Re: What Happened?
Did you do your tire cleaning right after an engine start? I believe there is a trans learn period that starts when the transmission hits 110 degrees and lasts for 5 minutes. I know that Edge enhanced trucks have it when the trans is programmed to learn periodic. During that time period, judicious applications of throttle can bring weird behavior from the transmission as it is trying to readapt. I have had it happen to me. Generally a restart will start the prcess over again, and if you wait five minutes the trans should operate normaly even under a heavy foot.
White 06 F350 Lariet CC 2WD DRW Tow Boss, Timbren SES, Smiths Ultimate Bedliner, RK Tool Box, Reese 20K Hitch, CondensorGuard, IntakeMod, S&B Intake, SEIC, Banks 4"TB w/cat, Accufab, Edge Platinum/w Evo Trans Tune, Harpoon Mod, Coolant Filter, CAC Tube Restrainer, Glove Box Light, Hood Insulator, Rewired Mirror Heat, Seat Heater Indicator.
