What changes were made to the 2007 6.0L - Diesel Forum - TheDieselStop.com
Old 08-03-2006, 10:01 PM   #1 (permalink)
KingKong's Avatar
My Photos: (11)
I'm sure this has been posted before But my question is what changes were made to the 6.0 to date for the 2007.
I have a 2007 on the way to replace my 2004 I just wondered what changes or improvement have been made
thanks in advance
07 F-250 6.0 L CC XLT 4x4 Red Addons: ARE Cover, WheelSkin Cover, PML Rear axle Cover, Dieselsite Coolant Filter, C-better Mirrors,Gauges Isspro Fuel press. Trans Temp. EGT gauge. Gauges from Diesel Manor. Edge Insight CS (For EOT & ECT)
04 F-250 6.0 L CC XLT 4x4 White Buy Back
...... 06 Jayco Travel Trailer 32'
KingKong is offline
Old 08-03-2006, 10:30 PM   #2 (permalink)
My Photos: (5)
Re: What changes were made to the 2007 6.0L
None worth mentioning from '06 to the (short) '07 run.
AutoJim
Former Cooling Guy
'99.5 F350 Lariat CC SRW 4x2, 7.3L 4R100
'99 Mustang Cobra, SCCA Solo2 E Street Prepared
'97 Dodge Neon, SCCA ITA/STU/EP Club Racing
Now I do subsea ROV tooling.
AutoJim is offline
Old 08-03-2006, 11:34 PM   #3 (permalink)
ford_doctor's Avatar
I have visually noticed was the turbo inlet tube is now one peice...
Ford Master Diesel Technician
Diesel Technician Society
ford_doctor is offline
Old 08-04-2006, 12:37 PM   #4 (permalink)
TexasTruck's Avatar
My Photos: (13)
thanks in advance
Congrats on the new truck! My 07 replacement just came in, we're waiting on the final paperwork.
From 04 to 07 the 6.0, I've heard is now "commonized". I think this means that manufacturing the 6.0 and upcoming 6.4 are built on the same line. I noticed right away that the overall engine area is more compact, neater. The heads look different to me. Someone here posted a link that takes you to the changes that were made to "commonize" the 6.0. IMO, this engine is smoother, quieter, "zippier", than my 04 6.0. So something changed...
Scott
2008 Silver F250 FX4 6.4
ICON / OUO / Line X / Viair / Air Horns / BMF / Toyo / GOS harness / Custom Driveline
"A problem is an opportunity in work clothes"
TexasTruck is offline
Old 08-04-2006, 01:31 PM   #5 (permalink)
Oil Dip Stick Changed [img]/ubbthreads/images/graemlins/smile.gif[/img]
2006 F250 (April 06), 4x4, Lariat, SuperChips 1706, Auto-Meter Guages, AUX-Box (PIE), 13,000 miles.
J_Calhoun is offline
Old 08-04-2006, 02:50 PM   #6 (permalink)
rock_doctor's Avatar
Let me guess it's black in color again...to make it easier to see when checking the oil at night... I am looking around now for a 07 F250 CC and see many nice ones on the lot. I am just waiting for Ford to match GM's 0% interest for 72 months and I will make the jump also.
mark
2005 Excursion w/ 6.0L PSD
2008 FX4 F250 CCSB w/ 6.4L PSD
rock_doctor is offline
Old 08-06-2006, 09:59 PM   #7 (permalink)
KingKong's Avatar
My Photos: (11)
Could someone post a link to the commonized 6.0 changes I have looked for them and can't find anything I did see someone said that the tail pipe may be 4" can someone confirm this with there 07 truck?
KingKong is offline
Old 08-07-2006, 11:08 PM   #8 (permalink)
I too would like to see the list - I cannot find one from 05-06 nor what (if any, were changed in 2007). I used the search function as well.
