what's the best motor oil? - Diesel Forum - TheDieselStop.com
post #1 of 30 (permalink) Old 12-21-2008, 07:51 PM Thread Starter
8534's Avatar
What do you think the best motor oil is? I have 2003 6.0 F250 33000 miles on Her.
8534 is offline
post #2 of 30 (permalink) Old 12-21-2008, 08:01 PM
rock_doctor's Avatar
Most use rotella or delo 15w40 and a fram filter (the fram filter is the same as motorcrafts filter complete with the same patent numbers) or you can just use a motorcraft filter. All of these are easily available at any walmart, side by side on the shelf.
rock_doctor is offline
post #3 of 30 (permalink) Old 12-21-2008, 08:20 PM
Lightningfast01's Avatar
Clean oil is the best oil. As long as it has the API certification for CF4 plus, CH, CI4-plus whatever Ford requires it should be okay. 15-40 is best protection. 5-40 is acceptable for low temp operation. Shell now carries the CJ-4 rating which is the newest out right now...
- ROTELLA Products
2005 F250 FX4 SuperCab SWB in DSG
Buckstop rear bumper American steel!
Daystar baja bar with PIAA Racing 80's
Quad pillar Air, trans temp, pyro, boost
Magnaflow 15954, ATS studs
Transfer Flow 46gal midship tank
Firestone Airbags 2400 kit ViAir 250C compressor
Eaton TruTrac, Rancho 9000's, Skyjacker 1.5" rings
ViAir 380C@200psi, 5gal tank, Siege Anvil train horns say move *****!
Lightningfast01 is offline
post #4 of 30 (permalink) Old 12-21-2008, 09:29 PM
mlsteele's Avatar
Have you guys ever had problems with the Rotella vapor locking?
Steele
______________________________________________
2012 F-250 Lariat 6.7L Crew Cab, Ingot Silver
20"wheels, 3.55 EL gear, Dual Alternators, FX4, Upfitter Switches, Bullet Liner, Weather Tech mats, Reacon side mirror smoke lens, SCT Live Wire TS with PIP tunes, 4" Delete Pipe
My Wife took ownership of:
2006 F-250 Lariat 6.0L Crew Cab, Black w/ Chrome package, Chrome bug guard and door latches
18" stock wheels, Nitto Tera Grappler, 4" Turbo Back MBRP, AccuFab Power Elbo, Edge Insight Monitor, Tinted Windows, Rhino Liner, Husky Floor Mats, B&W Turnover, Air Horn, ZooDad mod, Recon's all around, ARP studs, EGR Delete, SCT from IDP, and a heavy foot
Turned 100K miles 12-23-11
-Bullet Proofed 103K
-New Head Gaskets 58K
-New EGR Cooler 29K
mlsteele is offline
post #5 of 30 (permalink) Old 12-21-2008, 09:31 PM
dlblazer's Avatar
I like the rotella synthetic oil and Donaldson filters (great seal and a bypass valve that wont leak contaminates).
Current truck: 2002 PSD 4x4, CC, XLT, F350 dually, 4.10 gears. Air bags, 6.0 trans cooler, Fleetrite ELC, ISSPRO gauges (boost, EGT, trans, fuel pressure), PHP Hydra, full EBPV delete (pedestal & outlet), CNC Fab HP & HPX lines, Riff Raff FRX, Riff Raff IC boots, CCV mod w/catchcan, Reese Titan, AIS, ITP pre-pump filter kit, in-tank mods, Redhead steering box.
Old truck: 2000 PSD 4x4, ext cab, XLT, F-350, auto, V-code springs, air bags, coolant filter, 203 thermostat, CCV mod, Fleetrite ELC, DB Alternator, DB high-torque starter, Tru-cool Max-cool trans cooler, B&M trans temp gauge, 47 gallon Titan tank, ITP pre-pump filter kit.
dlblazer is offline
post #6 of 30 (permalink) Old 12-21-2008, 09:34 PM
Jinco's Avatar
X2 On the Rotella 5W40.
