Upfitter switch wiring locations - Diesel Forum - TheDieselStop.com
post #1 of 11 (permalink) Old 04-03-2006, 07:14 PM Thread Starter
tedncindy's Avatar
Help! Bought a 2006 DRW f-350 and am searching for the locations of the aux wiring locations? I went to where Ford stated in their manual, but the page will not come up. This site is better than any google search........so......who can help?
Thanks in advance.
2006 F-350, DRW, stock (Sold)
2011 F-350, DRW, King Ranch
2006 391K-SUT Sunnybrook toyhauler (Sold)
2010 Cameo F37FB3
2005 Suzuki Intruder 1500 (Sold)
Wife, 2 boys, 2 cats, 1 Great Dane (Not SOLD YET!)
tedncindy is offline
post #2 of 11 (permalink) Old 04-03-2006, 07:32 PM
FTG-05's Avatar
My Photos: (25)
Re: Upfitter switch wiring locations
You're in luck, just did this yesterday hooking up aux reverse lights.
- Big panel underneath the steering wheel, comes off by pulling the top away, with those huge big handles made just for the purpose [img]/ubbthreads/images/graemlins/smile.gif[/img]
- Power distrubution panel just to the left with 4 10 mm bolts holding them on.
- Take the 4 10 mill bolts off, pull the PD panel down and away, careful, there's live power here, although protected.
- Look up and to the left you should see the following:
4 "pull thru" wires, red, black, white and blue. These go through the firewall and are "blunt cut" just in front of the drivers side firewall in the engine bay. They're 14 ga, use'em for what you want; they are there so you don't have to go through the firewall with your stuff.
11 SEIC wires (if you have a diesel, 9 if gas). These are used for among other things: to modify your idle control by simply flipping a switch.
4 upfitter wires, 2 12 or 14 ga, 2 18 ga:
Aux-1 Circuit No 1936 wire color: Orange/Lt. Green [30amp]
Aux-2 Circuit No 1933 wire color: Orange [30amp]
Aux-3 Circuit No 1934 wire color: Orange/Yellow [10amp]
Aux-4 Circuit No 1935 wire color: Orange/Lt. Blue [10amp]
More here:
High Idle
and here:
https://www.fleet.ford.com/truckbbas...bb_pdf/160.pdf
Good luck.
Al
'06 F-350 SRW 6.0 PSD
FTG-05 is offline
post #3 of 11 (permalink) Old 04-03-2006, 07:42 PM
overfly's Avatar
My Photos: (16)
The wires are located in a bundle behind the fuse box in the cab. You'll need to remove it (4 bolts - 10mm socket required) to get to the wires. Wire colors are:
Aux. 1 - 30Amp Orange w/light green trace
Aux. 2 - 30Amp Orange
Aux. 3 - 10Amp Orange w/yellow trace
Aux. 4 - 10Amp Orange w/light blue trace
More detailed information about the Upfitter switches can be found in
the Electrical Wiring section of the Ford Truck Body Builders Layout
Book, found at www.fleet.ford.com/truckbbas.
Driver Controls
2006
- Amarillo Package,loaded with all the toys, 4" MBRP cat back exhaust, Autometer EGT gauge, Viper 791XV auto start/cool down timer/alarm, Pioneer AVIC-D3 navigation/XM Radio/Sirius, 2.5" Tuff Country Leveling kit, KC Hilights front & rear, Dieselsite.com coolant filter, SkyJacker dual steering stabilizer, Firestone Ride Rite airbags w/onboard compressor, Kleinn Train Horns, Bilsteins all the way around, Recon LED's in the back, Programmed with the SuperChips 1805 Tuner always set on Tow Safe for a little extra get up and go.
30' Cardinal 30TS 5th wheel. The weekend home away from home.
"The early bird may get the worm, but the second mouse gets the cheese."
overfly is offline
post #4 of 11 (permalink) Old 04-03-2006, 07:58 PM
Mine were tucked up out of the way so well, that I had a h3ll of a time finding them even though I knew where they were.
Steve Urban
Semper Fi!
2007 F350, Lariat High Line, SRW, SC, LB, 4x4, 6.0/auto, FX4, Camper Pkg, HD alt, Red w/custom black two-tone, Buckstop bumpers F&R, Warn 16.5ti winch, Line-X, F550 coils, 305/70R18 ProComp XtremeMTs
2007 Apex9.5 truck camper
1973 Bronco (stock), wife's
1973 Bronco (HEAVILY modified), mine
2006 Mustang V6, Screaming Yellow, wife's
2006 F350, Amarillo, SRW, CC, 4x4, SB, 6.0/auto (traded)
2004 F350, SRW, CC, SB, Sport, 4x4, 6.0/auto (bought back by Ford)
SteveIn29 is offline
post #5 of 11 (permalink) Old 04-03-2006, 07:58 PM Thread Starter
tedncindy's Avatar
Al and Overfly,
Thanks.........now to find the right toys to plug in!!!! Suggestions? Too many toys........too little time.
2010 Cameo F37FB3
post #6 of 11 (permalink) Old 04-03-2006, 08:02 PM
Okay, please enlighten me. What does "11 SEIC wires (if you have a diesel, 9 if gas)." mean.
I did the high idle mod. Now I need to wire aftermarket lights and this confuses me.
Gerald
'06 F350 XLT 6.0 Crewcab SRW,FX4,6 spd. manual, Arizona Biege Met. BONE stock except for appearance and convienience add-ons: Westin stainless nerf bars, Brown's welding grillguard, Billet grill, Speedliner spray-in, Protecta bedmat,Fumoto valve,Hide-A-Way gooseneck hitch,amber pinch weld lights, Husky floor liners, C-betr mirrors.
'03 6.0 Excursion 4X4 Limited (Wife's ride)stock 'cept for the Ranchhand bolt-on grillguard, 285/75/16's and Fumoto valve.
SOLD! '94F350,PSD,4x4,CC,straight pipe(I HATE CATS!!!),shimmed,ported snorkle,K&N filter,J.D. coolant eye,amzoil-tranny&trans.case,updated PCM.Pro-Comp 315/75/16A/T's,Pioneer cd player,Brite Box,LuK SMFW-LuK 13 clutch,4" Skyjacker lift.
Married so driver carries NO CASH!!!!!
hotcrazee is offline
post #7 of 11 (permalink) Old 04-03-2006, 08:42 PM
FTG-05's Avatar
My Photos: (25)
Hotcrazee, look at the *.pdf in the second link I posted. The info I regurgitated is in the lower left. Apparently, these are to access the computer by vehicle upfitters and people like us e.g. high idle mode. Not sure they're used for aux lighting. There, now I've exhausted my knowledge on that subject. [img]/ubbthreads/images/graemlins/smile.gif[/img]
Al
FTG-05 is offline
post #8 of 11 (permalink) Old 04-03-2006, 09:01 PM
I get it now. I had to refresh the memory a bit after looking at the link.
post #9 of 11 (permalink) Old 04-03-2006, 09:16 PM
FTG-05's Avatar
My Photos: (25)
Driver Controls
Link fixed??
https://www.fleet.ford.com/truckbbas/
FTG-05 is offline
post #10 of 11 (permalink) Old 04-08-2006, 02:03 PM
Is it possible to add the upfitter switches?
2006 F-250 White CC LWB Lariat FX4 20" Wheels, Chrome Package, Moonroof, Pwr Rear Sld, Rhino Liner
deker9 is offline
post #11 of 11 (permalink) Old 04-08-2006, 04:12 PM
overfly's Avatar
My Photos: (16)
Yes - check here.
2006
overfly is offline
