Are we out of the woods???? - Diesel Forum - TheDieselStop.com
Old 08-14-2006, 07:02 PM   #1 (permalink)
It has been sometime since I have been on this message board, but I do have a quick question. How many of you guys are having problems with your 07's? I figured 4 years is enough time for Ford to get there heads out of there asses, but hey you never know. Or on the other hand praise your truck if you don't have problems. I would like to hear both sides. The only reason Im concerned is I had an 03 and it was a pile. Don't want to have to go down that path again gents. TIA!!!!
2007 Ford F-250 Lariat, Extended cab, Single SS 4" MBRP w/ Cat delete pipe, Triple Pillar, Boost, Pyro, Trans, and more to come!!!
honkey84 is offline
Old 08-14-2006, 07:25 PM   #2 (permalink)
VS06SD's Avatar
Re: Are we out of the woods????
I have 2 '06's and so far...(knock on wood)...So good!
06 F350 6.0 Lariet Crew Cab DRW FX4
06 F350 6.0 XL Reg Cab DRW 4X2
06 Fusion SEL
09 Eagle 314BHDS TT
94 Explorer XLT 4X4
VS06SD is offline
Old 08-14-2006, 08:13 PM   #3 (permalink)
Well your signature shows you already have an 07 but your text sounds like you're trying to find out if you should get another PSD or not?
If you already have an 07 it's kinda late to "protect yourself from going down that path again".
I have an 05 that's been flawless so far.
05 F-350, PSD, 4x4, Crew Cab,6-Speed
2" Front Level Kit, Pro Comp ES9000 Shocks
Firestone Model 2400 Airbags (horrid engineering)
Tow 30' Toyhauler
*-Friends don't let Friends run Crap-lisle Trailer Tires
Rich807 is offline
Old 08-14-2006, 09:15 PM   #4 (permalink)
05 48,000 miles & 06 23,000 miles 6.0s and no problems to speak of!!
2001 White Lariat 7.3 Auto CC LB 4X4 -- Mods -- K&N Drop in, DP Tuner, 6.0 IC mod, 4" Magnaflow Exhaust, BTS Tranny, 3 gauge A piller pod. Kennesaw Mountain Accessories Rear and Front “Wincher” Bumper, Warn 16.5Ti Winch, Suspension: Tuff Country 2" front and 3" rear, Toyo MTs 305s on 10s, 310,000 miles!!
05 White XL 6.0 Reg Cab 4X4 140,500 miles!! (That has never seen the inside of a Garage)
06 White 6.0 CC Lariat 4X4 Auto LB: Kennesaw Mountain Accessories Front “Wincher” Bumper, Warn 16.5Ti Winch, Fabtech 8" lift, 35 Toyo M/Ts 125,651 miles!!
---07 Shelby GT500--- Performance White Vert-- Mods-- JLT Intake, 2.6" upper & 10% IW Lower Pulleys, AFCO Duel Pass Heat Ext., American Racing Long Tube Headders, Full 3" Magnaflow Exhaust, Evolution Stage 4 Tune, BMR Carbon Fiber Drive Shaft, Steeda UCA & LCAs Currie 9" 1:3:75s True-Trac locker, Proglass Cold Air Hood, 36,500 miles---11.491 1/4 mile! 592RWHP
mobeydick is offline
Old 08-14-2006, 09:28 PM   #5 (permalink)
No, I'm not getting a different truck just wondering what you guys have had go on with your trucks. You always hear the horror stories and so forth, but just wondering what the up side of it all has been. I made the mistake of buy a first year ford, and trust me I will NEVER do that again. Thanks guys and keep it coming!!!!
honkey84 is offline
Old 08-14-2006, 09:37 PM   #6 (permalink)
I hope so cause I just made the deal today on a '07 F550 4x4. I thought I better get one of the last 6.0's before all the new motor problems start. Man these trucks are hard to find and the dealers know what they got. They told me that if I ordered an '07 it would likely be bumped to an '08. Yikes!!!!!!!! So I had to settle for a white one. I swear 99% of these are white. I hope there aren't any problems. Eric
2008 Chev 2500HD CC SB LTZ 4X4 Duramax/Allison, dual alternators, B&W Turnover ball w/ Companion, 8'2" Boss V-plow, Timbrens
SOLD----2002 F350 CC SB, 4x4, Lariat, leveling kit, 285 BFG's, AIS w/ fender sleeve, AIC, A-pillar Pyro, Boost, Trans, SCMT, 4" Magnaflow turbo-back, AIH delete, Weatherguard toolbox, 8'2" Boss V-plow, Hide-a-way strobes, B & W Turnover Ball and Fifth Wheel Companion, Fumoto, 203* Stat, Bilsteins, XM, C-Betrs, 136,000 miles,Hella 500's up front, Hella flush mount back-up lights, Speed Bleeders, Air Lift rear bags w/ inside controller
Pulling this:
2005 Alumascape 35 FLQ by Holiday Rambler w/ 5 slides
2007 F550 4x4 XLT, 11' contractor dump box, dual alternators, Tow Command, Upfitters, C-Betrs, #19000 GVW, Fumoto, 9'2" Boss V-Plow, 8' V-box salt/sander, LED flashers
prograde is offline
Old 08-14-2006, 09:49 PM   #7 (permalink)
I'm a proud owner an '03 KR. I have 51K on it. So far it's been in the shop twice. 1st time to replaced the hydraulic brake booster and 2nd time have the most recent flash. For some reason whenever they reflashed it the #2 injector would not respond. They ended up replacing it. Both items were covered under warranty. So far, knock on wood everything seems to be running fine. I was running a BD powerpup in the beginning just for economy. But later decided to set it back to stock. I was paranoid about the dealer voiding my warranty. That was probably 10K ago. I'm averaging 17.5 mpg in the city.
