6.0L Power Stroke Engine and DrivetrainDiscussion of the 6.0L Power Stroke diesel engine and drivetrain in the 2003-Up Super-Duties and Excursions. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 6.0L Power Stroke engine.
Ok, so my water in fuel light comes on and I get around to draining it two days later. When I unscrew the plug I get about 6 ounces or so of liquid (I assume a mix of water and fuel).While I'm at it I change both fuel filters. I think this should take care of the light but after a few hours it comes back on. The next dayI drain it again and as before I get about 6-8 ounces of drainage.....hmmmm....light goes out. Whoa....next day, light is back on and I go through the same scenario all over again.
First off, should I be getting that much drainage? I don't remember getting that much on previous drains. Second, could it be that I just have a dirty sensor and if so is it is to clean? Right now the truck runs very rough at first start but after it warms up it seems to be just fine....maybe I got a tank of bad fuel ....
2003 F-350 Crew Cab 4x4 DRW 6.0 PSD Torqshift, Build date 3/21, 4.10, Black Clear coat, FX4 Pkg., DVD system, 2-7" TV's, gaming port, crimestopper remote starter, A.R.E. "Z" Series cap.
If I try to drain with more than half a tank, I can get a gallon or two out.
I didn't see in your post - do you actually have water in your fuel? Little bubbles on the bottom of the container? It is possible that your sensor has become corroded, and needs to be replaced.
OMC
Before you spend the time and money to replace the sensor you might want to try a little carb cleaner in the drain. A few years ago my light was on and wouldn't go off after draining. I stuck the straw up in the drain hole and gave it a real good flushing. All kinds of crap came out and I haven't had a problem since then. I just did it again today as I changed my filters.
2003 6.0 6 speed. 3.73 gears, 4X4 w/Camper pkg. Ordered Oct 02, Received Mar 03. 100% stock.
Make sure you are catching the drained diesel in a glass and look at it (i keep a 1qt clear bottle with a cap in the truck for this purpose). I suspect you just got a bad tank of diesel and you just need to keep draining. It happened to me and i was draining it very often (in the beginning every couple of hours and then less as time progressed). Since the light is going off then your sensor is likely ok. When they go bad the light generally stays on. Just keep draining when it goes on and after the current fuel is used up it keeps going on then look further. The 6oz drain seems about correct. Just make sure you open the tank fill cap as the pressure in the tank can cause more to drain out then necessary. The rough running may be a reason to get the latest flash. The induction flash was supposed to fix rough cold running and sometimes hard starting due to the injectors sticking. Was it flashed with in the last year?
Are there any good fuel additives that would help in this sitution?
(In case a guy was out on the road away from his tools and spare filters)
2006 F-250 XLT FX4 PSD 6.0, Born in Kentucky 10/05. 4X4 Crew, auto, 3.73, Tow Command, Dark Slate Gray, will remain stock for now.
SOLD 3/25/06: Stock 2001 PSD 4X4, Auto, 3.73, CREWCAB in RED.
*1985 F350 farm truck for plowing snow and bouncing around the woods in, leaves 2 pounds of rust on the ground every time I shut the door.
*2008 Polaris Sportsman 500 HO X2
*1968 Shelby GT-500, 428 CJ
Where did you spray the carb cleaner in from, the drain plug hole or unscrew the filter and sray it in there?
Thru the drain plug hole. You just have to work aroud the front drive shaft the best you can. As was later stated, your sensor is probably OK since the light does go out, but I don't think you have anything to lose in cleaning out the sensor area. Just my dos pesos.
No flashes ever on this truck.......I had run that tank of fuel down to about 1/4 tank then refueled and put in some diesel fuel supplement....hopefully it clears up soon, this is getting old.
