upgrades while dealer fixes egr, turbo & heads - Diesel Forum - TheDieselStop.com
Old 09-11-2009, 06:51 PM   #1 (permalink)
any thoughts on upgrades while dealer fixes egr, egr cooler, oil cooler, head gaskets, new heads and new turbo? ARP studs for sure...others?
btw, 06 f250, 4x4, automatic, used for commute and light hauling, not worked hard at all. engine was great for first 60k miles, then periodic whirling noise from turbo under load with low power and hard-long starts. Then at 70k miles, coolant blow out and using a 1/2 gallon of coolant to dive 30 miles. hence the dealer fix above.
i know several guys that had the same experience at 60-90k miles
cheers
06 F250 Harley
4.5in Rancho Lift & adjustable shocks
hankook ATM 325 60 20 E
stock harley rims
banks programer w/pda
cat delete pipe
zoodad and air filter
fabtech prerunner bar and 2 lights
4 lights behind grill
train horn
rjquad is offline
Old 09-11-2009, 09:05 PM   #2 (permalink)
cheers
YEA LOSE THE BANKS THATS MOST LIKELY WHY YOUR PULLING HEADS RIGHT NOW
2005 F350 XL REGULAR CAB 6.0 11 FOOT SERVICE BOX DRW STOCK 212,347 ON THE CLOCK
1997 34.5 FLEETWOOD AVION 5TH WHEEL
2003 F350 XLT CREW CAB 7.3 STOCK DRW 85,000 on the clock
JOHN 3:16
timbo2 is offline
Old 09-12-2009, 12:08 PM   #3 (permalink)
mostly run the banks on the economy mode and level 4 when pulling a trailer.
exhaust temp stays low and fuel mileage improves 1-1.5 mpg.
of course this means nothing if it blows the heads/motor.
cheers
06 F250 Harley
stock harley rims
cat delete pipe
train horn
rjquad is offline
Old 09-13-2009, 10:47 AM   #4 (permalink)
Is this covered under warranty? I know there is a 5yr/100k warranty on it, but wanted to check with someone who is having a dealer work on it. I think I am having issues with mine also, and need to get it to the dealership to have it checked over after Oct.
White smoke at startup, then rich smell of fuel, poor fuel mileage even with 35's.
Any thoughts on that one?
2005 F250 XL, Powerstroke, 6 Speed Manual, 4X4, Quadzilla Xzillaraider module (30,60,120hp),T.A.G. (Turbo Air Guide), Tinted Windows, Pioneer Stereo System, Upgraded to 06 grille, headlights, Superlift 4inch Suspension Lift. Line-X Bedliner, Front/Rear bumper/Brush Guard line-x coated, Smoked Clearance Lenses, Chrome Door/Tailgate Handle Covers, BFG A/T 35's on 17x9 Pacer's.
bbrrcrw is offline
Old 09-13-2009, 11:07 AM   #5 (permalink)
69cj's Avatar
Can't speak for all dealers but most and esp. Ford will reject a headgasket claim when mods such as tuners and cai's are involved. They can also void your warranty on the Oasis report stopping you from taking it to another dealer.
2005 Lariet, 6.0, 3:73 1969 Mach 1, 428 CJ
1971 Triumph Trident(SOLD)
2007 Road King flhp
2007 Jazz 5er, 11k
173rd Airborne
69cj is offline
Old 09-13-2009, 01:45 PM   #6 (permalink)
cheers
YEA BUT YOU ARE STILL RAISING THE PRESSURE IN THE CYLINDERS AND ARE STRETCHING THE HEAD BOLTS NOT TO MANY MODS A DEALER WILL INSTALL BECAUSE A LOT OF THEM WILL VOID YOUR WARRANTY
JOHN 3:16
timbo2 is offline
Old 09-13-2009, 03:04 PM   #7 (permalink)
69cj's Avatar
Also if a dealer gets caught installing mods that violate state or fed. smog laws he can pretty much kiss his liscense by-by. At the least a very hefty fine.
2007 Road King flhp
2007 Jazz 5er, 11k
173rd Airborne
69cj is offline
Old 09-13-2009, 03:59 PM   #8 (permalink)
FamilyRide's Avatar
cheers
I'm not a fan of Banks on a 6.0 either. But you're on the right track with having the studs installed.
Are you sure you understand what you wrote and how many things are wrong with it?
How is that relevant?
I don't mean to seem to be picking on you, if it were 2 different people, the quotes would still be there. But some of the things that get said sometimes.....Wow.
2004 EB Excursion, 4x4, 6.0, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto, V code front springs, Revo 285's and bubba lights
FamilyRide is offline
Old 09-14-2009, 12:15 AM   #9 (permalink)
dealer knows about the banks and said all will be covered under the 100k mile warranty,
except the parts cost of the ARP studs.
will update this week after the work is done (been in the shop since wed last week).
cheers
06 F250 Harley
stock harley rims
cat delete pipe
train horn
rjquad is offline
