Turbo Recondition,, Happy - Diesel Forum - TheDieselStop.com
Old 11-12-2012, 10:26 AM   #1 (permalink)
Well with 140K on the truck, see sig line, yes a VERY early 03, the turbo seemed to be sticking. So it was time to dive in.
Being an "Old Geezer" and not able to sit on top of the engine I called my go to helper Brian, my son.
I should mention I took Auto Mech in high school and my son did the same. But only he worked as a mechanic for a couple years. That was 18 years ago.
After reading the HORROR stories we were prepaired for the worst.
Here is Brian digging in at 20 minutes into the job. I was helping with the easy to get to stuff.
Here is one hour and into the job!!!
Object of operation and some progress, Exaust disconnected....
One hour and twenty minutes into the operation!!!!!
I think he and I are HAPPY, Happy, Happy !!!!
I didn't take picks of the re-instillation but here are the pics of what it looked like before reconditioning.
It doesn't look bad considering the miles on it. But the Unison ring was sticking on the hub and could hardly be turned by hand. When all was said and done it worked great and the truck is BACK!!!!
So after all is said and done the truck runs great and the jobe took about 5 hours.
The job was really much eaiser than we had expected.
S_B
Early 2003 F-250SD 6.0ps, 6 spd, 3:73s, 4x4, XLT Extended cab short bed. Most of the bells and missing some of the whistles. Engin born on 3/13/03 Truck about a week later.
Smokey_Bear is offline   Reply With Quote
Old 11-12-2012, 11:00 AM   #2 (permalink)
fordsforever73's Avatar
My Photos: (21)
Feedback Score: 2 reviews
Did you replace bearings, seals, etc? I think I'm going to rebuild my turbo in the spring. I already have a rebuild kit and new unison ring on hand, just in case.
2005 F-350 CC, LB, 4x4, Dually, 6.0 Powerstroke, Torqueshift, 4:10 Gears. Gooseneck and rear pull hitches. "Truck Covers USA" roll up aluminum tonneau cover. Putco Boss Running Boards. Aluminum finned diff covers. Bilstein HD shocks. ProComp steering stabilizer. XRF ball joints. NC Hornet CCV mod. RCD egr delete kit. AirDog fuel system. Strictly Diesel's regulated fuel and coolant return lines kits. Amsoil oil bypass (by NUC Motorsports) and homebuilt coolant bypass kits. CFM intake elbow. ARP head studs with factory gaskets and all upgrades. MBRP 304SS "Cool Dual" exhaust system. SCT Livewire tuner with pyrometer. Autometer 'A' pillar gauges (Boost/Trans temp/Pyrometer/Fuel Pressure). 850 CCA Motorcraft Batteries. Using Rotella T-6 synthetic oil. Upgraded degas tank and cap. Hayes deep aluminum trans pan. GoGo Diesel modified direct clutch solenoid. Retro Solutions HID head and fog lights. High idle mod. Jimmi-Jammers. Many other custom features.
fordsforever73 is offline   Reply With Quote
Old 11-12-2012, 12:28 PM   #3 (permalink)
Iam4MSU's Avatar
Unless your unison ring is cracked or your vanes are broken and bearings are squealing, the only thing you need to do is clean it then polish it with a dremmel and buffing wheel. Lightly coat all surfaces with anti-sieze and put it back together. I just rebuilt mine last week and she runs like a charm now.
2004 F250 Crew Cab King Ranch Lariat FX4 Saddle Leather 6.0 L FUMOTO Valve
AIRAID 4" straight No CAT No MUFF
Nitto Terra Grapplers All Terrain LT285/75R16 10 PR Everything else pretty much stock
NEW Ranchos installed 8/15/2010
WORK IN PROGRESS - R&R EGR COOLER, OIL COOLER, THERMOSTAT, TURBO BOLTS, GASKETS, ORINGS, and adding a COOLANT FILTER WITH NEW COOLANT AND FLUSH
Anyone Got Birds? Will Travel to Hunt!
We are all just Village Idiots,
Enamoured with our own shadow,
Oblivious to the setting sun!
Iam4MSU is offline   Reply With Quote
Old 11-12-2012, 12:41 PM   #4 (permalink)
My Photos: (21)
Ya, I kind of figured that, I hear of many people "cleaning" their turbos. But my luck doesn't go very far and because parts are pretty much 2-3 (or more) days away where I live, I try to keep some parts on hand for those instances where I don't want to wait for something...like a unison ring or a seal. Thanks for the tips.
Old 11-12-2012, 03:54 PM   #5 (permalink)
No. We only did the clean and lube. The seals and bearings were fine. There was no play at all in the bearings.
S_B
