Water pump replacement? - Diesel Forum - TheDieselStop.com
Old 08-16-2006, 09:27 PM   #1 (permalink)
I'm anew diesel owner, learning on the go. My recently purchased 04' 6.0 has a coolant leak I believe is the waterpump. I can't find any service manuals for my truck. Was wandering if anyone knows of where to get the info. for the simplest way for me to install a waterpump? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
04',F250,6.0,PSD,Offroad,CC,SB,auto,3.73,lariat,mo onroof,wedgewood blue metalic,6"procomp lift,36x14.5-16 interco trxus sts,16x12 weld racing forged beadlock,K&N,Edge w/Attitude,Grilleguard,Custom A.R.E. topper,line-X liner,Wheel-wheel nerf bars,Bushwhacker pocket style flares,tail light covers,100 watt back-up lights,Sirius tuner.
04supercrew60 is offline
Old 08-17-2006, 12:16 AM   #2 (permalink)
FamilyRide's Avatar
Re: Water pump replacement?
Not sure what the poll is for, but eBay usually has toms of service manuals. Otherwise, your dealer can get them I would imagine.
You might want to provide some more info too. Other may have better insight, but I haven't heard of 6.0 water pump issues.
2004 EB Excursion, 4x4, 6.0, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto, V code front springs, Revo 285's and bubba lights
FamilyRide is offline
Old 08-17-2006, 09:20 AM   #3 (permalink)
My Photos: (5)
It's exceedingly rare for a 6L w/p to go away. I'd be curious as to what makes you think that's the culprit.
AutoJim
Former Cooling Guy
'99.5 F350 Lariat CC SRW 4x2, 7.3L 4R100
'99 Mustang Cobra, SCCA Solo2 E Street Prepared
'97 Dodge Neon, SCCA ITA/STU/EP Club Racing
Now I do subsea ROV tooling.
AutoJim is offline
Old 08-18-2006, 08:21 PM   #4 (permalink)
After searching some more I'm not sure it is the waterpump. I'm loosing coolant somewhere on the front of the engine. It's leaking from somewhere in the area of the thermostat housing. But not coming from the thermostat housing or an radiator hose that I can see. I took the air filter box out and still can't find it. Any ideas before I break down and take it to Ford?
Old 08-18-2006, 10:31 PM   #5 (permalink)
make double sure its not leaking from the band clamp at the thermostat housing & check all the other yoo. if someone in the past has removed the hose for any reason the clamp must be put back in the same position or it will leak. maybe not w/o pressure but will leak under pressure. usually when i get one in w/ problem i replace it w/ a worm clamp as specified by our ford engineers. there is a special service message about this on our site. they tend to break into.
certified ford dealer 7.3L,6.0L & 6.4L diesel tech & foreman
dvtech is offline
Old 08-21-2006, 11:45 AM   #6 (permalink)
My Photos: (5)
Check the EGR cooler hoses.
AutoJim
Former Cooling Guy
AutoJim is offline
Old 08-23-2006, 09:35 PM   #7 (permalink)
Thanks for the help, I took the thermostat out to check if working properly. So the leak up front was the clamp at the housing. But problems aren't over the trucks been loosing coolant out the overflow resevoir, replaced cap inhopes of fixing. No luck, believe I've probably experienced first head gasket problem. Bought truck used w/edge already installed, believe I've inherited anothers problems. Thought I was getting a good deal, obviously thinking not my strong point. Live and learn!!!
Old 08-23-2006, 09:45 PM   #8 (permalink)
Has your truck had the coolant bottle recall done? There should be a sticker on the coolant degas bottle that indicates a different level than what is molded into the bottle. If not, just fill the degas bottle to the minimum level only.
And, yes, you might have inherited someone else's problems. I hope not.
2005 Arizona Beige F350 XLT FX4 6.0 CC shortbed, 3.73 ls rear, 18" wheels, Tow Command. Additions: Vent Visors, bug guard, Fumoto Valve, Timbrens. Traded for...
Current Truck -- 2008 Black F350 XLT 4x4, 6.8 V10, CC Long Bed, 4.10 rear, 18" wheels, IBC. Additions: Chrome Step Bars, Chrome door handles, Silver barbed-wire pin stripe, B&W Turnover GN ball
barrelhorses is offline
