What Alternator works in 2006 F350? - Diesel Forum - TheDieselStop.com
Old 03-16-2009, 05:16 PM   #1 (permalink)
My stock alternator is dying - down to an ouput of 11.6V according to the Ford guys. They want $500 Plus to put in a stock 110 amp unit, the local FLAPS has a 135 Amp unit for $270.00 - parts computer says this is for a truck with a dual alternator setup. Can I use the 135 Amp unit in a single alternator setup?? The 135 unit has a three pin plug receptacle, the stock unit appears to only have a 2 wire harness - haven't taken off the plug yet to see if it is 2 wire or 3 wire receptacle - assuming the plugs are compatable - any problems here I should know about???
Thanks !!
RcGreg 2006 F350 Dually 6.0 PS
rcgreg is offline
Old 03-16-2009, 07:20 PM   #2 (permalink)
no that one is the second for the dual trucks, do you run allot of electrical stuff?
Ford certified diesel tech
96 PSD reg cab 4x4 auto 4.10 LS rear xlt. 4" superlift 35" BGF Muds on 16.5 mickey thompsons, dual stabilizers, 3" glass cowl hood, custom american patriot headlinner, Beans stage I's, TS Performance 6 pos. chip, SD HPOP, BB in fuel regulator, custom intake, 3" downpipe, 4" straight pipe exhaust and 5" tip. All aluminum radiator, 6.0 trans cooler. Banks pyro, trans temp and boost gauges on the pillar. TransGo shift kit, billet converter. 10" rear drup bumper, custom droped hitch receiver billet grille, custom front bumper with fog lights and billet grille, diamond cut headlights, clear corners and markers. Viair compressor, one gal. tank and dual air horns.
90 mustang 347 race car.
05 f250 red supercab 6.0, suncoast auto trans, 4x4, long bed fx4, grey interior. atc 275cc injectors, turbonetics ceramic coated 70mm turbo, head studs, aeromotive fuel system, sct with innovative tunes, dual 5" stacks.
fordboyyfm is offline
Old 03-17-2009, 07:58 AM   #3 (permalink)
Not a huge amount - the object was to recharge the batteries in the short trips from home to work - I guess I will stick with the 110 amp unit then.
Thanks !!!
rcgreg is offline
Old 03-17-2009, 11:31 AM   #4 (permalink)
bugman's Avatar
My Photos: (18)
If you want to try a high output alternator try one from DB ELECTRICAL, you will also have to buy the upgraged wireing harness from them.
Jim
96 F250 PS XLT 4X4 long box, 5sp,4.10, manual hubs,pyro+boost guages,Dark Toumaline, add a leaf,Dale's TYMAR,and HX hose, downpipe, coolant filter
bugman is offline
Old 03-17-2009, 12:49 PM   #5 (permalink)
Hmmm - that looks like it could work for me, I'll check out DB - thanks for the info !
-RCGreg
2006 F350 Dually 6.0L Diesel with Tommy Gate
Looking for heated seats !! (It's cold up here in the winter!)
Calgary Alberta
rcgreg is offline
Old 03-17-2009, 07:13 PM   #6 (permalink)
if your batteries are low then they will need to be charged with a battery charger or they will never charge all the way back up.
Old 03-17-2009, 09:08 PM   #7 (permalink)
Auto value seems to have a good alternator with a 3 year unlimited mile warranty. I had an 03, ford replaced the alternator just over 12 months later it was junk.
zimmdairy is offline
Old 03-17-2009, 09:52 PM   #8 (permalink)
Down here in Texas nearly every town has a starter /alt shop that rebuilds yours.
Check out your local I bet there is one or two around.
rbutler46@yahoo.com is offline
Old 03-18-2009, 08:13 AM   #9 (permalink)
I talked to the friendly folks at DB Electrical and they made me a very attractive package deal on the high AMP alternator and wiring package. The cost is not that much more than having mine rebuilt - and twice the output - that should allow for better charging in a short period of time. Both batteries charge up to the exact same level on the battery charger - measured with the Negative lead off of course! 12.81Volts. Thanks everyone for their advice, I'll follow up with how the high AMP Alternator works out.\
RCGreg
2006 F350 6.0L Dually with Tommy Gate - looking for heated seats!
rcgreg is offline
Old 03-18-2009, 05:57 PM   #10 (permalink)
teamroper60's Avatar
Originally Posted by rcgreg View Post
I talked to the friendly folks at DB Electrical and they made me a very attractive package deal on the high AMP alternator and wiring package. The cost is not that much more than having mine rebuilt - and twice the output.....