Buy Ford. They're not taking bail-out money.
2000
F250 XLT PSD Crewcab, Longbed, 4x4, Auto, LS 3.73
Ford AIS, Frantz Bypass Oil Filter, Baldwin Bypass Coolant Filter, Fumoto Drain Valve, 203* Thermostat, Stancor
Bilstein Shocks all the way around, Timbren SES (Rear), Bridgestone Dueler Revo A/T 265/75/16
Commander Monitor (gauges), Crimestopper CS-2016 DP II FM Remote Start/Alarm/Paging/Turbo Timer/Keyless
Rotella 5W40 Oil
, Texaco ELC Coolant, Mobile 1 ATF Trans and PS
Jinco is offline
post #7 of 30 (permalink) Old 12-21-2008, 10:21 PM
I ran Rotella 5-40 in everything from my ATV to diesel. Some company patented the 6 liter oil filter so they are ALL the same reguardless of who's name is on it...
Never heard of oil vapor locking...
post #8 of 30 (permalink) Old 12-22-2008, 12:24 AM
I've run nothing but DELO 400 CI & CJ 15W40 for 76k. I change at 7.5k intervals & take an OA to track fuel dilution. Blackstone says the engine is doing just fine, and the oil could go to 8k if I wanted.
If I lived in a cold place, I'd run Schaeffer's 9000 5W40 year around w/ bypass filtration & extend to 15k intervalls.
The 6.0 is notorious for shearing, but the Schaeffer's has shown itself very stable in a 6.0. The DELO does shear, but agian Blackstone thinks mhy engine is doing fine with it. It starts right up, doesn't smoke or surge & runs good.
OMC
OMCUSNR is offline
post #9 of 30 (permalink) Old 12-22-2008, 07:15 AM
I have run Schaeffer 9000 for 5 OCI's. The viscosity did indeed hold up well. The issue was that the last 3 analyses, the lead numbers have crept up (7-9 ppm from 1-2). They are not real high, but they are up. There are multiple other posts across the boards on Schaeffer 9000 and high lead (20-30 ppm on some). I have switched because of this (and before my lead goes higher). Valvoline Premium Blue Extreme 5W40 is highly recommended (but expensive).
Mark
bismic is offline
post #10 of 30 (permalink) Old 12-22-2008, 10:54 AM
bcollison1's Avatar
Originally Posted by bismic View Post
I have run Schaeffer 9000 for 5 OCI's. The viscosity did indeed hold up well. The issue was that the last 3 analyses, the lead numbers have crept up (7-9 ppm from 1-2). They are not real high, but they are up. There are multiple othet posts across the boards on Shaeffer 9000 and high lead (20-30 ppm on some). I have switched because of this (and before my lead goes higher). Valvoline Premium Blue Extreme 5W40 is highly recommended (but expensive).
I agree with Bismic.
My lead #'s and now Iron #'s are creaping up with the Schaeffer's. Lead is 11 and my last Iron was 48. Iron and Lead are higher than I have experienced before.
I have tried Rotella T 5W-40 in the past and it gave more OK results.
I'm going to try Mobil 1 5W-40 for a few changes, and I'll post my results with this oil.
2006 F-250 Lariat 6.0L PSD,CC,SB,FX4, Black with the Chrome Package with Chrome Door Pulls. Smoked windows, Rhinolined, 4" Stainless Turbo-back Magnaflow exhaust, Zoodad mod., DEE ZEE mud flaps, CCV rerouted, High Idle mod., High beams w/Fog Lights mod, Sylvania Silverstars in Headlamps and Fog Lamps, Intake Elbow from intakeelbows.com, SCT X Cal2 programmed by Eric from Innovative Diesel, Dieselsite Coolant filter, Quadzilla Commander Monitor with Fuel Pressure Kit, Autometer Oil Pressure gauge.
