Old 08-03-2009, 09:06 PM   #1 (permalink)
Leggz61's Avatar
Send a message via MSN to Leggz61
Question What is the normal Engine Coolant Temp
Can someone tell me what the normal Engine Coolant Temp is in an 04 with a 6.0L Superduty? At what temp should one start to worry if not signs of puking, odor, fluid, or movement on dash gauge?
thanks.
Leggz61 is offline
Old 08-03-2009, 09:17 PM   #2 (permalink)
Ipolute's Avatar
i have a bully dog triple dog programmer and mine at an idle will sit at about 180... on a hot day... but driving around itll get up to 210...and if it gets up to 210 it wont start... i let it cool to anything under210 and itll start dont know why
2005 F350 Lariat 4x4 6.0
325/65R18 Nitto Terra grapplers
Leveling kit
8k HIDs w/fog lights
Recon Side Markers(Smoked)
Recon Roof Lights(Smoked)
Harley Davidson Headlights
White L.E.D lights (Parking and Roof lights)
DieselSite Coolant Filter
3.5 Inch straight Exhuast.
Bully Dog Triple Dog w/outlook monitor
Cobra XRS R9G Radar Detector
.....At the Track..... http://www.youtube.com/watch?v=vMiWo6i5ZVA
Ipolute is offline
Old 08-03-2009, 09:19 PM   #3 (permalink)
Leggz61's Avatar
Yeah ours with the Edge Platinum juice idles around 185 but once we get moving on the warm days we're having it hits 212 sometimes. Just curious as hubby is really concerned that it's running too hot?
Leggz61 is offline
Old 08-03-2009, 09:47 PM   #4 (permalink)
using my Dashawk, I get temps anywhere from 180-210 depending on where I'm driving. Usually 205-210 with trailer (11,000 lbs), though it has gone as high as 220 with trailer on longer and steeper grades, but it comes back down. I couldn't get an answer out of tech who did oil cooler as Ford doesn't give them that. Apparently the more important thing to watch is the difference between coolant and oil temps. If the oil stays around 15 degrees hotter than the coolant you could have an oil cooler issue, which can cause other issues (damaged EGR coolers, and puking coolant)
2007 F-350 Crew Cab DRW PSD 4.10LS
dougjpr is offline
Old 08-03-2009, 10:59 PM   #5 (permalink)
jdydiesel's Avatar
I usually run between 180 and 205 on my PowerPDA
Jason
02 Excursion 7.3l with Banks Stinger plus, Limited Ultimate 4x4. 06 F-350 6.0l with the Banks PowerPDA and Monster exhaust,SCT tuned by Dfuser, Lariat 4x4 CC LB DRW. 07 F-350 6.0l Stock, Lariat 2x4 CC SB SRW.
jdydiesel is offline
Old 08-09-2009, 09:18 PM   #6 (permalink)
194ish low power setting try to behave driving, and the highest I've seen is 203 high power setting showboating city driving with stop and go. once i hit 202 i tend to back off. All fan shroud has been removed also.
2003 6.0l CC LB dually, edge juice platinum with A2, afe stage 2 intake, mbrp turbo back cat delete, upgraded rebuilt trans
hulabaloo is offline
Old 08-10-2009, 08:01 AM   #7 (permalink)
Yikes !
On a steep grade - 7% for a long time (20 minutes) with a moderate load - the oil temp will hit over 240 degrees - while the coolant may hit 230 - Looks like the oil cooler is toast? - Is there an auxillary one available? Usual variation around town is 7 to 11 degrees, Coolant temps drop& rise faster than Oil temps which I expect to be the case. My EGR has the block option instlled.
2006 F350 Dually 6.0L Tommy Gate Lo0oking for heated seats !
rcgreg is offline
Old 08-10-2009, 02:53 PM   #8 (permalink)
Send a message via AIM to ritschner
195 to 204 degrees depending on outside temperature. Towing 24,000 GCVW temps will peak at 228 and oil 230 degrees. Oil temperature of 240 degrees is nothing to be concerned about.
White 06 F350 Lariet CC 2WD DRW Tow Boss, Timbren SES, Smiths Ultimate Bedliner, RK Tool Box, Reese 20K Hitch, CondensorGuard, IntakeMod, S&B Intake, SEIC, Banks 4"TB w/cat, Accufab, Edge Platinum/w Evo Trans Tune, Harpoon Mod, Coolant Filter, CAC Tube Restrainer, Glove Box Light, Hood Insulator, Rewired Mirror Heat, Seat Heater Indicator.
ritschner is offline
Old 08-10-2009, 04:01 PM   #9 (permalink)
Good to know ! Thanks
Around town Coolant is between 200 & 210 - but I live in Canada and the thermostats are usually set for Winter (Brrrrr) driving.
rcgreg is offline
Old 08-11-2009, 10:02 AM   #10 (permalink)
Leggz61's Avatar
Talking
UPDATE
Hey, we're in Canada as well...Alberta to be exact...we just arrived in BC and our temps hit 220 max pulling some really big hills. We drove 1/2 the way with the EDGE basically shut off, just allowing us to read the temps. The temps did really well, but our fuel mileage was down to 9 miles to the gallon....our trailer is approx 7000 lbs. We switched the edge to level 2 (tow Mode) and our temps stayed in the same range, and our fuel economy increased somewhat, to like around 12 MPG.
Now to improve the fuel economy...arrrrrrrrgh
Thanks to everyone for all their advice and suggestions, keep them coming as it's awesome.
Leggz61 is offline
Old 08-11-2009, 01:38 PM   #11 (permalink)
My coolant usually stays at 190 but will go to 215 . My oil temp stays about 15 to 20 degrees hotter.
~2004 F-250 Quad cab long bed, 6.0L PSD,4x4 ~Torqshift Trans
~Arizona beige,tan interior
~Running boards w/custom Piranha LED lights
~ARE bedcap, Bedrug
~Foglight/high beam mod,BriteBox,HD light harness
~Zoodad mod, High idle mod
~Coolant filter, Oilguard bypass filter, Fumoto
~Isspro pyro,trans temp,boost in A-pillar
~Marinco Block Heater Receptacle
~Bodiak front hitch
~Mag-Hytec rear diff cover w/6qts syn fluid
~250 watt oilpan heater
~Scanguage
barnbridge is offline
Old 08-11-2009, 04:12 PM   #12 (permalink)
I have a ScanGauge II. My Coolant reads 188 to 195 under load. I dumped my Airaid a few weeks back because I could not believe my intake temps, I installed the Banks Ram Air and now I am pretty much at outside temps when moving and slightly above when stopped.
What are you guys using to monitor oil temps? The ScanGauge to my disapointment does not monitor that sensor that I am aware of.
Oh and I am scheduled for a HG change under warranty. We puked coming over the Berkshires in Western Mass. I have my ARP bolts in the back seat waiting to hand to the dealer. And when it comes home I am installing the coolant filter.
Munfrobie is online now
Old 08-11-2009, 05:06 PM   #13 (permalink)
I use the Edge platinum monitor, which has the ability to monitor several parameters and display up to four at a time. Others judging by the posts use a Banks PDA, Bully Dog Outlook, or just tap the oil filter cap and run a oil temp gauge.
