Well, I joined the club... - Diesel Forum - TheDieselStop.com
Old 05-18-2005, 02:59 AM   #1 (permalink)
My truck went to the dealer for the first time with 10k+ miles. Over the weekend I felt it stumble a couple of times at idle. Then the check engine light came on. Went out after a while, then back on. I also noticed a couple of times the idle got loud then quiet.
Took it in and had them fix a minor under-hood oil leak while I was there as well. No hassle, replaced the EGR pressure sensor and EBP sensor, I think reflashed as well (can't read the numbers on sticker - looks like a CA, I assume for California). Also replaced the plastic turbo tube and several o-rings inculding the one on the highpressure oil pump.
Good news is, they say I am not involved with the trans recall (they are scheduling those out through August). Truck seems more quiet then before, power seems fine. Of course I haven't towed with it yet since the repair.
June 2004 F350 6.0L, 4 Door Supercab XLT SRwd Short Bed, Automatic, Deluxe Aluminum wheels, Class V Trailer hitch receiver, 3.73 standard rear end. Line-X bed liner, 5th wheel hitch, Brakesmart trailer brake control and powerlock starter interlock.
Larryect is offline
