Wet CAC boots - Diesel Forum - TheDieselStop.com
post #1 of 18 (permalink) Old 12-30-2009, 02:16 PM Thread Starter
Bumpy's Avatar
Wet CAC boots
I have about 72,000 on a 06 6.0. The CAC tube boots are starting to get messy. I'm assuming that the oil has got to them and they are weeping with boost pressure. What is the best source for replacements? Have no other weeps or leaks and just hate to have a mess for such a simple issue.
2006 F-350 Crew Cab Lariat 4x4 6.0 Power Stroke diesel
Bumpy is offline
post #2 of 18 (permalink) Old 12-30-2009, 04:38 PM
kbroadnax's Avatar
CAC Boots
Check this ebay store out, see if it meets your needs. I just replaced my Boots also, pricey little rascals.
eBay Store - Ford Diesel Parts: 6.0 L DIESEL ENGINE PARTS, 6.0 L DIESEL GASKETS, TURBO CHARGER PARTS
2004 6.0 liter(stock), 4x4 Dually King Ranch Package. Goose Neck Hitch, Bull Bar, 130 watt off road lights x 2, Vent Visors, Stainless Steel Exhaust Tip, Edge Insight Monitor, E*R Spool Kit, Dieselsite Coolant Filter Kit, GatesHeavy Duty Fleet Runner Serpentine Belt, Tires: Hankook Dynapro AT RF10 LT235/85R16 ROWL M+S. Use PM-22-A Motorcraft Diesel Cetane Booster with every tank. Pullin' 33ft Travel Trailer or 20ft Deck Boat.
Former 1996 7.3 Liter Dually XLT with conversion package , Tymar intake, Trans temp gauge, Auxiliary trans cooler.
"Give a complicated problem to a lazy man and he will always find a simple solution", words of wisdom from Uncle Smokey.
kbroadnax is offline
post #3 of 18 (permalink) Old 12-30-2009, 05:20 PM Thread Starter
Bumpy's Avatar
Thanks, Those are better prices than I have seen elswhere so far. Appreciate it.
Bumpy is offline
post #4 of 18 (permalink) Old 12-30-2009, 06:54 PM
Bumpy, look at doing the CCV re-route, get rid of all that crap going back into your engine!! This CCV mod is difficult only if you overthink it. Vent it to the outside and be done.
In the end we will remember not the words of our enemies but only the silence of our friends
2012 F250 C/C Lariat SRW SB 6.7 4x4 DSFF high idle mod door seal mod
2002 f250 7.3 Lariat SRW SB 4x4 nittos Ranch Hand bumpers straight exhaust TS 6 position chip 174k
Si Vis Pacem, Para Bellum
1954oldred is offline
post #5 of 18 (permalink) Old 12-30-2009, 07:45 PM
TousleyParts's Avatar
Pricey rascals indeed!
I can sell the 6C3Z-6C640-B for $39.56 & 6C3Z-6C640-A $43.88
+ UPS or Fed Ex shipping ($9-10 in the lower 48)
TousleyParts is offline
post #6 of 18 (permalink) Old 12-30-2009, 08:55 PM
I agree with ccv reroute. Just did mine and can see the emission coming out of it alot. That would really help them boots stay clean as well as your inner cooler. Easy mod you could do in about an hour.
Powerhouse9228 is offline
post #7 of 18 (permalink) Old 12-30-2009, 10:01 PM Thread Starter
Bumpy's Avatar
You know, I did something similar to an inline 6 gas I had years ago due to the air filter constantly getting soaked with oil. Although I'm by no means a tree hugger I'm not sure I want to just dump that on the ground. Or all over the undercarriage.
Bumpy is offline
post #8 of 18 (permalink) Old 12-30-2009, 10:03 PM Thread Starter
Bumpy's Avatar
Is that price with or without clamps?
Bumpy is offline
post #9 of 18 (permalink) Old 12-30-2009, 10:09 PM
Sorry, no clamps
We do sell clamps from time to time; However, with these particular boots I usually don't sell clamps.
post #10 of 18 (permalink) Old 12-30-2009, 10:12 PM
clamps range from $8-11ea
post #11 of 18 (permalink) Old 12-31-2009, 11:04 AM
wet cac boots
I posted about this at another time in regards to the BD CCV filter. This is a device which says it will remove the oil from the blow by and recirculate only air and you would have a catch can for the oil which is drainable. The main problem some of us would have is to locate it in another position if you also have a coolant filter installed.
baddna is offline
post #12 of 18 (permalink) Old 01-01-2010, 09:24 PM
wheelbase's Avatar
Bumpy,
Don't buy those silicone boots. I'm on my second set (yes the last set were the updated ones from the dealer) and they are now leaking. I'm 100% stock. I just ordered replacement boots from dieselsite.com, which are NOT silicone. A little pricey, but I don't care. The updated boot from Ford started leaking after 8 months. They also sell a wire clamp that goes on the pipe to help with blowoff.
http://www.dieselsite.com/index.asp?...ROD&ProdID=932
2005 F350 Superduty 6.0L CrewCab LB 4x4 Black Lariat Loaded w/ S&B Cold Air Intake / 2008 Telescoping Mirrors / Recon Smoked Cab Lights & Side Markers / Cooper Zeons / Bilstein Shocks / MBRP Turbo Back Exhaust / Edge Insight / Cab off repair replaced every gasket in engine after buyback process ended with a check from Ford (Oil Leaks) / Run Rotella Synthetic / Stanadyne Performance Formula in every tank
2012 Greystone Fifth Wheel (Heartland)
2003 Black Lab (Magnum) 105 LBs and runs on Pro-Plan
wheelbase is offline
post #13 of 18 (permalink) Old 01-02-2010, 08:27 AM
The crankcase vents to the intake therefore there will always be a source of oil. Replacing the stock boots does not do any good because they will just saturate again.
If they are replaced with something that is not permeable the oil will just collect there.
I personally just wipe mine down every now and then. I could not justify spending any money on that item. Once I kept after it the wet spot on my bell housing went away as well.
2007 F350 XLT 4x4 SC 6.0 PSD No Mods *Traded*
2011 F250 XLT/FX4 4X4 CC 6.7L PSD
johnny87 is offline
post #14 of 18 (permalink) Old 01-02-2010, 09:35 AM Thread Starter
Bumpy's Avatar
I think I'm going to just remove clean, inspect for cracks and if all is good re-install. I can't really justify the $$$$ for it to happen again regaurdless. It has taken 72,ooo to get to this however, so if it becomes a constant issue right after cleaning I may just get a new set............ took 3 years to get this way first time around.
What would be a good cleaner? Dish soap perhaps?
Bumpy is offline
post #15 of 18 (permalink) Old 01-02-2010, 09:52 AM
I just take a rag to mine. Dish soap is a great degreaser and would work. I noticed mine after I was under my truck for an oil change and saw that the bell housing was wet(~18,000 miles). Took it to the dealer and they put dye in it. I did some looking around on my own and found drips forming under the CAC boots. I reacted the same way you did. I did some reading on it and came to the conclusion I posted above. I bounced it off of a few techs. One in particular said sometimes they replace them at the dealer he works at just to make the customer happy but acknowledged that they will again become saturated and drip.
johnny87 is offline
