water seperator drain plug - Diesel Forum - TheDieselStop.com
Old 03-04-2005, 07:54 PM   #1 (permalink)
Water in fuel light is flashing when I turn corners, so i decided to claw under her and loosen the plug and drain it. I put the 6mm hex wrench in the slot and with very little torq of my hand the threads stripped out????? I'd liked to get ahold of the so called engineer who came up with the 6mm hex wrench design and were they thought it was a convient location for draining. HA HA.... This is like the 4th time it has been drained all by me. I called the parts deptment and asked for a plug thinking I'd somehow get this one out. Parts guy told me he'd have to order a plug, but would order a new pump/ filter assembly as the tech might not get the plug out, and he would have the s.ad. write it up under warrenty as it is in a terrible location and not very accesible for the less then 3 minutes it should take to drain it. Anybody else have any problems with the stupid plug design?? Ford has some great engineers, and some great dipstick engineers we pay good money to.
25,524 miles and would not give her up, although the little problems. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
'03 Red F-350 Crew 4x4 6.0L Torqshift 3.73 axle 156" wheelbase FX4 package,well everything but leather!!!!!!!
Pullin' a 32' Forest River Fiver #7500 dry
PER DSB, REPLACED ALL INJECTOR SEALS,UPDATED PCM, AND FILLED OIL TO PROPER LEVEL!!!!!!!!!
david875 is offline
Old 03-04-2005, 08:09 PM   #2 (permalink)
dbennett48's Avatar
Re: water seperator drain plug
Yes this has been around before. Ford now makes a steel plug so you can't strip it. I never stripped mine, but I bought a steel plug in case. $7.00 I think.
Dave
2004 F-350. Standard Cab, 4X4, 6.0 with Torqshift, 3.73 w/LS. <font color="red">(((XM))) Satellite Radio.</font> Lo Jack, 6608 lbs wet. Born on 8/4/2003. Engine 07/23/2003. 3" Lift. Grover Air Horns!!!
http://community.webshots.com/album/85108545NlXNsD
1993 F-350 4X4 7.3 IDI with 5 spd. Gone now.
1976 Kenworth C-500 with Detroit Diesel 8V92TA with 3 spd Jake, SQHD's and RTO 12513 10 Wheel Dump Truck. Sold.
dbennett48 is offline
Old 03-04-2005, 08:16 PM   #3 (permalink)
Thanks for the info. i'll check into the steel for sure when i go get this one fixed. What a terrible design.
david875 is offline
Old 03-04-2005, 08:17 PM   #4 (permalink)
dbennett48's Avatar
Almost as bad of a design as the black dip stick. A first prize winner.
Dave [img]/ubbthreads/images/graemlins/grin.gif[/img] [img]/ubbthreads/images/graemlins/grin.gif[/img] [img]/ubbthreads/images/graemlins/grin.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Old 03-04-2005, 08:22 PM   #5 (permalink)
Right on, you caught my drift. Still would'nt get rid of her [img]/ubbthreads/images/graemlins/smirk.gif[/img] [img]/ubbthreads/images/graemlins/smirk.gif[/img]
david875 is offline
Old 03-06-2005, 01:47 AM   #6 (permalink)
Anybody have the part number for the steel plug?
2003 F-350 Lariat, dob 3/6/03, 6.0L auto, CC, 4x2, SRW, LB, white/parchment, 3.73LS, capt seats, 6CD, adj pedals, chrome steps, roof lights, heated TT mirrors, reverse sensors, Line-X, X-Monitor, Pullrite hitch, Prodigy controller, Ride-rite air bags, tool box, mud flaps, wheel well skirts.
