I am considering buying new batteries for my F250 6.0. Anyone have any advise on brand CCA? After installing new batteries what should I expect from the truck? I mean is there in idle re-learn or anything like that?
You will likley get alot of different opinins on this one. Here's my 2 cents. I just replaced the batteries on my 7.3L Ex. After some research, I went with Walmart Everstart Maxx's. $75.00 each.Best price, equal or better 3yr non prorated, 7yr prorated warranty. Plus (the big reason for me) if you have a problem, there's a Walmart open 24hrs everywhere. They are 850 CCA each. Replaced them myself (although Walmart will do it free) No issues. They have Everstart and Everstart Maxx available for most vehicles but I think the only choice you have with the diesel is the better Maxx.
Some people have not had alot of luck with them and most the popular I saw on the forums is interstate. I have not had good luck with interstate. I also have had Walmart Everstart Maxx on my 4runnner for about 5yrs now with no issues.
2000 Limited, 118K, 7.3L, 285 Cooper ATR's, super chips 1705 on tow/performance, Bilsteins, Isspro EGT/Boost/ Trans temp.
1997 4runner,5spd,TRD supercharged,Bilsteins,H&R coil springs front and rear
1968 roadrunner,383,4spd
1970 roadrunner,383,4spd,pistol grip,58k 0riginal miles
1970 Charger,383,4spd,pistol grip,my first car
Dont go crazy thinking about what brand name to get!!
With all the big names and all the lables on batteries you will be mind boggled and the truth to all this is that there are only about 5 BATTERY MANUFACTURES today. Yep even DIE Hard is just a lable.
Just get 850 CCA or higher. Name is not as important cause it is just that a name
Sears dont make them DIE HARD dont make them Walmart dont make them sams dont make them Everlast dont make them Mack dont make them Caterpillar dont make them Ford dont make them Chrysler dont make them
Jim Sult / Excavator (we dig it) Trying to fix it? KISS IT"KEEP IT SIMPLE STUPID" Avatar- purchased off Ford lot as NON RUNNING ENGINE - I drove it off lot in 1 hour/ my everyday 1996 F250 XLT Ext Cab, Powerstroke, 4x4 Dana 60 , Bilsteins shocks, Greggs MB AutoTrans, BabySwamps,Tony Wildman Chip, AutoMeter Pyro/Trans/Boost, Tymar intake, MBRP 4 in turbo back exhaust, 209000 miles,D&B HT Starter
1996 F350 XL PowerStroke 4X4 DRW, Auto Trans, Stock Work Dump truck, DDP down pipe,Tymar intake, 113000 miles
1997 F350 XL 2x4 DRW Powerstroke , DP Tuner PCM, 5 speed,Luk Clutch Tymar intake. DPP downpipe, 185,000 miles
The first two posters gave you the best advice you will need. Like they said don't get hung up on the name. An adhesive label does not make a battery, it's the internal construction that makes a battery. I currently have Everstart Maxx but also have had Autozone Durolast Gold. Johnson Controls is a good manufacturer. Do your research on the manufacturer and not the label. When you go to purchase look and the small print on the label that tells you which company made the battery. Consider also the warranty and ease of redeeming warranty work if needed.
2004 6.0 liter(stock), 4x4 Dually King Ranch Package. Goose Neck Hitch, Bull Bar, 130 watt off road lights x 2, Vent Visors, Stainless Steel Exhaust Tip, Edge Insight Monitor, E*R Spool Kit, Dieselsite Coolant Filter Kit, GatesHeavy Duty Fleet Runner Serpentine Belt, Tires: Hankook Dynapro AT RF10 LT235/85R16 ROWL M+S. Use PM-22-A Motorcraft Diesel Cetane Booster with every tank. Pullin' 33ft Travel Trailer or 20ft Deck Boat.
I replaced mine last year with the exact same Walmart batteries, They have a very good write up on them.
MOST JOHNSON CONTROL BATTERIES ARE MADE IN MEXICO NOW I WOULD STICK WITH A BATTERY MADE IN THE USA
And what batteries name are you refering too?
