Water in fuel sensor...fault? - Diesel Forum - TheDieselStop.com
Old 07-27-2006, 05:13 PM   #1 (permalink)
jonrjen's Avatar
I have been having a problem with a 30amp fuse blowing for awhile. This fuse controls the gauges, tow/haul, AIC, 4x4 engagement. Dealer has attempted to fix the problem 3 times now, the last fix was to replace the entire gauge cluster.
But now I am having a problem with the water in fuel light coming on after about 4 minutes of run time. I have drained the water/fuel drain 5 times now. The first time there was a very small amount of water/moisture present, the following 4 times there has been no sign of water/moisture present. I am draining the fuel into a glass jar and can see no seperation of fuel and water present.
Has anyone had or know of a problem of faulty sensors in the separator.
I have tried switching tanks (I have dual tanks) and the problem exist with both tanks, (which were not purshased from the same fuel stop).
Any Ideas
2008 F-550 Regency Conversion Hauler 6.4 PSD
2006 Ford F-250 XL V-10 6-Speed
2006 Ford F-150 Crew Cab XLT
2005 Lincoln LS Sport
1977 F-600 Cab-Chassis V-8 4-Speed 2 Speed rear
1997 Travel Supreme 40' triple slide 5th wheel
38 +or- head of Texas Longhorn Cattle..."REAL COWS Have HORNS"
jonrjen is offline   Reply With Quote
Old 07-27-2006, 06:07 PM   #2 (permalink)
Re: Water in fuel sensor...fault?
There is a known issue with the early water in fuel (WIF) sensors. I was having the same problem as you in our 2004 - no contaminants in the drained fuel, but the WIF light was on. The sensor was replaced, and when the problem recurred the fuel pump was replaced.
Joshua
CoralDoc is offline   Reply With Quote
Old 07-27-2006, 08:51 PM   #3 (permalink)
I had an early 2003 X and sensor was bad. There is a update sensor available and I would have this replaced and see if that is your issue.
RoyC
2005 Limited, 6.0L PSD, 4X2, Mineral Gray, 3.73 LS. Excursion Build date 02-08-05 6.0L 2005MY Engine Build date 01-03-05 Huntsville, Ala.
2005 50th anniversary Thunderbird Red with all
options except hardtop.
Old Ride: 2003 Excursion 6.0 L March 2003 Build 73,000 with no significant issues.
RoyC is offline   Reply With Quote
Old 07-28-2006, 05:17 AM   #4 (permalink)
jonrjen's Avatar
I guess I will run it into the shop and let the warranty take care of it. Mine is also an early 2003 model run, been very dependable up till this last few weeks............of course I guess that is because the 36/36 warranty is 5,000 miles from running out.
Old 07-28-2006, 05:44 AM   #5 (permalink)
What is happening, is that the water sensor
has become gummed up. On the 6.0 the fuel
pump, water seperator, fuel filter, and fuel
heater are all built into one unit. I have
two friends that had this problem. Add some
type of fuel conditioner in every tank fuel.
This will keep things clean.
Herb
2002F250 <font color="red"> RED </font>Lariat, CC, 7.3L PSD, AMSOIL 5W-30HDD, Amsoil ATF, Rear Differential, Dual-Bypass Oil Filter, DI Prepump & Tank Mod, DI H/X Mod, DI Fuel Regualtor, New DI Four Positon Chip, Autometer Phantom 3-Pillar, 30 micron Dahl100 filter, AIS Air Filter, Magnaflow XL 4" turbo back exhaust w/ 5" tip, Baldwin Coolant Filter, Magnifine Trans Filter, Racor CCV4500, Sonnax Accumulator Valve/Tricumulator Spring, ISSPRO Turbo Temp Monitor, Optima Yellow Tops, V10 Trans Cooler, AirLift Air Bags,B20 Biodiesel.
Performance by Diesel Innovations
Snow White Supporter
2002BigRed is offline   Reply With Quote
Old 07-28-2006, 06:26 PM   #6 (permalink)
jonrjen's Avatar
BINGO.........Dealer said the fuel manifold was defective. Fuel maifold is the expensive name for the water/fuel/heater/filter housing.
Thanks to all that replied.
Jon
Old 07-29-2006, 03:15 PM   #7 (permalink)
Send a message via AIM to PaCeMaKeR
did you get the updated version with out the heater and new wire harness?
2002 PSD modded " tow rig"
92 Dodge Cummins
86 Buick Grand National
PaCeMaKeR is offline   Reply With Quote
Old 07-31-2006, 03:07 PM   #8 (permalink)
jonrjen's Avatar
It was indeed the new set up that was installed, at least via the part numbers on the invoice.
