lbs and i run Ford cetane boost in my fuel to help keep the turbo and egr valve clean and once a week i drive it like i stole it.
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS with Expandable pyro
AutoMeter Fuel Pressure Gauge 0-100
Sinister Fuel Pressure Adapter
Updated Fuel Reg. Kit 3C3Z-9T517-AG
WOT 58lbs Idle 62-64lbs Just Right
HFCM Water Separator Drain Plug Upgrade
Ford Cetane boost every fillup
Amsoil By-Pass(Amsoil 5w40)
Fumoto Oil Drain Valve
Dieselsite Coolant Filtration System
Dieselsite Boots
Delo ELC Coolant
Tow Command
Upfitter Switches
Pulling a 14,000 lb Alpenlite 5er
Roll-N-Lock bed cover
97 F350 4x4 PSD CC LB (sold it)
1700 Super Chip
PacBrake&ATS converter lockup
3" dp-4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A pillar EGT,Boost,Trans
2 Stroker is offline
post #3 of 6 (permalink) Old 10-30-2011, 10:42 AM
When I had my oil cooler and egr delete done my guy saw an overboost condition on his first test drive. They took the turbo apart and cleaned it up and everything is ok now. I suppose the unison ring was dirty or rusted at that time.
baddna is offline
post #4 of 6 (permalink) Old 10-30-2011, 12:42 PM
sarnott140's Avatar
you need to get your turbo cleaned, overboosting leads to blown headgaskets
'06 F350 CC, SB, 6.0
Oxford white, scangauge 2, 3" lift, egr delete, stc upgrade, dieselsite coolant filter, high idle mod, skyjacker s/s,deezee nerf bars and drybox, 305/65-18 BFG all terrains, Hella driving lights and fog lights.
sarnott140 is offline
post #5 of 6 (permalink) Old 11-03-2011, 01:27 PM
My Photos: (11)
Does anyone make a stainless steel unison ring for these turbos? Seems to me that would solve a lot of problems with these VGTs sticking due to rust and corrosion.
2004 F250 Lariat, Diesel 6.0L, 5spd auto,4x4 FX4, True Blue/Med Parchment, Camper Package, Cab lights, Dual Alternators, AIC, Power Sliding Rear window, 12.5k receiver hitch.
Add-ons: Headache Rack, Brush Guard, B&W Hidden Hitch & Daytime Running Lights, PIAA 520 series driving lights, boost/tranny gauges, Dahl 100 fuel filter/water separator, Prodigy brake controller, air horns, Sinister Coolant Filter.
In-the-works: Onboard air, Aux. fuel/Toolbox combo.
Ordered on: 03/29/04.
Arrived on: 04/28/04.
SIGNED: 05/01/04 Whoop!
Recall 04B24: Installed 02/15/05.
PoppaSmurf is offline
post #6 of 6 (permalink) Old 11-03-2011, 05:49 PM
OT
OT's Avatar
IIRC..there was a change made to unison ring, but dont recall what it was? 06E17 reflash strategy also included cycling t. vanes at idle/stop to supposedly help to prevent sticking issue. Dont recall if cumulative or a specific reflash?
03 F250 XLT SC/SB 4X4 6L (stock) TqS. SRW 3.73's BD:02/11/03. 01 TL 23' SGII
OT is offline
