What gives with Fuel MPG - Page 2 - Diesel Forum - TheDieselStop.com
Old 08-21-2006, 12:21 PM   #16 (permalink)
FamilyRide's Avatar
Re: What gives with Fuel MPG
....Scientology-like cult that surrounds it frightens me.
LOL WHAT!! [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
I use Amsoil in just about everything and in everything I use it in, I see a benefit that makes it more than worth the $$$.
However, I switched to Rotella in the Ex. because UOA's on Amsoil was coming back not much better than dino. You cannot extend the drain on the 6.0. Maybe change the filter and do partial drains, but it shears. Viscosity and flashpoint do matter regardless of what someone drinking Amsoil for breakfast thinks. I may switch back to try it again now that I have some miles on it but I may not. $30 vs $85????? At dealer cost too.
With Amsoil yes, easier starts, runs slightly smother (or didn, who knows with all the flashes since then) and absolutly no romping or other cold start issues. Yes, mine every now and then, will still romp a tiny bit with Rotella.
I wish people would stop giving Amsoil a bad name. It's good stuff in the applications/situations where it's right. I've had awesome results running 20w-50 Racing oil in my boat!!! However, it's over $6 a quart dealer cost. But for as much money as I have in the motor, it's well worth it and I still change it at about 20 hours.
My wifes '05 Pacifica gets Amsoil. It gets extended drains an it works great in that application. I don't like changing it so I change it and leave it alone. It's also the first time I "saw" a MPG increase using it in anything.
You guys stop talking Amsoil voodoo and giving it a bad name. USe, love it but don't come on here talking about it like it's what will save the world. [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
2004 EB Excursion, 4x4, 6.0, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto, V code front springs, Revo 285's and bubba lights
FamilyRide is offline
Old 08-21-2006, 01:23 PM   #17 (permalink)
Yea here we go again with yet another Amsoil discussion!! Anyway thanks for the replies about the fuel mileage. I hope it gets somewhat better. Although, I get better fuel mileage than my buddies Z71, might be he has a real heavy foot.
2006 6.0 PSD CREW CAB WEDGEWOOD BLUE FX4 LOADED
fish4funjb is offline
Old 08-21-2006, 01:44 PM   #18 (permalink)
It should go up with some miles on the engine.
I have noticed a mile per gallon more with 9000 miles on mine, 12 to 13 when brand new and 13 to 14 mpg now in mixed highway/city driving.
99.5 F350 XLT CC 4x4 PSD/auto
2006 F350 XLT CC 4x4 PSD dually towboss
lrantan is offline
Old 08-21-2006, 04:35 PM   #19 (permalink)
I agree with Irantan. Fish4fun, with my 2000 7.3 l didn't start seeing decent mileage until around 15k to 20k. It will get better. At around the 10k to 12k mark I saw about a 2 or 3 mpg increase. I wondered then if I was ever going to see decent mileage. Then around the 18k to 20k mark, I saw another increase. At that point, it tapered off and has remained pretty steady the past 4 or 5 years.
As others will state, speed will usually eat up your mpg after around 70 mph or 2000k on the tach. Wind resistance (a strong head wind) will also knock it down a little. Make sure your tires are inflated to where they should be. I've got Michelin LTX tires, and I run them with 70 to 80 pounds of pressure. I also drive with a tonneau cover over the bed. That is good for a good 1 mpg or more.
I use dino oil, either Mobil 1, Shell Rotella, or Chevron (depending on what's on sale), and I change my oil every 5k miles for piece of mind. Since I change my oil as often as I do, I don't think synthetic would give me much better performance, other than maybe stretching out my oil changes a little.
I change oil and oil filter at the same time. I change the fuel filter every 10k to 12k miles. I've never had the 'water in fuel' light come on, so I've felt pretty lucky.