If I may make a suggestion........ When you get that alternator and before you install it, take it someplace and have it tested.......
A group of us bought the 220amp alts from DB. When they were delivered and before we installed them we had them tested, only to discover they didn't put out anywhere near 220amps......... Not even near 200amps..... So where that company is concerned, buyer beware....
pics
#43
SLAPS President and Webmaster
teamroper60 is offline
Old 03-18-2009, 11:02 PM   #11 (permalink)
FTG-05's Avatar
My Photos: (25)
Or at least make sure it comes with a "proof of performance" test tag like the one shown below.
Good luck.
Al
'06 F-350 SRW 6.0 PSD
FTG-05 is offline
Old 03-23-2009, 08:38 AM   #12 (permalink)
I installed the Alternator with the help of a buddy in less than 20 minutes. Here is the technique that worked for us.
1. IMPORTANT !!!! Remove both battery negative cables.
2. Use a long round sharfted screw driver slipped betweent he alternator pulley and drive belt to slip the belt off the pulley.
3. Tie the drive belt off to prevent it slipping off any of the other pulleys. I used a ratchet strap tied to the lugs on the front wheel. No great pressure required, you just want to keep it in postiion.
4. Remove the 3 alternator bolts - strange that they're metric not SAE.
5. Remove the alternator cables and attach them to the new alternator.
6. Bolt the new alternator in place using the reccommended torque.
7. Untie the drive belt and using the round shaft of the screw driver slip the belt back onto the new pulley. Be careful not to damage it.
8. Replace the negative battery cables and your done!!
I can't believe that the local Ford dealer charges 1.8 hours to do this !!!
YIKES !!!!!!!!
TESTING:
Test the ouput of the alternator by measuring between the post of the red cable ON THE ALTERNATOR and the NEGATIVE post of the #1 battery. You should see close to 14 volts and rising as the batteries charge. Measure between each connection to see if you get a voltage drop (usually .01 volt) accross it. If you see anything greater (Such as .1 Volt) you need to clean up that connection as there is resistance developing due to corrosion at that connection. It may seem a small amount but it adds up by the time you get to battery # 2.
I discovered that one cable hooked to the positive terminal of battery #1 has a flat metal part, like a strap - Does anyone know if this a 'fusable link' or more likely a repair of some sort. The cable goes into the main harness. If it is a repair I'd like to clean it up before it becomes a problem.
rcgreg is offline
Old 03-23-2009, 03:17 PM   #13 (permalink)
FTG-05's Avatar
My Photos: (25)
Did you have it tested or did it come with a factory test tag? If so, what were the results?
Thanks,
Al
FTG-05 is offline
Old 03-24-2009, 08:03 AM   #14 (permalink)
Hi AL, No time to have it tested - and there was no tag on it, physically it appears the same as the 135 AMP units. So I can't tell you the exact ouput, but it is bigger and charges faster at a lower RPM than the 110 unit, and it was cheaper than what they sell the 135 AMP units for locally, so for me it was a good deal. It is a different part number than the 220 AMP unit so I wasn't expecting it to be right up there AMP wise. If you really need all those AMPS then for sure your going to want a performance tag or test prior to install. It meets my needs as it came - so I'm happy. I can now make short trips in the winter and be sure my battery is charging - even with the lights heater etc on.
rcgreg is offline
Old 03-24-2009, 11:47 AM   #15 (permalink)
When you remove the belt on a 6.0 there is a nifty little steel strip on the tensioner that locks tensioner in released position. It doesn't look like it has a purpose but it does. The lock strip is on the left side of tensioner as you look down at tensioner standing in front of truck. On the tensioner body is a tab that sticks out and the steel strip will push to the right and when you relax your grip on pry bar or breaker bar the steel strip will hold tensioner in the released position. The steel strip pops out when you pry tensioner towards release position and its ready to go again.
I do not for sure if a dual alternator setup has a different tensioner
2006 F450 CC Hauler bed 4x2 6.0 L Pstroke/Torqshift, Lariat, 4.30 r/a.
2006 F350 Lariat CC Dually 4X2, 6.0 TQShift 4.10 LS, STOCK.
36 foot double tandem axle flatbed trailer.
36 foot Sooner 6 horse large dressing/ mid tack.
15 horses with good balance from being hauled behind a P'stroke.
jimmy is offline