Johnson Control Industries makes Duralast seen in Autozone stores, Diehard - sold in Sears, Kirkland - the Costco brand, Motorcraft - which Ford sells, some of the EverStarts, and Interstate. Exide makes Exide batteries, Champion, Napa and even a % of the EverStart batteries
Johnson Controls and Exide are worlwide
I just had to replace my batteries in my 04 f350 drw 6.0. Man what a price shock I got. I called SEARS and they wanted $189.99 each. I about $hit myself. Those were 950cc. ASKED IF THEY WERE MADE OF REAL GOLD! LOL. Then called Les Schwab and there 950cc was 95.00 each. SO I went there. Factory was 850cc. I could not believe there was such a huge price difference.
When I replaced the batteries in my '03 last spring, the best deal was at Costco. They killed Les Schwab, sears and even wally world. Made by Johnson Controls, good warranty, in stock. The only hassle is that they would not do the install so I had to bring back the old ones for the core charge.
The Toys:
'01 KDX200, '01 YZ125, '02 WR426, '02 TRX500, '03 KX100
Rage'n 2930-5GLX fifth wheel toy hauler (GVWR 13.5K)
Circle J bumper pull horse trailer (rated for 3 but I take out the dividers and load 4)
4 horses of questionable parentage
I agree with what has been posted, and I will add the following: Costco and Walmart are great places to get batteries, why? Because they dont give you a hassle when you need a replacement. Some places require an act of congress to get a replacement battery if you have a failure. It seems that Walmart and Costco is happy to comply with their agreement.
__________________ TDS member #49 - 1999.5 (Built 4/26/99) White F350, CC, SRW, LWB, Lariat, AIC, 4R100 (4th transmission before 85k - gotta love this tranny), 6.0 trans cooler, manual shift 4wd, 3 inch leveling kit, KING reservoir shocks, 285-75-16 Bridgestone REVOs, Performance Friction Pads all around, Powerslot Cryo'd rotors in front, CD player, Infinity REF 6800CS speakers (front and rear), Garmin 2610 GPS (hardwired), 40/20/40 leather seats, heated turn signal- TT mirrors, Titan V hitch, weatherguard box, DP Tuner 4 Position chip (love it), AIS intake, Diesel Site CAC Boots, 4" Magnaflow exhaust, Diesel Innovations Up Pipe, gutted EBPV, Non EBPV Turbo Pedestal, X-Monitor. NO STEERING WHEN BRAKES ARE APPLIED!
Have used the Walmart batteries for several years with fairly good luck. Yes have had a couple replacements under warranty with no hassle. Price/no hassle/ and the fact I need a nation wide instant warranty is my reason
DEKKA BATTERIES ARE MADE HERE, CROWN BATTERIES ARE MADE HERE, TROJAN BATTERIES ARE MADE HERE, US BATTERIES ARE MADE HERE AND ALSO MAKES INTERSTATES GOLF CART AND DEEP CYCLE BATTERY SO IF YOU LOOK YOU CAN STILL FIND BATTERIES MADE OVER HERE I HAVE SOLD A LOT OF DIFFERENT BRANDS OF BATTERIES AND NONE OF THE OFF SHORE BATTERIES HOLD UP AS GOOD AND NOT MUCH OF A PRICE DIFFERENCE
2005 F350 XL REGULAR CAB 6.0 11 FOOT SERVICE BOX DRW STOCK 212,347 ON THE CLOCK
1997 34.5 FLEETWOOD AVION 5TH WHEEL
2003 F350 XLT CREW CAB 7.3 STOCK DRW 85,000 on the clock
JOHN 3:16
Johnson Controls makes their batteries in Wisconson however I'm sure they and the others have more than one plant world wide.
2005 Lariet, 6.0, 3:73 1969 Mach 1, 428 CJ
1971 Triumph Trident(SOLD)
2007 Road King flhp
2007 Jazz 5er, 11k
173rd Airborne
I bought OE batteries from the local stealership....$115 installed; I also had a coupon for $50 off the total price.
Sometimes it pays to look at Ford.
__________________ Fred
2004 F-350 CC DRW LB FX4 4x4
Oxford White/Arizona Beige
King Ranch
Herrin Hauler bed
4.10 Trac-Lok
Reman'd 6.0L @43,956 miles
Reman'd Turbo @54,814 miles
