water in fuel lite - Diesel Forum - TheDieselStop.com
Old 02-19-2009, 06:22 AM   #1 (permalink)
water in fuel lite
this is for a friend so here goes. its a 06 that has a persistant wif lite come on, changed filters, ran fuel low, got fuel from diff. stations, put additive in fuel but water in fuel lite keeps coming on any suggestions.
firman is offline
Old 02-19-2009, 10:56 AM   #2 (permalink)
What year is the truck? This is a known "problem" where the sensor gets dirty or corroded and needs to be replaced. It's about $100 for the parts & time.
You might try removing the drain plug & shooting some carb cleaner in there & brushing it out with an acid brush. If you need to replace it, you'll need a new pig tail connector & gasket for the cover plate as well.
I'd also suggest that he get the IH replacement plug & check the HFCM on a regular basis (once a month or every other tank).
OMC
Depending you year & millage, it could be covered under warranty.
OMCUSNR is offline
Old 03-06-2009, 03:29 PM   #3 (permalink)
69mach1377's Avatar
What year does it apply to? My dad's truck may have it...
2000 F250 4x4 SC 7.3 w/Auto Tranny w/ TC L/U Sw & shift kit, Fully gaged, Cold air intake mods beyond zoodad, Stacked tuners, 4" Exhaust w/dual 3.5" outlets, 295/75/16 BFG ATs on 8" rims, 08 AlumDiffCvr, Bilsteins, otherwise mostly stock.
24' 5th wheel camping trailer, no RV parks...just the woods.
2005 VW Passat 2.0 TDI, 40+ mpg hiway
1969 Mustang Mach1 HotWheel, 377 clevor, R&P steering, 3.50 posi, 2003 Mach1 Wheels (17s)
69mach1377 is offline
Old 03-20-2009, 01:53 PM   #4 (permalink)
69mach1377's Avatar
Anybody?
Old 03-20-2009, 08:02 PM   #5 (permalink)
Originally Posted by 69mach1377 View Post
Anybody?
It applies to all years - it just depends on whether you're still in warranty of not.
OMC
OMCUSNR is offline
Old 03-20-2009, 11:52 PM   #6 (permalink)
OT
OT's Avatar
Fir...more info. 6.0 PowerStroke bulletins Scroll down to WIFL illuminated. Im thinking pulling apart..inspect/clean etc. would eliminate guessing. Good luck!
03 F250 XLT SC/SB 4X4 6L (stock) A/T. SRW 3.73's BD:02/11/03. 01 TL 23' SGII
OT is offline
