Old 10-20-2009, 10:48 AM   #1 (permalink)
Weird Smell
Howdy Folks,
Here's the story. This summer my Engine overheated during a bumper to bumper crawl on the highway. Pulled over as soon as I could, it puked a little and I let it cool down. Problem was the fan did not come on. Took it to Ford, got an oil change and flush and fill with the new improved GOLD priced coolant. Engine runs much better, still gets up in OIL temps on long hills (220 to 230 degrees). No smoke, no fluid losses BUT I detect a burnt oil or exhaust smell after the engine is fully warmed and the heater fan is on. I see no drips, no oil on the exhaust pipes - just the weird smell, kinda like exhaust and tranny oil - but again - no loss of fluids. I have the Bully Dog PMT for guages - set on tow performance - nothing higher. Mileage is 240K KM's, all new injectors last spring.
What to check next? Thanks All.
2006 F350 Dually 6.0L Tommy Gate Lo0oking for heated seats !
rcgreg is offline
Old 10-20-2009, 12:31 PM   #2 (permalink)
Thumbs down
Have you considered power washing all the areas around where the spill was? Any fluids, oils and etc left in a nook or crany some place could continue to "cook" and cause weird smells for quite a while. My '93 plow truck started smelling better, now that the dead mice that nested in the muffler have finally been completely incinerated!
That was a smell I just could not get used to.
2006 F-250 XLT FX4 PSD 6.0, Born in Kentucky 10/05. 4X4 Crew, auto, 3.73, Tow Command, Dark Slate Gray, will remain stock for now.
*1993 F250 w/ Fischer Plow, farm truck.
*2008 Polaris Sportsman 500 HO X2
*1968 Shelby GT-500, 428 CJ
* 1988 Mustang GT Convertable
DizzyD is offline
Old 10-21-2009, 08:03 AM   #3 (permalink)
Good Point! - I'll do that - also I had them pressure test the cooling system when they did the flush and they reported it held pressure with no loss.
rcgreg is offline
Old 10-21-2009, 11:40 AM   #4 (permalink)
teamroper60's Avatar
If your fan doesn't kick on, I would be looking at that further. IIRC, only the Ford IDS has the ability to command it on though, so a trip to the dealer would be required.
2003 Toreador Red/Arizona Beige CC, DRW, Lariat, FX4, 6.0 PSD, Torqshift, born early Feb. 03, AIC, MBRP turbo-back exhaust, Tuning by Tony Wildman (Total Diesel Performance), ARP studs & some "other" work done by River City Diesel, AFE PG7, Fumoto valve, B&W hitch, Di-Pricol gauges, Voyager brake controller, DIESELSITE Coolant filter, Timbrens, Rancho RSXs, Michelin XPS Traction's, a whole bunch of "bling", Connex 4300hp, JL Audio 275w amp w/ 12" sub, Alpine door and rear seat speakers.
pics
#43
SLAPS President and Webmaster
teamroper60 is offline
Old 10-22-2009, 07:52 AM   #5 (permalink)
Yup - they fixed that when they did the flush & fill, it comes on much sooner now and really drops the coolant temps, the oil temps follow that a little more slowly.
rcgreg is offline
Old 10-22-2009, 09:16 PM   #6 (permalink)
Got the same smell
I got the same smell after my engine was pulled for a bed plate repair. Did you ever find what was causing your smell. I would like to know if and when you do so I can use your information.
scbrown74 is offline
Old 10-27-2009, 09:07 AM   #7 (permalink)
rcgreg,
Was you able to locate anything on your problem?
Old 10-28-2009, 08:05 AM   #8 (permalink)
Originally Posted by scbrown74 View Post
rcgreg,
Not yet - going to have the engine shampooed this weekend and that wil eliminate - I hope - the possibility that it was spilled liquid caught in some valley some place. I'll let you know - but with my luck .................
rcgreg is offline
Old 10-28-2009, 03:06 PM   #9 (permalink)
Not yet, taking my truck to the dealer on Monday (10-02-09) to get it looked at. Let me know if you find the source of your problem and I will do the same.
Old 11-02-2009, 11:34 AM   #10 (permalink)
Took my truck to the dealer today. I will let you know what they find.
Old 11-08-2009, 06:05 AM   #11 (permalink)
Well I don't have anything to add. The dealer kept my truck for a week and also noticed the oil type smell coming from the air vents. They also noticed you would get the smell when the truck was stoped like at a stop sign or a stop light. They could not find the cause of the smell. Everything was dry and no oil leaks or exhaust leaks. Anybody have any ideas?
Old 11-09-2009, 09:53 AM   #12 (permalink)
Shampooed the engine - now I get a Nice shampoo smell - along with Exhaust smell - Guess I should have used Glade air freshner on it. So now it's off to the dealer so they can tell me which fuse turns on the tail/side lights that crapped out.
rcgreg is offline
Old 11-16-2009, 10:01 AM   #13 (permalink)
Results from Dealer check
Loose bolts on exhaust manifold tightened, Turbo clamp leaked at full load - tightened.
Smell pretty much gone - some residual I expect will fade away in a short time.
rcgreg is offline
