Most use rotella or delo 15w40 and a fram filter (the fram filter is the same as motorcrafts filter complete with the same patent numbers) or you can just use a motorcraft filter. All of these are easily available at any walmart, side by side on the shelf.
Clean oil is the best oil. As long as it has the API certification for CF4 plus, CH, CI4-plus whatever Ford requires it should be okay. 15-40 is best protection. 5-40 is acceptable for low temp operation. Shell now carries the CJ-4 rating which is the newest out right now... - ROTELLA Products
2005 F250 FX4 SuperCab SWB in DSG
Buckstop rear bumper American steel!
Daystar baja bar with PIAA Racing 80's
Quad pillar Air, trans temp, pyro, boost
Magnaflow 15954, ATS studs
Transfer Flow 46gal midship tank
Firestone Airbags 2400 kit ViAir 250C compressor
Eaton TruTrac, Rancho 9000's, Skyjacker 1.5" rings
ViAir 380C@200psi, 5gal tank, Siege Anvil train horns say move *****!
Passed down to my step son: 2006 F-250 Lariat 6.0L Crew Cab, Black w/ Chrome package, Chrome bug guard and door latches
18" stock wheels, Nitto Tera Grappler, 4" Turbo Back MBRP, AccuFab Power Elbo, Edge Insight Monitor, Tinted Windows, Rhino Liner, Husky Floor Mats, B&W Turnover, Air Horn, ZooDad mod, Recon's all around
I ran Rotella 5-40 in everything from my ATV to diesel. Some company patented the 6 liter oil filter so they are ALL the same reguardless of who's name is on it...
Never heard of oil vapor locking...
What do you think the best motor oil is? I have 2003 6.0 F250 33000 miles on Her.
I've run nothing but DELO 400 CI & CJ 15W40 for 76k. I change at 7.5k intervals & take an OA to track fuel dilution. Blackstone says the engine is doing just fine, and the oil could go to 8k if I wanted.
If I lived in a cold place, I'd run Schaeffer's 9000 5W40 year around w/ bypass filtration & extend to 15k intervalls.
The 6.0 is notorious for shearing, but the Schaeffer's has shown itself very stable in a 6.0. The DELO does shear, but agian Blackstone thinks mhy engine is doing fine with it. It starts right up, doesn't smoke or surge & runs good.
OMC
I have run Schaeffer 9000 for 5 OCI's. The viscosity did indeed hold up well. The issue was that the last 3 analyses, the lead numbers have crept up (7-9 ppm from 1-2). They are not real high, but they are up. There are multiple other posts across the boards on Schaeffer 9000 and high lead (20-30 ppm on some). I have switched because of this (and before my lead goes higher). Valvoline Premium Blue Extreme 5W40 is highly recommended (but expensive).
I have run Schaeffer 9000 for 5 OCI's. The viscosity did indeed hold up well. The issue was that the last 3 analyses, the lead numbers have crept up (7-9 ppm from 1-2). They are not real high, but they are up. There are multiple othet posts across the boards on Shaeffer 9000 and high lead (20-30 ppm on some). I have switched because of this (and before my lead goes higher). Valvoline Premium Blue Extreme 5W40 is highly recommended (but expensive).
I agree with Bismic.
My lead #'s and now Iron #'s are creaping up with the Schaeffer's. Lead is 11 and my last Iron was 48. Iron and Lead are higher than I have experienced before.
I have tried Rotella T 5W-40 in the past and it gave more OK results.
I'm going to try Mobil 1 5W-40 for a few changes, and I'll post my results with this oil.
2006 F-250 Lariat 6.0L PSD,CC,SB,FX4, Black with the Chrome Package with Chrome Door Pulls. Smoked windows, Rhinolined, 4" Stainless Turbo-back Magnaflow exhaust, Zoodad mod., DEE ZEE mud flaps, CCV rerouted, High Idle mod., High beams w/Fog Lights mod, Sylvania Silverstars in Headlamps and Fog Lamps, Intake Elbow from intakeelbows.com, SCT X Cal2 programmed by Eric from Innovative Diesel, Dieselsite Coolant filter, Quadzilla Commander Monitor with Fuel Pressure Kit, Autometer Oil Pressure gauge.
2008 Ford Edge Limited. AWD, Vista Roof aka Big Ass Moonroof, Navigation System. Black with Chrome 20" wheels. It has ALL the Options for an Edge.
My other toys:
2006 Rinker 232 Captiva Liberty Edition Bowrider. White gelcoat with Red band in the middle. Fuel Injected 320 HP Volvo Penta 350 with duoprops and captians call exhaust.
2004 Jayco 27BH travel trailer.
2005 John Deere 5303 64HP 3cyl. Turbo Diesel Utility Tractor with 512 Loader/Bale Spike. Too many implements to list.
I have always heard good things about the Rotella T oil and use it in my Farm Tractors. However I know someone personaly who has used the Rotella in a new 6.0 Diesel and repeatedly had Injector O-Ring failures. After switching to Motorcraft Oil the problem went away. Anyone else ever heard of a specific Oil causing O-Ring failure?
Just switched from 10-30 regular oil(winter) 15-40 (summer) to Mobil Delvac 1 ESP 5W-40. That was the oil the dealer recommended. On my second oil change with it. My local shop(not dealer) who does my oil changes and anything not related to the motor(for now) is a BG dealer and I am running one of their additives. So far it's been good, starts well and runs good cold. Real test will be when morning temps get down below 50, don't think we're going to get them for a while. I do have a stiction issue but need cold temps to see if the oil helps and additive helps. Ran Hot Shot Secret with Ford 10W-30 in the winter and it ran great. Not easy to get HSS here in Canada.
Doug
2007 F-350 Crew Cab DRW 4X4 4.10LS, MBRP 4" Cool Duals turbo back, SCT/ custom tunes from Elite Diesel, Autometer gauges EGT, Trans, Fuel Pressure, MSD Dash hawk OBD II reader for ECT,EOT,Voltage and Boost, Dieselsite coolant filter,EGR delete
