What are the major causes - Diesel Forum - TheDieselStop.com
Old 08-28-2006, 02:32 AM   #1 (permalink)
of problems on the PSD's?
I may have an injector going bad. If and when it goes, I'm going to fix whatever needs to be fixed under warranty, and address other potential problems that may not be a problem at the time of the warranty work out of pocket. So please, diesel gurus, what should I have replaced to improve the reliability of the 6.0?
Thanks much
If it's worth Shooting, It's worth shooting twice.
Ammo is Cheap... life is EXPENSIVE.
2003 6.0 Crewcab/Auto/Shortbed. AirRaid Intake. Autometer Nexus H2O, Tranny, EGT and Boost Gauges.
BB PIN
32ADB170
LSC_Ya is offline
Old 08-28-2006, 09:54 AM   #2 (permalink)
FamilyRide's Avatar
Re: What are the major causes
...what should I have replaced to improve the reliability of the 6.0?
Anyting that's broke, worn or just not working right? [img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/wink.gif[/img]
2004 EB Excursion, 4x4, 6.0, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto, V code front springs, Revo 285's and bubba lights
FamilyRide is offline
Old 08-28-2006, 10:44 AM   #3 (permalink)
Well, stuff like injectors, HPOP, ICP sensor, Headstuds, I am aware of. But what else am I missing? I figure if we're going to be in there, might as well replace stuff that's known to go out because of the 6.0's design flaws. And yes, I'll be paying for most (if not all) of this work, I won't be going to FORD and being a crybaby to get stuff done under the warrranty, unless it's actually broken.
The EGR cooler I'm not too concerned about, as the EGS is unplugged. (yes, I did it with the engine off, and to be on the safe side, with the keys out of the ignition. [img]/ubbthreads/images/graemlins/laugh.gif[/img] )
BB PIN
32ADB170
LSC_Ya is offline
Old 08-28-2006, 03:52 PM   #4 (permalink)
No One? Wow....
BB PIN
32ADB170
LSC_Ya is offline
Old 08-28-2006, 04:00 PM   #5 (permalink)
Just look through the forums. If you replace the injectors this should do it. Lots of things to clean but no real big issues. An experienced tech should see if there's anything else upon his work. Have a look on your TC / tranny.
Jim
2009 F250 PSD 4x4 CC LB KR
2007 Suburban LT3
2007 Yukon XL Denali
2005 F250 PSD 4x4 CC LB KR
pictures
JimJoe is offline
Old 08-28-2006, 05:09 PM   #6 (permalink)
Aha. Thank you.
BB PIN
32ADB170
LSC_Ya is offline
Old 08-28-2006, 08:52 PM   #7 (permalink)
OT
OT's Avatar
For starters, replace orig. C94 f.i. w/redesigned C 95 if not already done. Otherwise..potential problems..Might be cheaper to install complete new 07 6L which has the benefit of all changes since 03. JMO! [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Gotta go back to all the changes made to true (not 04/03 6L) 04 6L. Maybe someone has link on old FMC report showing about 30+ changes made to 04. Then go forward to present date & all changes made. for updates. FWIW www.intellidog.com/dieselmann/60bulletin.htm
03 F250 XLT SC/SB 4X4 6L (stock) A/T. SRW 3.73's BD:02/11/03. 01 TL 23' SGII
OT is offline
Old 08-28-2006, 11:16 PM   #8 (permalink)
I appreciate your opinion, but if I were to do an engine replacement, I'll wait till the current one ****s the bed, then I'll go with a 5.9 Cummins swap.
BB PIN
32ADB170
LSC_Ya is offline
