VSS Location - Diesel Forum - TheDieselStop.com
Old 06-30-2009, 09:38 AM   #1 (permalink)
mlsteele's Avatar
VSS Location
Guys,
Where is the VSS located on the 06 trucks? My ABS light is coming on and going off when driving. When the light comes on the speedometer drops to zero and than back to speed.
Steele
______________________________________________
2006 F-250 Lariat 6.0L Crew Cab, Black w/ Chrome package, Chrome bug guard and door latches
18" stock wheels, Nitto Tera Grappler, 4" Turbo Back MBRP, AccuFab Power Elbo, Edge Insight Monitor, Tinted Windows, Rhino Liner, Husky Floor Mats, B&W Turnover, Air Horn, ZooDad mod, Recon's all around
-New Head Gaskets 58K
-New EGR Cooler 29K
mlsteele is offline
Old 06-30-2009, 02:17 PM   #2 (permalink)
On top of your rear differential. You'll see the pigtail plugged into it. If you're careful unplugging it you'll likely see water pour out of the connection or @ least be wet. It picks up road water thrown up there and leaks into the VSS, it's a common issue on the 06 for sure. Has one bolt that secures the hold down plate. I changed the connector and VSS. Taped it real good as to seal out water. No more ABS light and cruise doesn't kick off anymore.
Ken
2006,F-250 FX4,C/C,Lariat,6.0 PS w/ Auto & 3:73, Dark Satin Green/ Arizona Beige, Zoo-Dad, Diesel Site Coolant Filter, Accu Fab Elbow, Ford-Blue Spring FPR Upgrade, Muffler Delete, Nitto Terra-Grapplers AT 33's
Muddog06 is offline
Old 06-30-2009, 03:20 PM   #3 (permalink)
mlsteele's Avatar
Awesome!! Thanks for the advice. I will check that out this afternoon. I hope this fixes my problem. Thanks again
Steele
-New EGR Cooler 29K
mlsteele is offline
