Water In Fuel Light??? - Diesel Forum - TheDieselStop.com
post #1 of 13 (permalink) Old 01-28-2008, 08:05 PM Thread Starter
Question Water In Fuel Light???
I searched and found some steps to take once the light comes on. So this is what I have done and the results.
I drained the HFMC and did notice that the fuel that got on the ground had some watery lumps in it. The 1/3 of a 2 lieter bottle that I collected and managed not to spill did have some sediment in the bottom but no noticeable water.
I did notice that the light did take longer to come on after draining.
What should I try next.
I have 3/4 of a tank left and added some ati-gell that said would get the water out too. I always fill up a the same chain of truck stops and they do go through a lot of fuel.
Please advise. Thanks.
'06 F250 CC King Ranch Shortbed SRW, 6.0PSD, TorqShift, FX4, ESOF, 3.73LS
Totaled '05 F250 CC Lariat shortbed SRW, 6.0PSD, TorqShift, FX4, ESOF, 3.73LS RIP
tu3712 is offline
post #2 of 13 (permalink) Old 01-28-2008, 08:18 PM
Texrob1's Avatar
Send a message via Yahoo to Texrob1
If you have drained the HFCM & the WIF light is still on,you probably have a bad sensor,so far that's the only problem I have had with my truck (Knock on wood Twice) It's the only time I have actually seen that warning when my sensor went bad,it seems to be a fairly common problem with the 05's from what I have read,Good luck.
2005 F250 XLT wedgewood blue 4x4 C/C SWB,6.0L PSD, Auto.(Member of 05 STC Failure Club
) 2006 Expedition Eddie Bauer,5.4L (Wife's) NRA Life Member. TSRA Life member.
Texrob1 is offline
post #3 of 13 (permalink) Old 01-29-2008, 09:22 AM
I was on a trip when I had same problem, WIF light came on, drained HFCM, a few miles later, light came on again. I had to drain the HFCM 3 times, before the light stayed out. Don't know how much water was in there, but when I returned to my house, I drained into a container, all other times were just onto the ground, and I had a couple of drops, some sediment and fuel. Hasn't come on since, but I do drain periodically. I suspected I got bad fuel and I just had to run it all out.
luckeyd is offline
post #4 of 13 (permalink) Old 01-29-2008, 03:08 PM
Black05's Avatar
Continue to drain the HFCM and catch the fuel when the WIF light illuminates. As long as you can find water in the fuel, the WIF sensor is working. If you find no water and the WIF is on, then scrub the sensor inside the HFCM with carb cleaner and a toothbrush. If it still stays on, then it needs to be changed.
Black/05/F350/XLT/CC/LWB/FX4/SRW/3.73/6.0L PSD/ TorqShift/Updated TBC/Upfitter Switches/SEIC Mod/Diesel Site Coolant Filter/Fumoto Valve/ITEC HFCM Drain Plug/Bilstein Shocks/BFG A/T 28565R18/Built September of 2004
Texas Proud.
God Bless our Armed Forces.
Black05 is offline
post #5 of 13 (permalink) Old 05-28-2008, 08:29 AM
lutzgater's Avatar
Black05,
Great tip on the toothbrush cleaning approach.
My WIF was on right after I changed my filters. I drained, no water but some scale. Used your idea with carb-cleaner and a trusty toothbrush and the sensor was rather dirty with this scale buildup.
Now everything is back to normal.
Thanks again for the great tip.
Thanks in advance,
Bruce
2004 F250 6.0L SuperDuty 2WD Crew Cab Long Bed
lutzgater is offline
post #6 of 13 (permalink) Old 05-29-2008, 11:35 AM
LUP
Diagragm of water sensor
Can someone describe or show me which part needs to be cleaned? How do you get the module open?
LUP is offline
post #7 of 13 (permalink) Old 05-29-2008, 06:05 PM
lutzgater's Avatar
The approach I was referring to was simply draining the unit, then stick a toothbrush in the drain-hole and scrub, spray, scrub,spray etc...