Bottom line, your mileage should start improving as you get some miles on the truck. imho
Y2K F250 CC PSD Auto, Short-bed Lariat, Woodland Green/Gold, ordered 07/10/99, born 09/12/99, delivered 10/08/99, Access bed cover, Bed Rug, Zoodad mod, Viper Remote Start Alarm, Fumoto valve, 103K somewhat error-free miles (so far) [never back to dealer for anything]
Repairs: CPS, Water Separator Valve assembly, rear axle bearings, VSS, batteries, brakes, alternator, serpentine belt (x2), driver door pwrlock actuator, water pump
2009 VW Tiguan 2.0 l turbo 200 hp gas engine (TDI engine not available for it yet)
short_stuff is offline
Old 08-21-2006, 05:59 PM   #20 (permalink)
Hello all, My 06 PSD just doesn't seem like it gets that great of MPG AVG in the city not pulling anything. I think the last couple of tanks I have seen an average of 12 - 13 mpg. I went to GA not pulling anything as well 375 miles stayed at around 75mph cruise all the way and only got 17. Is this normal. Truck has just 2700 miles on it, Thanks in advance for the input!!
I wish mine got that good!!
2001 White Lariat 7.3 Auto CC LB 4X4 -- Mods -- K&N Drop in, DP Tuner, 6.0 IC mod, 4" Magnaflow Exhaust, BTS Tranny, 3 gauge A piller pod. Kennesaw Mountain Accessories Rear and Front “Wincher” Bumper, Warn 16.5Ti Winch, Suspension: Tuff Country 2" front and 3" rear, Toyo MTs 305s on 10s, 310,000 miles!!
05 White XL 6.0 Reg Cab 4X4 140,500 miles!! (That has never seen the inside of a Garage)
06 White 6.0 CC Lariat 4X4 Auto LB: Kennesaw Mountain Accessories Front “Wincher” Bumper, Warn 16.5Ti Winch, Fabtech 8" lift, 35 Toyo M/Ts 125,651 miles!!
---07 Shelby GT500--- Performance White Vert-- Mods-- JLT Intake, 2.6" upper & 10% IW Lower Pulleys, AFCO Duel Pass Heat Ext., American Racing Long Tube Headders, Full 3" Magnaflow Exhaust, Evolution Stage 4 Tune, BMR Carbon Fiber Drive Shaft, Steeda UCA & LCAs Currie 9" 1:3:75s True-Trac locker, Proglass Cold Air Hood, 36,500 miles---11.491 1/4 mile! 592RWHP
mobeydick is offline
Old 08-21-2006, 09:15 PM   #21 (permalink)
for diesel service you can safely use 20k intervals using amsoil diesel oil and amsoil oil filter along with clean oem air filters.
if a k&n air filter is what you use then I wouldn't go over 10k with amsoil.
How to void your engine warranty, let me count the ways............
You know, I would really like to see a OA on a sample of Amsoil after it been ran in a 6.0L diesel engine for 20,000 miles. Given the 6.0L reputation for shearing oil, dino and synthetic, I would suspect the oil would have a viscosity rating similar to water.
I don't know on the 6.0 although I have 2 and I'm using Amsoil, with oil Drain cycle of 10,000 miles! I expect great results! I can tell something about the 7.3. On my 01 I started using Mobil 1 at 7,000 miles at 13,000 miles I changed the oil and filter, I didn't change the oil until it hit 100,000 miles. Now I change the oil every 10,000 miles! I did change the filter every 10,000 miles and topped it off at the full line on the oil dipstick. I never did a OA during that time. I did have one done a few months ago, 220,000-230,000 miles I think. Using a K&N air filter, Blackstone said everythng was below normal and my 7.3 was as good or better then most out on the road!!
I think Amsoil is just as good as Mobil 1 the only reason I didn't use it before was it cost more and was harder to get!
Syn. is the only way to go if you put 60,000 miles a year on your truck!! With Dino that is an oil change every 2.75 weeks!! I've got better thing to do!!
Old 08-21-2006, 10:46 PM   #22 (permalink)
how true that is. most guys here that use dino oil can remember a few times they didn't have time to change out the oil and went a few k over, hey life happens and we dont always have time for our vehicles.
I did say some guys I know a few dont miss a oil change for anything.
Mobile One is one of the top oils and worth the coin but Amsoil is not as hard to get as some may make it out to be, a toll free call will get you what you need whenever you need it.
or ask any dealer you may happen to see, he will be more than happy to help you out.
hey mobey you said you had some blackstone UOA? do you remember the silicone content of the sample oil?
interrested in the silicone content using a K&N air filter
thanks
1988 F250 dually 7.3 IDI Banks Sidewinder C-6 with GearVendors overdrive 3.55 ring gear
Amsoil 5w30HDD with full flow / bypass filters,
Evans coolant and Amsoil conical air filter.