2003 Carriage Cameo LXI F34CK3 5th wheel, triple slides, fireplace, 2 A/C, R21 insulation, Mor-Ryde suspension, Honda EU2000i generator, Motosat Datastorm mobile satellite Internet/TV receiver, Trailair pin box.
dminz is offline
Old 03-06-2005, 02:50 AM   #7 (permalink)
Come on Dave.... You don't like trying to read the oil on the black dip stick. [img]/ubbthreads/images/graemlins/phoney.gif[/img]
2003 PSD 6.0 SRW Supercab Short Bed 4X4, Sonic Blue, Engine Build Date: 12/02. October 2003
Flash.
Truck Pics
1999 F150 Lightning, K&N Filter, Amsoil 5W30, 16,000 Miles.
oc788 is offline
Old 03-06-2005, 07:24 AM   #8 (permalink)
I don't let it drain totally down figuring any water will be at the bottom. I usually drain when the water symbol goes on in turns or hard braking, 3 times in 20,000 miles. I thought I was the only one too blind to read that stupid black dip stick I use a white paper towel to see where the oil is. Dumb!
2003 White F-350 Lariat Crew Cab: 6.0PS Torqueshift w/PTO, 8'bed Reese signature 5th wheel hitch, Reese Front Hitch, Peragon cover, trac racks, Thule tracks on cab. Traded in 3/06 Pulling a triple slide HR Alumascape.
2006 White F-350 Lariat Crew Cab: 6.0 PS, signature 5th wheel hitch,Jimmy the Welder cooler rack, Peragon cover, Beach Vehicle in Development
Shag is offline
Old 03-06-2005, 10:34 AM   #9 (permalink)
I'm definetly telling them i want the steel plug when it goes in to get the stripped one out, or the whole assembly gets get changed out. It's be on me why they would use a brass threaded plug with a hex wrench, when they know it will be removed from time to time. I think its another way they knew it would keep money rollin' in!!!!!!!!!!!!!! [img]/ubbthreads/images/graemlins/rolleyes.gif[/img] [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
david875 is offline
Old 03-06-2005, 10:47 AM   #10 (permalink)
dbennett48's Avatar
The Ford part number for the steel plug with o-ring is: 3C3Z-9A214-AB and it is called "One Adaptor". If I recall correctly it is about $7 or $8. Mine was ordered and took a few days.
Old 03-06-2005, 10:49 AM   #11 (permalink)
dbennett48's Avatar
I would not know, mine came with the gray one. I'll bet is is as hard as I have read. Does the word "impossible" ring a bell??
Dave
Old 03-06-2005, 11:50 AM   #12 (permalink)
Dave B.
Thanks for the part #. I'll take it and get with the parts guy and see if he even knows about it, my guess is he does'nt since he hasn't said anything to me about it.
What a farse [img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/shrug.gif[/img]
david875 is offline
Old 03-06-2005, 04:02 PM   #13 (permalink)
dbennett48's Avatar
Good luck on your parts search. I have found that the parts people don't know Jack. I know Jack, and I tell them.
Dave
Old 03-08-2005, 08:30 PM   #14 (permalink)
Daveben
When and took truck in today for the stripped plug. dealer told me they have 2 on hand at all times because of the problem with the stripping of the plug. Anyway they told me that they have to change the whole unit out per ford motor company, and they did. New unit is the updated verison i was told, and yes it looks different and the drain plug has deeper threads. of course I had no problems with them changing it out. I was wrote up at 8:50 and back on the road at 9:35. [img]/ubbthreads/images/graemlins/smile.gif[/img] [img]/ubbthreads/images/graemlins/smile.gif[/img] [img]/ubbthreads/images/graemlins/smile.gif[/img]
Yes the parts guy had no clue on the steel plug either, no surprise like you said. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
david875 is offline
Old 03-08-2005, 09:16 PM   #15 (permalink)
I would go ahead and take the original brass plug out and install the new steel unit as soon as possible. When I stripped the brass plug, I had to remove the entire pump unit, disassemble it, and attempt to drill the old plug out.Unfortunately, it was frozen in there pretty good and had to purchase a new drain plug cover plate anyway.
Anthony
2003 F-350 SRW 6.0L Supercab Longbed
FormulaOne is offline
