What do I need to make a 6.0L Reliable? - Diesel Forum - TheDieselStop.com
Old 11-26-2007, 08:10 PM   #1 (permalink)
I am in the market for a Diesel Ford Excursion and I have been looking for the 7.3L for its reliability. However they are very hard to find and everyone wants $1 million dollars for them. I can buy the same year 6.0L (which I have in my truck and it has been reliable *knock on wood*) for about 3-4k less. So even if I had a problem with head gaskets I can put ARP's on it for under 3k can't I? The EGR coolers are alos notorious, Once these 2 problems items are gone, isn't the 6.0L very reliable?
Is this just wishful thinking?
2003 Ford Excursion 4x4 6.0L
jbilliel is offline
Old 11-26-2007, 08:27 PM   #2 (permalink)
OneTonHillBilly's Avatar
Re: What do I need to make a 6.0L Reliable?
The reliability is there with ARP's
2007 F-350 CREW SRW Lariat Outlaw(Bought New By Me)
This Thing Is Going To 200K With Me Behind The Wheel!
OneTonHillBilly is offline
Old 11-26-2007, 08:59 PM   #3 (permalink)
Lightningfast01's Avatar
I would buy a 7.3 my buddy has a loaded Limited 4wd white/tan 02 with 210K miles ish he'd take 17K for it. The 7.3's are rock solid. We have 4 6.0's in the family and all have had problems from turbos, head gaskets, tranmissions etc.. The two 7.3's just keep on going and going and going.
2005 F250 FX4 SuperCab SWB in DSG
Buckstop rear bumper American steel!
Daystar baja bar with PIAA Racing 80's
Quad pillar Air, trans temp, pyro, boost
Magnaflow 15954, ATS studs
Transfer Flow 46gal midship tank
Firestone Airbags 2400 kit ViAir 250C compressor
Eaton TruTrac, Rancho 9000's, Skyjacker 1.5" rings
ViAir 380C@200psi, 5gal tank, Siege Anvil train horns say move *****!
Lightningfast01 is offline
Old 11-26-2007, 09:25 PM   #4 (permalink)
I've heard that a coolant filter will do wonders for your EGR.
Rednecks have more fun!
1992 F350 CC LB 5.8L 5-speed 4.10 L/S. Stock
92F350CC is offline
Old 11-26-2007, 09:25 PM   #5 (permalink)
Smiley1's Avatar
Ditto on the Studs. Thats what I did. The Trans is better in with the 6.0.
Be careful talking about emission related stuff as it is prohibited on this forum to talk about compromising them.
2004 F250 CC FX4 / 46g Transfer Flow / ARP Studs / Coolant Filter / CCV
2004 Surf Side 30' pull trailer
1999 Pontiac GTP modified
1968 Pontiac Firebird (restored)
Smiley1 is offline
Old 11-26-2007, 10:50 PM   #6 (permalink)
I like the torqshift tranny much better myself.
jbilliel is offline
Old 11-26-2007, 11:21 PM   #7 (permalink)
bigwhite1's Avatar
the emissions talk might be prohibited, but i think we can still talk about what's causing the 6.0l problems and i think it's the EGR cooler.the way it was changed on the 6.4l is a dead giveaway that this area is a problem. i think ford still needs to take responsibility for this and fix it.
unfortunate owner of a 2006 6l diesel,lb,cc and formally a 2004 6l. both puke and both not fixed by ford under warranty
2004 cardinal 33ts
bigwhite1 is offline
Old 11-26-2007, 11:30 PM   #8 (permalink)
My 6.0L has 92,000 Kilometers on it and it has been good. I tow with it and use it as a daily driver. I have some mods (see my sig) but the key I think is to be smart. Gauges, and using them, and synthetic oil contribute to longevity. The torqueshift is very good and when hooked up to a good running 6.O L it kills a 7.3. I know, I have had a 91 and a 97 7.3. The fuel economy of my 6.0 L is way better then my 7.3. I had good performance out of my 7.3, I had a banks powerpack, but I burned up my manual transmission at 120,000 kilometers. I really like my current truck and would not want to go back to the much noisier and less fuel efficient 7.3
Saskatoon Diesel installed my Vanaaken and my exhaust system and they claim increased reliability if you don,t overheat. So far it appears to be true.
2004 F350, 4x4, 6.0l auto, Lariat fully optioned, LB, CC, Ford remote start, Isspro gauges in A pillar, AFE (proguard 7) intake, 4" exhaust, Vanaaken Smart box, Bilstein shocks, Truxedo, PIAAs and KC driving lights, SS grille, towing a 27.5 Cardinal 5er, using Delvac 5-40 synthetic oil.
Bills2003 is offline
