Undercarriage alot of rust - Diesel Forum - TheDieselStop.com
Old 04-03-2007, 04:30 PM   #1 (permalink)
Does any body else have alot of rust under there truck, mine just looks like it is rusting realy bad for a year old. My past trucks did not have nearly as much as this one does. Any body else.
2006 F-250 6.0 SRW Supercab Lariat 4X4 ESOF 3.73 Gears, Short Bed Dark Stone Metallic & Arizona Beige, Crome Package, Tan Leather Interior.
coonman111 is offline
Old 04-03-2007, 04:35 PM   #2 (permalink)
Re: Undercarriage alot of rust
My 03 came new with a lot of rust underneath. I just sprayed it and it has been good since. I had a post about this earlier and all the responders seemed to think this was normal. Dosen't seem to me that there should be any rust on a new truck. jmho.
JD
08, 6.4, F-350, torqshift, SRW, lariat, 4X4, LB, CC, Pueblo gold (Built the week of 04/09/07)Arrived 4/24/07 brought home 4/26/07
http://rides.webshots.com/photo/2919...01044415MSbgrF
jhughd is offline
Old 04-03-2007, 04:41 PM   #3 (permalink)
lincster's Avatar
My Photos: (22)
New trucks still sit on a lot outside the plant or a train yard so rust can happen pretty quick.
2006 F350 4X4 Dually, Tow Boss, Crew Cab, Lariat... Inyati Spray In Bedliner, Autometer Z Series Gauges towing a 2006 LE3905 Weekend Warrior
On order: 2012 F350 4X4 Dually, Oxford White, Black Leather, Ultimate Lariat Package
lincster is offline
Old 04-03-2007, 04:55 PM   #4 (permalink)
It's metal, it's going to rust. My 97 F250 HD is pretty rusty; the spare tire carrier finally gave out when I was putting in fence around the pasture. It broke loose toward the front, but not completely free and when it finally hung up on the ground it lifted the back of the truck up as it ran over it. Scared the bejeebies out of me as I had no idea what it was til I got out and saw the spare tire and carrier on the ground. [img]/ubbthreads/images/graemlins/eek.gif[/img]
2004 F350 Crew XLT 4x4 long box, SRW, 3.73 Gears
Bone Stock
newtodieseling is offline
Old 04-03-2007, 06:45 PM   #5 (permalink)
FamilyRide's Avatar
After just over 3 years, mine doesn't, but I'm in Texas. I see you're in NY?
2004 EB Excursion, 4x4, 6.0, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto, V code front springs, Revo 285's and bubba lights
FamilyRide is offline
Old 04-03-2007, 07:30 PM   #6 (permalink)
Im in NJ and mine is rusting too. I have already repainted the entire driveshaft. Now there is some rust showing up on some bolts and the diff pan.
2008 Dodge 1500 Quad Cab SLT
http://community.webshots.com/user/mbro598814
2006 F-350 4x4 Crew Cab SB 6.0L Diesel Lariat (trade)
1996 F-250 CC SWB 7.3L XLT traded
2004 US Cargo 14x 7 enclosed trailer
Markford14 is offline
Old 04-03-2007, 09:00 PM   #7 (permalink)
Thanks guys they just don't make them like they use to. But I still love the truck.
Old 04-03-2007, 09:09 PM   #8 (permalink)
Texrob1's Avatar
Send a message via Yahoo to Texrob1
[/ QUOTE ]I was going to guess the same thing.The salty winter northern roads, may make yall's trucks worse as far as rust goes. [img]/ubbthreads/images/graemlins/eek.gif[/img]
2005 F250 XLT wedgewood blue 4x4 C/C SWB,6.0L PSD, Auto.(Member of 05 STC Failure Club ) 2006 Expedition Eddie Bauer,5.4L (Wife's) NRA Life Member. TSRA Life member.
Texrob1 is offline
Old 04-03-2007, 09:21 PM   #9 (permalink)
They could build the truck so it wouldn't rust or at least wouldn't for at least 5 years +++. But the truck is expensive at it is so to lower cost they lower quality and cut corners. Paint the undercarriage of your truck with epoxy and urethane and look at it in 10 years. You will probably have more rust on a truck in a dealer lot than you would with that kind of paint system.
Dan
2006 F350 Superduty CrewCab 6.0 XLT Sport package (oxford white) options - a little bit of everything
ANSA SILVERLINE DUAL EXHAUST
danster is offline
