What happend to my high idle??? is idling bad for 6.0s? - Diesel Forum - TheDieselStop.com
Old 04-25-2009, 06:15 PM   #1 (permalink)
DieselPeter's Avatar
Used to be that when I first started the truck it would do a normal idle for about 3 minutes , and then wind up to a much higher idle................
NOW , its just pretty much stays at idle.
Is that because its much warmer out, or is there another reason????
Also, I read somewhere that its bad for 6.0s to idle for too long, is that true????? I let mine sit at idle alot..........
DieselPeter is offline
Old 04-25-2009, 06:35 PM   #2 (permalink)
It will idle up according to ambient temps. For instance I live in San Diego Ca. and on a cold morning here I will see about 750rpm's. But when I go to Northern ca. and it is under 30* outside it will idle a little over 1000rpm's. I let my truck idle alot as well and have never had problems. I am sure that the EGR valve is the problem when long idle times occur.
BP6.0 is offline
Old 04-25-2009, 06:42 PM   #3 (permalink)
Phil G.'s Avatar
As stated, the high idle is temp related and yes the EGR valve really hates idling. But there is another issue with extensive idling called wet stacking. You can search wet stacking if you want more detail, it has been discussed many times on this site.
http://philztruck.piczo.com/?cr=7 Updated February 2009!
2007 F350 SRW 6.0L Auto, 3.73LS, 172"WB 4x4.Viper VX790 Alarm/RS w/motion sensor, WD pillar Guages,Alpine W205 DVD head unit with Blackbird 2 GPS, and Parrot Handsfree Blueooth + 7" O/H Monitor,Sirius plug in receiver, Kenwood KAC-8492 720w 4ch Amp driving Infinity 6010CS 6.5" components up front and Infiniti Kappa 62.7i 6.5" 2-way in rear doors, Infinity 611a Class D mono amp driving 2- Kenwood W2509 10" subs in custom box Cobra night-watch w/ dual wilson 2000's, 100gal polished alum fuel tank, Reese 5th hitch, Anderson Tool aluminum TT hitch, Bremen full glass running boards, painted mirrors, grille, door handles,valence,wiper arms,RamMount laptop mount.
Phil G. is online now
Old 04-25-2009, 09:10 PM   #4 (permalink)
Thanks!
Thanks.............I will look up wet stacking. This may sound like a dumb question, but as a maintenance thing, is it worth changing out the EGR valve periodically????
It seems to me that it would be a fairly inexpensive item to change out, even from the dealer....????
Old 04-25-2009, 09:29 PM   #5 (permalink)
rock_doctor's Avatar
Actually yes.... Some have two and just change each oil change. The one they take out gets cleaned and saved for the next change out. If you take it to the dealer they will not change it but clean it and reinstall. Here is a link to a page describing how to clean the valve. Diesel Technician Society
2005 Excursion w/ 6.0L PSD
2008 FX4 F250 CCSB w/ 6.4L PSD
rock_doctor is offline
Old 04-26-2009, 12:04 PM   #6 (permalink)
STG
From memory I seem to recall the diesel owner's supplement recommending no more that 10 minutes idling for every hour of operation.
That said, I have the SEIC hooked up to the #4 upfitter switch and use it religiously anytime I'm idling for more than.
You may want to hook up the Stationary Elevated Idle Circuit. It's built-in to your truck and all you have to do is hook up a switch to the wiring for it found under your steering column. I think there is a sticky around here with directions.
With the truck in Park and the emergency brake on, activating the SEIC will increase idle to 1,200 RPM and help prevent wet stacking (engine runs warmer at 1,200 RPM). Additionally SEIC does not lock up the torque converter like the other up idle circuit for power take off applications.
If the engine computer senses low batteries, the SEIC wil automatically raise idle anywhere from 1,200 to 2,400 RPM until the bats are charged.
Stan
2005 F250 4X4 SD R/C Power Stroke / Torqshift
Oxford White, Medium Flint 40/20/40 Vinyl, Prefered Equip. Pkg. 600A , 3.73, Limited Slip, XL Decor Pkg., Jeweled Headlamps, Chrome Rear Step Bumper, 9600# GVWR Pkg., Engine Block Heater, Sliding Rear Window, Speed Control / Tilt Wheel, Camper Pkg., FX4 Pkg., Air Conditioning, Forged Aluminum Wheels-17", Tow Command, Telescoping TT Mirrors. Using this vehicle to produce an ambulance voids Ford warranty. Added: Ford factory upfitter switches, Go Industries Rancher Grill Guard (hammered powdercoat), Hella 4000 Rallye lighting (two Euro Beams), SnugTop Super Sport camper shell, Jotto Desk & Escort Redline Radar/Lidar Detector.
STG is offline
Old 04-26-2009, 02:00 PM   #7 (permalink)
ZMANN's Avatar
do the high idle mod and it takes 30 minutes to clean an egr just get a gasket kit ahead of time
O6 King Ranch cc sb 4 inch lift ,35 Pro Comp,Helo’s Edge Insight CTS guage only , Auber EGT , o8 center console ,2x10 subs, xm satellite ,coolant filter,RSX 9000 shocks,dual bilstein steering stabilizers ,Viper , remote toolbox popper, High Idle mod , up fitters added ,weather guard mats , ARP's, BPD EGR cooler, Marinco Mod ,Zoodad waste Fabtech traction bars, Some other stuff
ZMANN is offline
Old 04-26-2009, 11:46 PM   #8 (permalink)
I see how to clean the manifold but what to use to clean the valve?
04 GMC 3500 4x4 dually LB7 duramax 04/04 F250 12/20/03 build date, XLT Supercab longbed 6.0l, 4X4, 3.73lsd, FX4 pkg, torqueshift, ESOF, silver/med. flint, 6cd, back up sensors, rear slider, camper pkg, big mirrors w/ heated/pwr glass, Sold
04/04 F350 Crew Cab long bed 6.0L lariat FX4 46K Sold
1998.5 Dodge 3500 4x4 dually 24valve cummins 160K (sold)
2005 Lance 835 Cabover Camper
1999 Sanger DXII ski boat
1975 Dodge RamCharger (sold)
1990 Sanger DX ski boat
1991 Dodge W350 Cummins SRW (sold)
pwrstrokn2004 is offline