2008 Ford Edge Limited. AWD, Vista Roof aka Big Ass Moonroof, Navigation System. Black with Chrome 20" wheels. It has ALL the Options for an Edge.
My other toys:
2006 Rinker 232 Captiva Liberty Edition Bowrider. White gelcoat with Red band in the middle. Fuel Injected 320 HP Volvo Penta 350 with duoprops and captians call exhaust.
2004 Jayco 27BH travel trailer.
2005 John Deere 5303 64HP 3cyl. Turbo Diesel Utility Tractor with 512 Loader/Bale Spike. Too many implements to list.
bcollison1 is offline
post #11 of 30 (permalink) Old 12-22-2008, 10:19 PM
Jinco's Avatar
Please do. I've thought of trying Mobil 1 too, but have not heard much feedback.
2000
Rotella 5W40 Oil
Jinco is offline
post #12 of 30 (permalink) Old 05-27-2010, 02:18 PM
JBs
Rotella T
I have always heard good things about the Rotella T oil and use it in my Farm Tractors. However I know someone personaly who has used the Rotella in a new 6.0 Diesel and repeatedly had Injector O-Ring failures. After switching to Motorcraft Oil the problem went away. Anyone else ever heard of a specific Oil causing O-Ring failure?
JBs is offline
post #13 of 30 (permalink) Old 05-27-2010, 05:46 PM
lincster's Avatar
My Photos: (29)
Rotella all the way. 15W40 if you tow. You will break down a lighter weight oil very quickly if you tow and don't run the 15W40.
2012 F350 4X4 Dually, FX4, Crew Cab, Ultimate Lariat Package, Oxford White, Black Leather towing a 2006 LE3905 Weekend Warrior
2002 F250 CC, 4X4 - Sold
2004 F350 CC, FX4, loaded - Sold
2006 F350 CC, DRW, FX4 - Sold
lincster is offline
post #14 of 30 (permalink) Old 05-27-2010, 07:58 PM
my03psd's Avatar
I always run Rotella in my truck too.
3/28/03 F250 6.0L PSD ,TORQSHIFT,CC,SB,FX4,LARIAT
Charcoal Gray/Black,
Tint,RhinoLined,Sirius,Roll&Lock,Strobes,
SCT X3 Custom Tuned by Innovative,
58v FICM Tuned by Innovative,
MBRP Stainless 4" Turbo Back,
ISSPRO Pyro,Boost, & Trans Gauges
Prodigy Brake Controller,Remote Start and Turbo Cooldown,
High Idle Mod., PM-13A on the Oil Pan,
HFCM Plug Upgrade,DieselSite Coolant Filter,
Blue Spring Mod, 08 Diff Cover,
Banjo Bolt Mod, Energy Suspension Bushings,& Stanadyne every tank
my03psd is offline
post #15 of 30 (permalink) Old 05-27-2010, 09:30 PM
Just switched from 10-30 regular oil(winter) 15-40 (summer) to Mobil Delvac 1 ESP 5W-40. That was the oil the dealer recommended. On my second oil change with it. My local shop(not dealer) who does my oil changes and anything not related to the motor(for now) is a BG dealer and I am running one of their additives. So far it's been good, starts well and runs good cold. Real test will be when morning temps get down below 50, don't think we're going to get them for a while. I do have a stiction issue but need cold temps to see if the oil helps and additive helps. Ran Hot Shot Secret with Ford 10W-30 in the winter and it ran great. Not easy to get HSS here in Canada.
Doug
2007 F-350 Crew Cab DRW 4X4 4.10LS, MBRP 4" Cool Duals turbo back, SCT/ custom tunes from Elite Diesel, Autometer gauges EGT, Trans, Fuel Pressure, MSD Dash hawk OBD II reader for ECT,EOT,Voltage and Boost, Dieselsite coolant filter,EGR delete
dougjpr is offline
