Up Date On Using 10W-30 Oil - Diesel Forum - TheDieselStop.com
Old 06-02-2005, 07:43 PM   #1 (permalink)
I was told today at the dealership that they did not have anything in writing from Ford when the tech said that I should be using 10W-30 oil in my truck. They said that the tech didn't know that I am pulling a 5th wheel trailer. They (I'm using they because I don't want to use the persons name) told me that they called Ford on the hotline and was told just what it states in the owners manual when towing heavy I'm to use 15W-40. If not towing then to use 10W-30. I don't know how the tech missed the 5th wheel tailgate on the truck and the bed rails for the reese hitch. Oh well it took a lot of phone calls and going to the dealers today to get the answer. So it was a whole lot of nothing. I had made up my mine if I didn't see it in writing from Ford I was going to use 15W-40 oil as I have in the past. [img]/ubbthreads/images/graemlins/shrug.gif[/img] Thank you everybody for your help on this.
2004/03 F350 Lariat 4WD DW CC 6.0 Auto-Trans., 4.10 Limited Slip, Leather Captains Chairs, White over Silver, Heated Seats, Adjustable Pedals, Telescoping Heated Mirrors, Reverse Sensor, Class 5 Hitch. American Fuel Tank/Tool Box 45gal.Lund Sun Visor II, Handy 5th. Wheel Tailgate.
1800 Gold Wing Illusion Blue. Member Of: Blue Knights NJ #1, GWRRA Cycle Clubs, FOP, VFW & NRA Life.
Keystone 5th/W Tail-gator 34ft.
BlueJay is offline
Old 06-02-2005, 07:55 PM   #2 (permalink)
Re: Up Date On Using 10W-30 Oil
Glad to hear you got to the bottom of things. Maybe the tech thought the 5th wheel gate was to make it easier to load groceries in the bed. [img]/ubbthreads/images/graemlins/rolleyes.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
2004 F-250 Lariat CC, Short Bed, 4x4, 6.0L, TorqShift, FX4, Metallic Green/Arizona Beige, Medium Parchment Leather, Fumoto, B&W Turnover, A.R.E. LSX Tonneau, Built 4/01/04
MoeB is offline
Old 06-02-2005, 09:45 PM   #3 (permalink)
Does this mean if we are going to tow before the first oil change we should switch to 15w-40 even if the 3000-5000 miles are not up?
2005 F250 crew cab XLT fx4, sun roof, leather, rhino liner, diamond plate tail gate cover, diamond plate mud gaurds, xtang tano cover
2003 7.3 PSD crew cab XLT turned out to be a lemon-trade
2002 V10 crew cab sold it!
1998 Ford F150
1998 Ford Windstar
2001 Honda Rubicon
malkiman is offline
Old 06-02-2005, 10:08 PM   #4 (permalink)
POS
Why not just use 15-40 all the time?
<font color="red"> WIX filters at </font><font color="blue">www.fleetfilter.com</font>
POS is offline
Old 06-02-2005, 10:32 PM   #5 (permalink)
hitecdan's Avatar
My Photos: (22)
My grocery getter does just fine on 15W-40. I've never used a 10W-30. Maybe if I lived somewhere in the great white north, then maybe. But in California for my daily grocery store runs, 15W-40 no problem.
My html Version of the 6.0L Bible Now with 2005 Updates
$5 AIC
Born on date: Jan 20, 2003
Number of times the EGR valve has been replaced/cleaned: 0 (updated: 4/15/2010)
The United States Constitution © 1791, All Right Reserved.
hitecdan is offline
Old 06-02-2005, 10:40 PM   #6 (permalink)
Mine won't run is the winter on 15/40. Romps, smokes, all kinds of bad stuff. 10/30 and its good to go. Whats wrong with 10/30 and towing?
New truck
08 f-250 6.4 auto CC SB FX-4 stock
Sold
3/27/03 build F-350,CC,SB,DRW,6.0,auto,Black on Black,Blacked out bumpers/grill,285/75/16 Toyo A/T, 2" spacer, Alpine everything,Vector 1000w Inverter,16k Reese slider,Prodigy brake controler,MBRP cat back with muffler delete,Autometer luners on the A-pillar,Viper 5900,XM Radio
04 F-350 6.0,auto,supercab,shortbed, 8ft Fisher X-Blade, Hideaway Strobes, XM Radio,Alpine Head unit,X-codes, Edge Mini spring pack, Edge adjustable track bar,International helper springs 315/75/16 Toyo A/t,Prodigy brake controler,MBRP 3.5" downpipe,5"stacks
Last truck
sick, 1/7/03 build
2003 F-350 XLT supercab 6.0 powerstroke
4"lift 37 MT/R 372HP
http://community.webshots.com/user/traxx400-date
ipkyss is offline
Old 06-02-2005, 11:11 PM   #7 (permalink)
Haven't really looked at my manual yet as far as what oil to use, but for the last 9 years, I have always used 15-40W in my 7.3l. Unless things have changed with the 6.0 motors, I thought 15-40W was mandatory due to the extra detergent it uses that 10-30W doesn't have. Haven't needed an oil change yet, but I will double check the manual when I do.
2005 F350 Crew Cab 4x4 SRW LB White Lariat FX4 6.0
4.5" Donahoe Racing Lift with 5" rear blocks. 35x12.5x18 Toyo Open Country M/T's on stock rims. Air Lift rear air bags with onboard compressor.