AMSOIL ATF in the transmission, AMSOIL gear oil in the diff.
20MPG city 25/28 hwy
IDIABUSE is offline
Old 08-21-2006, 10:57 PM   #23 (permalink)
What I "get" is that you have a disease probably related to Tourette's Syndrome wherein you cannot type a sentence on your computer's keyboard without mentioning Amsoil.
Like a previous poster said - Comeback and post after you use it in a 6.0 and when you have independent verifiable data from a certified lab to back up your claims.
You certainly never took a logic class in a Jesuit university. Your paragraph on extended oil intervals is painful to read.
Manufacturer's extended oil change intervals have come about with regular motor oil. How can that be? Manufacturers specify synthetic oil for differentials, but NOT Amsoil. NO manufacturer uses Amsoil as a factory fill or factory recommendation. Longer oil change intervals without Amsoil??? Could it be differences in new engine design? How about cleaner burning fuels - both for gasoline and diesel engines?
Wow! The world continues to spin without Amsoil. Wanna bet? I don't use it and I say the sun rises tomorrow.
thanks for the heads up, manufactures are using synthetics why?
dosent matter they dont use Amsoil, fact is synthetics save time money
something the manufactures are tired of fooling with, with warranty claims and backlogged repair lines manufactures are turning to synthetics for better customer service and improved engine performance and extended drain intervals. GM is paid by Mobile1 to use their oil. [img]/ubbthreads/images/graemlins/biggrin.gif[/img] thats a clear winner for the synthetic oil
crowd [img]/ubbthreads/images/graemlins/smokin.gif[/img]
europe uses 20k drain intervals for 2 decades now maybe expensive gas has something to do with that?
IDIABUSE is offline
Old 08-21-2006, 11:43 PM   #24 (permalink)
STG
Stop making stuff up. Mobil doesn't pay GM to use Mobil1. Same for Porsche. What 20K oil drain interval in Europe?
The fact remains that NO manufacturer uses or recommends Amsoil.
You are so full of [censored], it's getting on your keyboard.
Post some facts. Better yet, shut up. You're killing Amsoil sales.
Stan
2005 F250 4X4 SD R/C Power Stroke / Torqshift
Oxford White, Medium Flint 40/20/40 Vinyl, Prefered Equip. Pkg. 600A , 3.73, Limited Slip, XL Decor Pkg., Jeweled Headlamps, Chrome Rear Step Bumper, 9600# GVWR Pkg., Engine Block Heater, Sliding Rear Window, Speed Control / Tilt Wheel, Camper Pkg., FX4 Pkg., Air Conditioning, Forged Aluminum Wheels-17", Tow Command, Telescoping TT Mirrors. Using this vehicle to produce an ambulance voids Ford warranty. Added: Ford factory upfitter switches, Go Industries Rancher Grill Guard (hammered powdercoat), Hella 4000 Rallye lighting (two Euro Beams), SnugTop Super Sport camper shell, Jotto Desk & Escort Redline Radar/Lidar Detector.
STG is offline
Old 08-22-2006, 12:00 AM   #25 (permalink)
But amsoil is great! that's why ALL of the Us and domestic manufacturers SPECIFICALLY recommend using amsoil when it comes to oil changes [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
/sarcasm
If I hear this guy touting his snakeoil.. err amsoil one more time, I swear bad things will happen.
If it's worth Shooting, It's worth shooting twice.
Ammo is Cheap... life is EXPENSIVE.
2003 6.0 Crewcab/Auto/Shortbed. AirRaid Intake. Autometer Nexus H2O, Tranny, EGT and Boost Gauges.
BB PIN
32ADB170
LSC_Ya is offline
Old 08-22-2006, 12:26 AM   #26 (permalink)
Uh, I don't want to agree with IDIABUSE, but.... German cars do have 15-20k oil change intervals, but..... This is because they hold a heck of a lot more oil. Double your quanity of oil and it's bound to last longer. They do use synthetic, but no one driving BMWs do OA so no idea whether or not dino would do just as good, or how syn is doing. I was trying to stay out of this convo, but I'm going to chime in. I'm a fan of synthetic oil, has worked for me in the past. My 2 7.3s, no way, cost to much to change. With the Rottella, I've had no problems and my OAs are perfect. Currently I'm running a CAT oil filter. Much larger, still full flow. I'm up to oil changes every 7500 miles. I add 2-3 qts in between and I can go longer. OTR drivers don't use amsoil or mobil 1, they use rotella and similar dino oils with success. Good filtration and capacity is key. This garbage about micron levels and efficencies is stupid. They are called full flow filters for a reason. Why would you want to make smaller openings when the small stuff does not effect engin wear. Filtration capacity, the capacity to hold dirt, is more important. These are my thoughts, and I DO have OAs to prove my theories!
