Water in Fuel - Diesel Forum - TheDieselStop.com
Old 09-19-2005, 08:38 PM   #1 (permalink)
Water in Fuel
I have a few questions. About 7 months ago, my water in fuel light came on (about 14K miles on a 2004 6.0L, w/6 spd trans in an F350 4x4). Not finding a drain - I took it to a dealer - hoping to get it warrantied.
Besides charging me $23.00 to drain the water (but he did show me the brass plug) it solved the problem,.
Now, I got it again. But now, the brass plug was frozen in place, so i loosened the cover - not once, but 3 times in the course of a week. Still, I get the light returning. Sometimes intermittent and sometimes steady.
3 questions:
1. Should it take multiple drainings of the water seperator?
2. Is there an aftermarket cover that more handily allows draining? The current setup seems to take a 1/4" socket on a 1/4" drive to fit - but once it gets some fuel on it, is too slippery to snug without the fear of stripping the heads. The seperator seems to have been placed in about the least user friendly place it could fit in to.
3. I change the filter seasonaly - as the fuel in New England changes. My thinking that the filter has no affect on this because the water (should??) seperates out BEFORE it runs through the filter (at least it did on my older diesels). Is this assumption incorrect?
I have owned a few of the older Dodge Cuimmins Diesels and a few older GM 6.2's - and water was never a huge problem to drain, the warning went on and you reached under the hood, spun the petcock and voila - after pissing out a few ounces of trapped water you were good to go.
This is very frustrating since each time I drain it - the light stays off until I am complacent and then BAM - it whacks me across the forehead. Overall I like the truck - but I do fear that as winter arrives, this could become a problem that strands me on a frigid day.
Any answers?
Thanks,
Dave in Pittsfield, Mass.
Berkshirite is offline
Old 09-19-2005, 09:17 PM   #2 (permalink)
dbennett48's Avatar
Re: Water in Fuel
Take it in. You will get a new HCFM cover at least. There is a TSB on this problem. It is caused by corrosion inside the fuel bowl.
Dave
2004 F-350. Standard Cab, 4X4, 6.0 with Torqshift, 3.73 w/LS. <font color="red">(((XM))) Satellite Radio.</font> Lo Jack, 6608 lbs wet. Born on 8/4/2003. Engine 07/23/2003. 3" Lift. Grover Air Horns!!!
http://community.webshots.com/album/85108545NlXNsD
1993 F-350 4X4 7.3 IDI with 5 spd. Gone now.
1976 Kenworth C-500 with Detroit Diesel 8V92TA with 3 spd Jake, SQHD's and RTO 12513 10 Wheel Dump Truck. Sold.
dbennett48 is offline
Old 09-19-2005, 09:55 PM   #3 (permalink)
Re: Water in Fuel
Youre right about it being a PINTA. Come on Ford work with us.
I wouldn't worry about it a whole lot. If you just recently drained you're water seperator give it a couple days for the light to go off. Seems to be about the norm. If the light continues to stay on i would suspect that you have a bad sensor.
Cant go wrong using Stanadyne with every fill up.
J. Maley
2004 Grey Lariat Crew Cab - 6.0L FX4 w/Grey Leather Interior
6" EDGE Suspension Lift
36x14.50x16.75 Interco TrXus STS
16.5x9.75 Weld Mountain Crusher Wheels
Bushwacker OE Fender Flares
Edge Juice Box
Magnaflow Exhaust
Line X Bed Liner
yankspanker is offline
