Weird bump after take off??? - Diesel Forum - TheDieselStop.com
Old 05-10-2010, 08:47 PM   #1 (permalink)
When I come to a complete stop after i let off of the brake and gas it to take off.I get what feels like i am rolling over a bump in the road.I fell it in the truck.Checked the drive shaft it seams to be tight along with the u joints.Any ideas what it might be?? Thanks The truck in my sig.
2006 4x4 larait full Silverline Exhaust Air Raid air intake 6in Pro Comp lift 37in Pro Comp Tires 20in Pro Comp Wheels
avm112 is offline
Old 05-10-2010, 09:01 PM   #2 (permalink)
paintingman's Avatar
You can feel it between the time you take your foot from the Barack to the gas pedal before even start to roll. Mine did something similar under warranty ford replaced the drive shaft. I read a thread here of some one with the same problem putting a grease fitting some how on the center bearing and it helped his problem.
_________________________
2004 F250 6.0 PSD every day work truck
Jotto desk / laptop / printer for giving estimates
3000 watt inverter keeps drill batteries charged
4" tubo back MBRP cool duals
CFM+ intake elbow / Airaid cold air intake
SCT X3 from innovative diesel
Coolant Filter / Amsoil by-pass system
ATS Intercooler
Fluidampr / 200 amp alternator
ARP head bolts / Black onyx head gaskets
185cc Injectors 70hp+ / stock turbo
stage 1 fuel lines / cross over with fixed orifice
58 volt FIMC mod from swamps diesel
Airdog 2 with in tank fuel module upgrade Mag-Hytec Diff. and trans. covers
Aluminum degas tank
paintingman is offline
Old 05-11-2010, 12:29 PM   #3 (permalink)
tvandyck7's Avatar
Your slip jont needs to be greased, that's all. You have to take your driveshaft off and remove the clamp from the rubber boot and grease the spline shaft. It needs to be done every 15k or so. Just remember to mark the original orientation of your driveshaft and slip yoke before taking it apart so that you don't throw it off balance.
2009 F-250 6.4L PSD CC SB Lariat Ultimate FX4, 3.73LS
Mod List:
-51 gal RDS direct fill auxillary fuel tank
-SEIC High Idle
-H&S Black Maxx Running the Hot Damn +300 Tune
-S&B Dry CAI
-Diamond Eye 5" Turbo Back Race Exhaust
-Custom 10" Sub Box Behind the Center Console
-Coastaltech SYNC-LP1 Lockpick
-Westin Bull Bar
-Westin Taillight Guards
-Recon LED Smoked Dodge Cab Marker/Clearance Lights
-Billet Fender Vent Inserts
-Zone Offroad 4" Lift
-20x10 BMF Novakane 8's
-35x12.50r20 Nitto Trail Grapplers
-'11 Super Duty Rear Seat Cargo Tray w/410W Power Inverter
tvandyck7 is offline
Old 05-18-2010, 09:17 PM   #4 (permalink)
stitch89's Avatar
My f-350 does the exact same thing. I had the carrier bearing replaced and had the ford guys check the backlash in the rear diff. Its a mystery to me. PLEASE....... let me know what it is if you find out. Thanks ......
stitch89 is offline
Old 05-18-2010, 09:39 PM   #5 (permalink)
F250crazy's Avatar
Stitch 89 lube your slip yoke on your driveshaft. Easy fix. Cut clamp on little boot and pull shaft apart. Clean splines and use some bearing grease. I zip tied boot on and problem is gone.
F250crazy is offline
