A while back I posted a question about the sound of the turbo under the hood when going down the highway. I had no replies, but carried on rationalizing it in my mind. When I am pulling a hill at a steady speed the turbo sounds like it is oscelating. The pitch of the turbo is changing up and down.
I thought maybe that it was just the turbo bleeding off boost, but I am not sure. I just want to make sure that it is normal. I have had various waranty work done and whe they scan everything it comes back clean. Just want to make sure that there may not be an updated sensor that I may need. I want to make sure it is ok before I touch my exhaust
Thanks in advance, Chris
2004 F350 Regular Cab Long Box XLT, FX4, 6.0L and TorqShift, Manual Transfer Case and Hubs, Dark Shadow Grey Metallic, Keyless Entry, Factory Idle Control, 8 1/2' Fisher MMII, XL Steel Wheels painted Black with 285/75R16 ProComp A/T's, Rough Country 2.5" Leveling Kit.
1991 VW Jetta 1.6L Diesel 5 Speed.
Displaced '97 F-350 Powerstroke XLT, auto, 355 gears, and LT285/75R16 Cooper Discover LT's. I have a Stan's Headers downpipe. Custom built cat delete pipe. 4" exhaust exiting at a 45 in front of the rear wheel, chrome of course. Homemade open element with a K&N Filter. 8' Fisher Minute Mount SnowPlow.
Your turbo is a VGT(variable geometry turbine) The vanes change postion as load changes per the PCM commands based on the input sensors and operating strategy.
2005 F-350 True Blue Harley Davidson 6.0L Crew Cab Short Bed
One of the sensors is the EBP (Exhaust Back Pressure) sensor. It may be faulty and the oscillation is one of the symptoms. It usually does not leave a code.
Dave
2004 F-350. Standard Cab, 4X4, 6.0 with Torqshift, 3.73 w/LS. <font color="red">(((XM))) Satellite Radio.</font> Lo Jack, 6608 lbs wet. Born on 8/4/2003. Engine 07/23/2003. 3" Lift. Grover Air Horns!!! http://community.webshots.com/album/85108545NlXNsD
1993 F-350 4X4 7.3 IDI with 5 spd. Gone now.
1976 Kenworth C-500 with Detroit Diesel 8V92TA with 3 spd Jake, SQHD's and RTO 12513 10 Wheel Dump Truck. Sold.
I may look into replacing this sensor on my own to see what happens. Thanks again, Chris
I'll look into it. I wonder if it would be easier to do myself if it is cost effective. I hate having to go back to the dealer. Well maybe I can call the dealer that is bigger and won't mind doing the work, only if they can do it while I wait. Thanks again, Chris