Dan
2007 F350 4Dr Diesel Dually Lariat, auto, 4x4, 4.10 ls., snow plow prep, loaded.
2001 7.3 - gone
1995 7.3 - gone
4drdually is offline
Old 08-22-2006, 01:17 AM   #27 (permalink)
LET'S ALL STOP TALKING ABOUT THIS STUPID AMSOIL AND GET BACK TO ANSWERING THE GUYS QUESTION! WHY DON'T WE JUST START TALKING ABOUT AMWAY OR KIRBY VACUMS! GEEEEEEZZZZZ!
First of all I was having what seemed to be poor mileage too. I was getting about 13 come hell or high water (no towing during calc). After reading the many knowledgeable posts about mileage I came to the conclusion that the 6.0 is VERY sensitive with regards to fuel usage and RPM's. I saw a 2 MPG increase if I kept the RPM's below 2000 during take off. The people behind you get a little impatient but they are not footing the bill for the fuel are they? I will do an occasional romp at WOT from 10MPH up to 80MPH for fun. I am also running stanadyne but really haven't noticed any difference in mileage.
2003 F-250 6.0L
FX4 Supercab Longbox
Build Date April 03
Torque Shift w/SOTF
Rancho Shocks.
Tires: BF Goodrich Rugged Trail T/A 265/75/16 (Pressures 55 fwd/65 Aft)
Oil: Rotella T Heavy Duty 15/40.
2003 F-250 6.0L
Build Date April 03
Torque Shift w/SOTF
Rancho Shocks.
Fumoto Drain.
2nd Turbo @ 14000
mowhawky is offline
Old 08-22-2006, 02:10 AM   #28 (permalink)
Yup, the sump in those BMW's with I-6's approaches 9 quarts exactly for the reason you stated.
I also don't reccomend looking in the crankcase of a car that has run 20k drain intervals even with synthetic. [img]/ubbthreads/images/graemlins/phoney.gif[/img]
My 6.0 kicked out around 14 towing where as my new Dodge gets 13.
All around driving the 6.0 averaged 15, 2 MPG's better than my 7.3.
On the freeway I would get like 22 if it was dead flat. So does the Dodge.
The overhead was always dead-to-nuts +- a tenth or two. It's odd that all these owners have overhead displays that are inaccurate. Maybe they aren't educated in their proper use?
hellokitty is offline
Old 08-22-2006, 06:32 AM   #29 (permalink)
thanks
Universal Average is 9, 5,000 mile oil Change intervals. Mine was running 7 on 10,000 mile Intervals.
Old 08-23-2006, 12:49 AM   #30 (permalink)
With almost 19k on the truck, mileage for my daily 50 mile roundtrip commute is avg. 22 at 55-60 mph. But once I hit stop lights and run errands around town, my tank average is closer to 18 mpg. Overhead display is usually within 1/10th. Couldn't be happier.
I'm happy with Rotella-T Syn 5W/40. It's fairly cheap at Wally World ($15-16/gal.). And the truck starts very nice with it (even in the dead of winter); just plain awesome. I still follow recommended service intervals; even though I have an oil bypass filter too. But that's just me.
p.s. you can't compare mileage to any other truck though, the number of variables is endless and impossible to compare against. You're within the normal range though..don't worry.
2005-6L/PSD F-250 Lariat CC/SB/4x4:
- 4" turbo back through muff @ 2050 mi.
- Racor CCV4500 reroute @ 4500 mi.
- Crankcase pressure gauge @ 4500 mi.
- Battery charge high idle @ 4500 mi.
- AFE Stage 2 ProGuard7 @ 6500 mi.
- Coolant bypass filter @ 7600 mi.
- Frantz oil bypass filter @ 10,550 mi.
- X-monitor; pyro/tranny/boost
- Fluidampr @ 22k mi.
- Fuel crossover line @ 28k mi.
pstrang is offline
