What Weight Oil in Cold Weather ? - Diesel Forum - TheDieselStop.com
post #1 of 13 (permalink) Old 12-18-2007, 08:38 PM Thread Starter
Hi everyone . I have Two 2005 F350 6.0Ls power stroke Paramedic Rigs that i maintain. Does any one use different weight oil during the Cold Winter Months ? Last winter i used 10w30 Motor craft super duty because of some starting complaints from the drivers. Which was recommended in the Owners Manual. It did help starting . Now i see that the new 6.4l power stroke Manual Shows that you can use 10W40 motor craft super duty oil For the entire Temperature Range . I Guess I'm just looking to see what other fleets and owners do with these Terrible 6.0Ls
Winkman is offline
post #2 of 13 (permalink) Old 12-18-2007, 09:47 PM
Lightningfast01's Avatar
Re: What Weight Oil in Cold Weather ?
I find Shell Rotella 5-40 synthetic works best for cold starting. I am not familiar with the 6L.
2005 F250 FX4 SuperCab SWB in DSG
Buckstop rear bumper American steel!
Daystar baja bar with PIAA Racing 80's
Quad pillar Air, trans temp, pyro, boost
Magnaflow 15954, ATS studs
Transfer Flow 46gal midship tank
Firestone Airbags 2400 kit ViAir 250C compressor
Eaton TruTrac, Rancho 9000's, Skyjacker 1.5" rings
ViAir 380C@200psi, 5gal tank, Siege Anvil train horns say move *****!
Lightningfast01 is offline
post #3 of 13 (permalink) Old 12-18-2007, 10:06 PM
The 6.0 uses HEUI fuel system with a high pressure oil pump. It is the HPOP that is largely responsible for oil shearing in these engines. The 6.4 doesn't have an HPOP, it uses piezo injectors with a high pressure fuel pump. It also has a different bearing design in the low end. I would not assume that the oil specs for that engine automatically carry over to the 6.0. That said, a lot of people are claiming that 5W-40 works well in the 6.0L in winter and summer. Not sure what would happen if you had an oil related failure under warranty, though.
2004 F-250 Lariat CC, Short Bed, 4x4, 6.0L, TorqShift, FX4, Metallic Green/Arizona Beige, Medium Parchment Leather, Fumoto, B&W Turnover, A.R.E. LSX Tonneau, Built 4/01/04
MoeB is offline
post #4 of 13 (permalink) Old 12-19-2007, 12:57 AM
HeavyAssault's Avatar
My Photos: (6)
I'm using Mobil 1 with great results with the starting and running of the engine.
2006 F-350 CC PSD Lariat 4X4 LB 3.73 LS
Some stock stuff, some modded stuff, some deleted stuff.....
HeavyAssault is offline
post #5 of 13 (permalink) Old 12-19-2007, 06:42 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Winky</div><div class="ubbcode-body">Hi everyone . I have Two 2005 F350 6.0Ls power stroke Paramedic Rigs that i maintain. Does any one use different weight oil during the Cold Winter Months ? Last winter i used 10w30 Motor craft super duty because of some starting complaints from the drivers. Which was recommended in the Owners Manual. It did help starting . Now i see that the new 6.4l power stroke Manual Shows that you can use 10W40 motor craft super duty oil For the entire Temperature Range . I Guess I'm just looking to see what other fleets and owners do with these Terrible 6.0Ls </div></div>
I run 5W40 Rotella Syn year round and it works very well for me. We have had temps down to 0 degrees F and my truck starts and runs no problem; not plugged in either.
2009 F150 Lariat, Crew, 4x4
Previous - 2004 F350, Crew, 4x4, 6.0l
newtodieseling is offline
post #6 of 13 (permalink) Old 12-19-2007, 09:51 AM
Ditto here.
2003 KR F-250 4X4 CC SWB, 6.0, 5 Speed Auto, 3.73 Axle, no Limited slip. Rhino bedliner, Unicover bed cover.
Built on February 19, '03
#2 93 F-150 XLT, 5 Liter, Auto, 4X4, X Cab. 251,000 miles. Uses no oil between changes.
montanafan is offline
post #7 of 13 (permalink) Old 12-23-2007, 09:20 PM
Shell 5w-40 in winter and shell 15w-40 in summer. The engine will still run rough when cold, but it helped ours quite a bit.
