What kind of coolant do I need to use? - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 04-08-2010, 01:24 AM Thread Starter
Arcticfury's Avatar
I have a few gallons of coolant that has a rating of Ford ESE-M97B44-A Sections 3.1.1 & 3.1.2.
Would that work?
All I can see on the Ford Gold is WSS-M97B51-A1
These diesels are new to me. Thanks in advance for any info.
2004 F350 6.0 PS Crew Cab Lariat Edge Evolution (Just to monitor)
2005 Jeep Wrangler Rubicon
Arcticfury is offline
post #2 of 8 (permalink) Old 04-08-2010, 02:39 AM
teamroper60's Avatar
I doubt the stuff you have is rated for this engine.
#43
President and Webmaster
teamroper60 is offline
post #3 of 8 (permalink) Old 04-08-2010, 06:19 AM
The manual is pretty specific about it. Engineers and chemists put all of the fluid specs in one place for the owner. Why out think it to save a few bucks?
2007 F350 XLT 4x4 SC 6.0 PSD No Mods *Traded*
2011 F250 XLT/FX4 4X4 CC 6.7L PSD
johnny87 is offline
post #4 of 8 (permalink) Old 04-08-2010, 12:35 PM
MikeL46's Avatar
My Photos: (14)
Save the old coolant for a gas engine and use the proper coolant in the diesel.
Mike
D70 Full floating rear axle from a cutaway van
140A Alternator. 125W solar panel. Sportsmobile off-road trailer.
115615 miles. 16.65 mpg average
From Cal to Alaska, Key West, Labrador/Newfoundland and points in between
05 F350 front axle and aluminum wheels 275/70-18 tires.
46 Gal tank - harpooned pump vent tube.
Scangauge. DieselSite Coolant Filter@72K. Fumoto valve. Amsoil dual remote oil filter setup.
MikeL46 is offline
post #5 of 8 (permalink) Old 04-08-2010, 01:39 PM
wareagle08's Avatar
Motorcraft premium gold engine coolant.
Its ethylene-glycol based brother man
2006 F-250 Lariat SC FX4 Off-Road. 6.0L PowerStroke. Hypertech Power Programmer. Airaid CAD. Diamond Eye 4" TurboBack. Daystar Level. Factory 20x8.5 Wheels. 35x12.50R20 Nitto Trail Grappler M/T. Black Brush Gaurd.
2003 Chevrolet 2500HD LT 4-Door 4x4. 6.6L Duramax. Hypertech Power Programmer. Airaid CAD. Straight Pipe Exhaust. 2" T-Bar Crank with Ford Keys. 2" Rough Country Level. Bilstein Shocks. Ball Joint Spacer. Eibach Pro-Alignment Kit. 16x8 Xtreme Alloy 1069. 315/75R16 Toyo Open Country A/T. Westin Black Brush Gaurd.
wareagle08 is offline
post #6 of 8 (permalink) Old 04-08-2010, 05:48 PM
hitecdan's Avatar
My Photos: (23)
Only use the Ford Gold or a diesel specific that meets Ford's standard. Coolant for gas engines do not have the corrosion protection that your diesel engine requires. The green stuff will turn to gel in your diesel engine from the heat and pressure which will cause your engine to overheat. In other words, you can kiss your EGR cooler and head gaskets good bye if you don't use the correct coolant. The anti-corrosion build in it the diesel specific coolant will keep your cylinder walls leak free from cavitation.
My html Version of the
Now with 2005 Updates
Born on date: Jan 20, 2003
Number of C94 injectors replaced: 1 (#4 Jan 30, 2015)
Number of times the EGR valve has been replaced/cleaned: 0 (updated: 9/17/2014)
hitecdan is offline
post #7 of 8 (permalink) Old 04-08-2010, 07:04 PM
69cj's Avatar
Mike
Actually alot of the gassers are getting particular on what to use with all the dis-similar metals now used. Go to the owners manual and look at the required specs for your motor. Corrosion, cavitation and electolysis can all spell doom to your engine wether a diesel or gasser. Penny wise, pound stupid. Your call. I would rather throw away free coolant than a good engine.
2005 Lariet, 6.0, 3:73 1969 Mach 1, 428 CJ
1971 Triumph Trident(SOLD)
2007 Road King flhp
2007 Jazz 5er, 11k
173rd Airborne
69cj is offline
post #8 of 8 (permalink) Old 04-12-2010, 10:16 AM
FTG-05's Avatar
My Photos: (25)
No need to throw it away, use it in your tires.
'06 F-350 SRW 6.0 PSD
FTG-05 is offline