Sold: 1996 F250 Super Cab LB XLT White 7.3L 124,000mi. 1996 F250 Photo
Sotoman is offline
Old 06-02-2005, 11:24 PM   #8 (permalink)
hitecdan's Avatar
My Photos: (22)
Motorcraft and others do make diesel engine rated 10W-30 oils, CH-4 and CI-4. But unless you live somewhere where it's cold, it's almost impossible to find. Another alternative to 10W-30 is a 5W-40 synthetic. Ford does not list it in the owner's manual as a "recommended" oil, but others have used it.
$5 AIC
hitecdan is offline
Old 06-03-2005, 12:23 AM   #9 (permalink)
FamilyRide's Avatar
Kind of ironic huh? Manual says no towing until after 500 miles, yet it also says to use 15w-40 if you're towing. So yep, it would mean changing then oil according to that!
FYI I have a friend who is a performance boat dealer. He has an '03 he used to go pick up a couple of boats, one of which weighed about 7500 lbs and rove it from California back to Texas. The truck was new but with the distance, he did have 500+ miles on it, but hadn't changed the oil.
Truck is still used as a shop truck doing the same things and runs great!
2004 EB Excursion, 4x4, 6.0, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto, V code front springs, Revo 285's and bubba lights
FamilyRide is offline
Old 06-03-2005, 01:44 AM   #10 (permalink)
OT
OT's Avatar
Tks. for update. Amazing, eh. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
FWIW (old news)...I've only used 10W/30 solo. Towing/hauling 15W/40. 15W/40 caused (sometimes) rompin/more smokin. [img]/ubbthreads/images/graemlins/shrug.gif[/img] 10W/30 no rompin/less smokin.
Changed factory 10/30 to 15/40 under 3K mi. due to temps were 90+ for my first tow trip. Long story/short.. OA showed 15/40 sheared, under 3K mi. was in 10/30 range. [img]/ubbthreads/images/graemlins/shrug.gif[/img] Yeah, that was towing in hot temps. [img]/ubbthreads/images/graemlins/phoney.gif[/img]
What, if any effect o.shearing has on 6L remains to be seen? JMO!However, after reading about shearing didnt leave me w/good feeling.
Currently using Schaeffer S.7000 Syn.blend 15W/40 CI 4. Havent done yet, but OA I saw &amp; BStone confirmed, it held grade (viscosity) &amp; didn't shear down low like Delo.15W/40. &amp; others, incld. some syn. 5/40 etc.
Unfortunately S7000 is causing the rompin/more smokin to start. Just changed from delo.10/30 which didn't. Reflash might fix, but dont like what comes with it. Still on orig. settings. Got d.10W/30 at local Chevron fuel dealer Berry Hinckley. As mentioned can be hard to find. Haven't seen it at usual outlets.
So the oil saga continues for me &amp; I suspect for others also. S.7000 apparently more stable, but rompin/smokin. Not sure Im gonna continue with it. Certainly is $$$.
I can run dino.15W/40 year round here, but...
Now, if I can just figure out how to read the o.level correctly. [img]/ubbthreads/images/graemlins/biggrin.gif[/img] OT
03 F250 XLT SC/SB 4X4 6L (stock) A/T. SRW 3.73's BD:02/11/03. 01 TL 23' SGII
OT is offline
Old 06-03-2005, 07:09 AM   #11 (permalink)
every f-350 diesel i have owned has had 10-30 amsoil put in it as soon as i got the new pick-up home. there has never been any problems with any of these 3 engines, nor any oil burning problems. the first two used 1 quart every 2500 miles. the new 6.0 uses a quart every 4,000 miles. ever since cummins made a bunch of big diesels that didnt use any oil and they all needed new pistns and sleaves, i like a diesel that lets a little oil past the scrapper rings.
04crew is offline
Old 06-03-2005, 07:22 AM   #12 (permalink)
Thank you. I think i'll use synthetic because i will need the truck to tow a 10,000 lbs trailer with ony about 600 miles on the odometer. Thank you for the input. I didn't realize the trucks came with 10w-30 break in oil. That's what is great about this site!
1998 Ford F150
1998 Ford Windstar
2001 Honda Rubicon
malkiman is offline
Old 06-03-2005, 08:56 AM   #13 (permalink)
Other than the fact that the factory oil usually sees the most break-in activity, it's not really a break-in oil...just plain ol' 10w-30. There's nothing wrong with dumping it right after the 500 mile mark and putting in 15w-40 if you'll be doing heavy duty towing. I would not put synth in it until after a few thousand miles, as it may retard break-in. (I don't know this for a fact, but just to be safe.)
MoeB is offline
Old 06-03-2005, 09:35 AM   #14 (permalink)
just did my first Oil change at 3400 miles. I went to 15/40. Not because of preferance, but because thats all the shop had in 4 gallons....used plain old rotella Diesel oil. Hasn't given me any issues. And was pretty cheap. I personally don't know of anything bad about this oil, or great about it...so if any one knows fill me in.
FYI. on the '05 350. A 5 gallon bucket slid under the truck behind coil overs fits nicely under oilpan w/o jacking. Use a bucket with a nozzle on the bottom ( like the ones used to brew your own beer). And use some 1/4" mesh riveted over the top to catch the plug. After refilling your beast with 15qt's use the drain nozzle to refill used containers...very nice set up. Bucket cost me $18 to make. And did an oil change with out a DROP hitting the concrete..
OK than.
ryan
rfarrelly is offline
Old 06-03-2005, 09:56 AM   #15 (permalink)
I realize the 6.0 is a totally different beast but, with that said, I used Rotella 15W-40 in my 7.3 for 13 years without a hitch. The only oil I lost leaked out of the fron main seal which was replaced three times before I decided to just let it leak.
'05 F350 Lariat DRW 4X4 6L Auto, stock.
Above replaced '91 F350 XLT Lariat DRW 2X4 7.3L 5 speed man.
jbdawson is offline