Don't use Mobil 1, it is not designed for diesels and does not have the CI-4 rating. If you can find Mobil Delvac 1 then by all means as it is a diesel rated oil.
My Rigs:
86' F-250 XLT Lariat,6.9 Diesel, Extended Cab, 4x4, 4.10's, 8'bed, Push Button Glowplugs, etc...
99' Crown Vic Police Interceptor (P71) w/Steet apperance package, 4.6L, 4R70W, 3.55 Trac-Loc Differential (DK), Total Cloth Interior, New Honeycomb Grill, Black PI Trunk Bezel, Silverstars, 110K,
04' F-150 XL Heritage, 4.6L V8, 4x4, Ext Cab.
Fordiesel69 is offline
post #8 of 13 (permalink) Old 12-23-2007, 10:30 PM
snoboy's Avatar
How 'bout this...
http://www.mobil1.com/USA-English/Mo...uck_5W-40.aspx
-12/02 built 6.0
-FX4 Lariat supercab 4x4.
*Truck modifications*
-Banks turbo back exhaust
-DJs Fuel+ Intensifier fuel system
-SCT X3 DJs "tow w/ Jake brake"
-Dieselsite frame mounted coolant filter
-4.30 gears
-BD Diesel CCV kit
-Fumoto drain
-Autometer Cobalts in woodgrain pillars.
-Nitto Terra Grappler LT305/70/16
-Concept Patterns "burnished" F/R diff. covers.
-Ride-rite airbags
-KYB Monomax shocks
-Torklift Superhitch
-Current oil: Rotella T6 5w40
snoboy is offline
post #9 of 13 (permalink) Old 12-23-2007, 11:13 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: snoboy</div><div class="ubbcode-body">
How 'bout this...
http://www.mobil1.com/USA-English/Mo...uck_5W-40.aspx </div></div>
Very interesting, the data sheet looks like rebottled Delvac 1. I wonder how the price compares to the Gallon Delvac 1?
Mobil claims it is the same product after all.
http://www.mobiloil.com/USA-English/...rboDiesel.aspx
My Rigs:
post #10 of 13 (permalink) Old 12-23-2007, 11:14 PM
That stuff costs a bloody fortune I think it is 7 bucks a quart x15... I don't know anyone that rich...
post #11 of 13 (permalink) Old 12-25-2007, 02:28 PM
Not sure how much better delvac 1 is over Rotella T synthetic. Rotella is only $15 per gal.
My Rigs:
post #12 of 13 (permalink) Old 12-26-2007, 08:00 PM
i used to use the Mobil 1 Delvac 5w-40 when i worked my last job... they had it on the reel for the heavy equipment so we used it in our trucks... i used it year round and had no problems, summer or winter... i had better starting then, than with the motorcraft 10w-30 im using now. the one time i really used my truck and did some heavy pulling on some steep grades, in 85 degree, high humidity weather, the oil temp was at 225 and the engine at 226.. but thats the high as it got... "12,000 lbs, 33 lbs of boost, 3 gear locked TC, floored, going up hill at 69 MPH"= heavy towing im my definition..
2003 F-350 6.0L CC/SRW/SB 3.73 Auto..
Edge Juice Platinum w/ Attitude just to monitor
Xcal2 w/ID tow w/JAKE,Street,Extreme Street
K&N FIPK kit
NO TURBO or ELECTRIC PROBLEMS
3 injectors, 1 set of head gaskets @ 95,000 miles
rebuilt tranny, plates and soleniods
built 03/27/03
craigwe is offline
post #13 of 13 (permalink) Old 12-26-2007, 08:48 PM
Banned
10W-30 is good to 0F to -10F in the 6.0L. Below that and you want to use a 5W oil. 5W-40 Rotella at $15 a gallon makes sense there.
Gooch is offline