Use a childs toothbrush since you need some room.
The WIF sensor is located next to the drain-hole, right-hand-side when looking at the drain hole.
Now, if you want to dismantle, get a shop-manual or purchase an online version, such as All-Data-DYI. They will have pictures on how to remove the front cover.
Or you can simply remove the WIF sensor, clean it, get a new O-ring, then replace.
If my light comes back on, I will remove the cover and clean the unit better.
Thanks in advance,
Bruce
post #8 of 13 (permalink) Old 05-29-2008, 06:26 PM
2003, 2004, 2005, 2006, 2007 WorkShop Manuals
http://www.motorcraftservice.com/pubs/content/~WS3O/~MUS~LEN/20/S3OLEFT.HTM
http://www.motorcraftservice.com/pubs/content/~WS4O/~MUS~LEN/20/S4OLEFT.HTM
http://www.motorcraftservice.com/pubs/content/~WS5O/~MUS~LEN/20/S5OLEFT.HTM
http://www.motorcraftservice.com/pubs/content/~WS6O/~MUS~LEN/20/S6OLEFT.HTM
http://www.motorcraftservice.com/pubs/content/~WS7O/~MUS~LEN/20/S7OLEFT.HTM
Mark
bismic is online now
post #9 of 13 (permalink) Old 05-30-2008, 09:38 AM
lutzgater's Avatar
Bismic, thanks for these links.
All:
After several days of no problems with the WIF, it is back on once again. There is no water, so I am making the assumption the sensor is bad.
I called the dealer and wanted to run this by the board to confirm what I was told. They said:
- you can purchase a replacement switch, but it requires a jumper-wire and the ECU needs to be reflashed in order for the new sensor to be effective.
After reading so many posts about problems after a reflash, I am not sure if I want to go through with this option. Please advise if anyone knows the reflash is specific for this sensor or they simply provide the latest version which may cause me other problems.
Wish I could simply find this darn switch from a Parts Store, but so far my search indicates only a Dealer-offered part, hence the upgraded switch, wire and reflash.
Thanks in advance for your response.
Bruce
Thanks in advance,
Bruce
post #10 of 13 (permalink) Old 06-02-2008, 12:51 PM
lutzgater's Avatar
Bump?
Thanks in advance,
Bruce
post #11 of 13 (permalink) Old 07-27-2008, 09:24 PM
How much fuel comes out of there?
jimmer818 is offline
post #12 of 13 (permalink) Old 08-28-2008, 08:13 AM
WIF light issue...
I have a 2003 Chevy Duramax that i purchased in april 2005. 10 minutes after picking up the vehicle the WIF light started flashing. of course the small town dealers option was to replace the fuel filter...nope didnt work. took it to a Chev dealer who replaced the sensor, took of the fuel tank, emptied the fuel, changed the filter yet again...guess what...still have the WIF light.
One mechanic spent two hours messing with the wiring harness which seemed to work temporarily...had no WIF for once month. then it was back.
anyone else had similar issues and any remedies?
Chevychick is offline
post #13 of 13 (permalink) Old 11-11-2008, 08:37 PM
any chance of getting links that are active for the above links? i used them a few days ago, but now it won't let me in.
PLEASE!!!
Diesel horns make me smoky!
2003 Excursion Limited 6.0L as stock as they come
thesixcar is offline
Similar Threads
water in fuel light/brake light 169stang Power Strokes 1994-1997 General 6 09-24-2006 06:44 PM
water in fuel light TheSandman '99 & up 7.3L Power Stroke Engine and Drivetrain 3 09-01-2006 12:16 AM
Help! Water in Fuel LIght triplethreat4597 6.0L Power Stroke Engine and Drivetrain 5 10-27-2005 06:04 PM
Water in Fuel light and trying to change bottom fuel filter clayk 6.0L Power Stroke Engine and Drivetrain 9 06-02-2005 05:35 PM
Water In Fuel Light Joe_Dirt 6.0L Power Stroke Engine and Drivetrain 12 04-12-2005 06:48 AM