- Marshall
2004 F350 Lariat King Ranch 6.0L,LB,CC,Dually,TS,4.10LSD,Sunroof,Dual Alts, Line-x, Tint, Banks Exhaust, HiddenHitch Gooseneck (ordered 12/15/03, picked up 02/14/04). 61k miles SOLD
2007 F350 Lariat King Ranch 6.0L,LB,CC,Dually,TS,4.10LSD,Line-x, Transferflow 57Gal underbed, MBRP with cat, 30k Gooseneck, picked up 09/03/06. 5500 miles
mmorgan24 is offline
Old 08-08-2006, 01:29 AM   #9 (permalink)
Banned
we have a 07 6.0 F350 Single Cab & Chassis that we picked up yesterday.
Nothing noticably different?
Exhaust is 3.5" and muffler & cat are both the same as our 06's.
Chase N.
cnesloney422 is offline
Old 08-08-2006, 10:49 AM   #10 (permalink)
TexasTruck's Avatar
My Photos: (13)
Chase N.
I picked up my replacement 07 last Friday, brought it back in on Monday for a resonating muffler. Around 1300-1500 it's "singing", worse when cold. The tech tried to tell me it's the turbo - I think not since you can stand outside the truck on the muffler side and hear it.
I noticed that the muffler is tilted towards the drive shaft, whereas my 06 it is vertical. The other plumbing appears to be the same as the 06.
Under the hood, the large diameter air intake on the output side of the air filter is a cheaper plastic version than what my 06 had. I'd be willing to bet this is causing another moaning sound I hear at idle, but isn't as bad as the "singing" muffler.
FWIW, I drove four other 07's on my dealers lot, they all had the "singing" muffler and moan at idle. The moan at idle is like a power steering pump low on fluid IMO.
Scott
Old 08-08-2006, 11:47 AM   #11 (permalink)
Not to sound mean, but did you check the power steering fluid level?
It would not be the first time a new truck was low on fluids. [img]/ubbthreads/images/graemlins/smile.gif[/img]
Allen
2005 F350 King Ranch 6.0L,4X4 DRW,5sp auto,4:10 LS, camper pkg, towing pkg, Loaded everything except dual alts and moonroof.
Options/changes...Supersprings for the TC, coolant water filter, Sylvania HV13XV hi-lo's, Sylvania Silverstar 9005 foglites, Brite box+ foglites, Tubular grill inserts, Paregon retractable bed cover, OilGuard EPS 60 bypass filter with Schaffers 9000 5w40 synthetic, Bilstien shocks, PIAA 93360 Super Sporza silicone wiper blades, Husky floor mats, Dash mat cover.
allenf is offline
Old 08-08-2006, 01:30 PM   #12 (permalink)
TexasTruck's Avatar
My Photos: (13)
No that's not mean [img]/ubbthreads/images/graemlins/smile.gif[/img] I didn't think of it actually, I will check it before heading home this evening...
Thanks,
Scott
Old 08-08-2006, 03:32 PM   #13 (permalink)
Banned
Chase N.
Scott
All of our 06's the mufflers are tilted, but on our 03's & 04's (dont have any 05's) they are all vertical, i wonder why Ford did this?
Chase N.
Old 08-08-2006, 07:30 PM   #14 (permalink)
KingKong's Avatar
My Photos: (11)
Just a thought could ford made this change to the mufflers because of the change in the frames One thing I have seen is the trailer hitch sets lower on the truck could this be the reason they tilted the muffler?
KingKong is offline
Old 08-09-2006, 01:30 AM   #15 (permalink)
I would really like technical details on changes from the 06 to 07 model years if any - I read about this "commonized" engine parts and stuff but cannot find it when searching here or elsewhere. Based on what the new 08's look like and the new 6.4L engine, I think I may get a new 06 or 07. I want to know if it would be better to get an 07 (possibly ordering) or an 06 (on the lot and a little better price). My 04 has been very good to me but I want may be able to upgrade to a newer truck for very little $$$. I've for 56k on it now and the warranty goes to 100k via ESP - that's only 16-18 months for me.
TIA!
- Marshall