2003 F250 6.0 4x4 King Ranch Crew
96K So Far
Sinister EGR delete with up pipe
Sinister coolant filter
Pure Diesel CAT delete
Mile Marker manual hubs
Procoat liner
Husky mats
Fumoto valve
International HFCM plug
Dieselkleen additive
Service repairs:
Dealer replaced hydraulic brake booster
Dealer replaced rear seal
Dealer replaced #2 injector
Dealer loaded 0617 flash
Dealer replaced ICP
jeffery712 is offline
Old 08-14-2006, 09:54 PM   #8 (permalink)
Re "I'm averaging 17.5 mpg in the city."
Do you have a 2wd? I cannot imagine you getting that with 4wd.
If I use eggshells under the accelerator pedal I am lucky to get 17 on back country roads...
Truck Build Date: 03/05 Kentucky
Engine Build Date: 02/28/05 Indianopolis
Purchase Date: 8/05 Sold date: 01/31/07
MPG: 16.08 2007 ytd average; 29k miles
2005 F 250 PSD Crew Cab Long Bed XL Auto
Completely Stock Truck: No Modifications
15 days in shop; a factor in deciding to sell.
05F250PS is offline
Old 08-14-2006, 10:20 PM   #9 (permalink)
17.5 mpg city everyday. I commute round trip to work and back 50 miles daily. Usually 70-80 mph on the interstate. Half of my commute consist of stop and go back roads.I'm running stock tires (265's). No lift. Diesel Kleen additive.
96K So Far
Procoat liner
Husky mats
Fumoto valve
Service repairs:
Dealer replaced ICP
Old 08-14-2006, 10:32 PM   #10 (permalink)
Oh yea, forgot to mention that it's 4 wheel drive.
96K So Far
Procoat liner
Husky mats
Fumoto valve
Service repairs:
Dealer replaced ICP
Old 08-14-2006, 11:04 PM   #11 (permalink)
TexasTruck's Avatar
My Photos: (13)
Congrats on the new 07! Honestly, I think the 06/07's are pretty darn good.
That said, out the door, mine had severe steering wheel sawing action over bumps and pot-holes. My dealer tried and tried to correct it, no luck.
Now, I have an 07 that I've come to realize that has a shudder at 3000-3200 RPM, every time, slow or hard acceleration, and a singing (resonating) muffler around 1200-1400 RPM every time...
Seriously, the truck is awesome, I can only hope when I reach 500+ miles and I go to tow my boat, the shudder isn't what I think it is (torque converted).
Scott
2008 Silver F250 FX4 6.4
ICON / OUO / Line X / Viair / Air Horns / BMF / Toyo / GOS harness / Custom Driveline
"A problem is an opportunity in work clothes"
TexasTruck is offline
Old 08-14-2006, 11:21 PM   #12 (permalink)
I'm debating trying Ford again, but concerned on the same note. I need to add a third truck to my fleet as our 05 Chevy Duramax caught fire and burned to the ground. My other two trucks are both HPCR Dodges (an 04.5 and an 05).
My biggest concern is the long term durability of the truck as we seriously rack up the miles (my 04.5 has 260k, the 05 has 115k and our 05 D-max has 165k when it went up).
I had an 00 PSD that I traded on my Dodge and miss the Crew Cab configuration. Do the new(er) 6.0's hold up better? I really like the overall truck but am still nervous about the engine.
2006 Job 2 F-350 Crew cab King Ranch single wheel 4x4 92k
2007 Dodge 3500 6.7 4x4 14k
Former diesels: 91 D250, 93 D350, 95 F350 PSD, 96 Dodge 3500, 2000 F350, 05 D-max: Fire, 2004.5 Dodge 3500, 2005 Dodge 3500
TXGooseneck is offline
Old 08-15-2006, 07:32 AM   #13 (permalink)
You drive dodges and you think they last a long time!!
Old 08-15-2006, 08:58 AM   #14 (permalink)
[img]/ubbthreads/images/graemlins/rolleyes.gif[/img] My trucks are holding up fine under daily abuse. I am asking if Ford has their diesel where it is once again reliable.
But Great Post! [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
Old 08-15-2006, 11:17 AM   #15 (permalink)
I'm not sure I follow you-are you saying they don't last a long time, or that they DO last a long time? In any case, I can't say I have a dodge with a huge amount of mileage-my '98 only has 265k on it.
1998 Dodge 12v 5 spd 2wd dually, 275k on truck, bhaf, CPP 7x10 injectors, timing at 19 deg, 3k gsk, no fuel plate, htb2 64-13 turbo with stainless exh housing, wastegate set at 50 psi, southbend dual disk clutch, detroit locker, has broken 2 stock dana 80 limited slip units, has run 14.65 at 98 granny shifting the 5 spd, dynoed at 450 hp and 906 ft/lbs on REALLY STINGY dyno
v8440 is offline
