When are you guys changing your air filter? - Diesel Forum - TheDieselStop.com
Old 11-27-2007, 03:04 PM   #1 (permalink)
I have been doing my fuel filters every 15k miles, oil and filter every 5k miles. Truck is a toy and doesn't tow or work in dusty conditions. (most of the time) When are you guys changing the air filter? That thing is huge! My truck is an 05 bought last year with 10k on the clock. (currently has 20k miles) The truck saw its fair share of dirt roads in VT before I bought it. Should I change the filter? I haven't torn it apart not that you can really "see" how dirty the filter is anyway. Thanks for all your help!
2005 F-350 CC PSD auto short bed, Titan 52 gallon fuel tank, MBRP turbo back, isspro boost, trans temp, EGT. aFe stage II, SCT from Innovative running extreme street(WOW!!).
2000 VW JETTA GLS TDI 5spd- MODS: RC3, TT 2.5" exhaust, Air Box Mod, Bilsteins, 17x7.5 RS4's, 51 MPG, 258,000 Miles and counting.....
2006 Honda Ody loaded. "The Man Van"
CHARRC is offline
Old 11-27-2007, 03:25 PM   #2 (permalink)
601HP's Avatar
Re: When are you guys changing your air filter?
I guess that depends on your driving environment. I changed mine with 15,000 miles on it, and felt like I did it too soon. The original looked nearly as clean as the new one I put in.
My next change will be somewhere between 20,000 and 25,000 miles.
David
2004 F350 Lariat, CC, LWB, 4x4, Dually, 6.0L w/ TorqShift, 4.10 LS, Dark Charcoal Gray, Permatech sprayed liner, A-pillar pod with 3 Isspro gauges, windshield-mount gauge pod with 3 more Isspro gauges, AIC, Jason cap, and PIAA fog lamps, mounted as aux. back-up lights. Billet badges. Alpine radio, a bunch of JL Audio and Sirius stuff.
<font color="blue">Photos</font>
601HP is offline
Old 11-27-2007, 03:31 PM   #3 (permalink)
i change mine when it gets dirty
chadjones99 is offline
Old 11-27-2007, 03:42 PM   #4 (permalink)
AllOutFirefighter13's Avatar
<span style="color: blue"> The manual says that one should do it every 30K miles. I currently have just over 75K on the truck, and I've changed mine at 30K and 60K miles, as required. On the back of the filter housing, there is a Filter-minder gauge, but I don't go by that. There is also a light on the dash that will illuminate, but I have only heard of maybe one or two instances of it coming on.
Some people go by the book and others go by the Filter-minder, so it's really up to you. I have heard that this filter (made by Donaldson) can hold quite a bit of dirt, but the main goal is to keep it out of the engine.
It would be nice if someone had data showing that the Filter-minder worked as it was designed to and that we could go by that...IMHO it would maximize the filter change intervals and potentially save money for the owner in the long run.
Later, </span>
Joey
* '04 F250 XCab LWB 4X4 w/ FX4 *
* TorqShift *
* Manual 4WD *
* Carpet Delete *
* No. 2 ONLY *
* High-Idle Mod *
* Fumoto Valve *
AllOutFirefighter13 is offline
Old 11-27-2007, 04:45 PM   #5 (permalink)
I changed my first at 15K. MISTAKE! They're expensive, and if it is the original blue-media filter, I have heard of intervals as high as 60K. Remember- a dirty filter will not allow dirt to pass through it any easier. It will actually filter better, but will restrict air flow eventually. The computer will compensate for this to a point, but even that convenience will go away over time. Stuff will begin to soot up, causing you inconvenience more than anything else. If your filter has been changed and it is the white -media filter, I wouldn't go much past 30K with it. Most folks I have seen on this site use the filter minder as a guide. I never bought into that myself, but there are many knowlegable folks that are doing it that way.
Red 2002 F-350 XLT SRW 4x4 7.3L reg. cab 6-speed rubber floors traded at 50K for:
Red 2005 F-350 XLT SRW 4x4 6.0L reg. cab 6-speed rubber floors BFG 12.5x35 mud-terrains, no lift traded for:
Red 2008 F-350 XLT SRW 4x4 6.4 reg. cab 6-speed. Got carpet this time- audiophile stereo deletes rubber floors. BFG 12.5x35 mud terrains, no lift.
Traded at 45K for: Red 2011 F-350 XLT SRW 4x4 6.7L reg cab BFG 12.5x35 mud terrains, no lift. "optioned" out of- stick shift, rubber floors, audiophile stereo, fog lights, chrome step bars GRRRRR!
torino73 is offline
Old 11-27-2007, 04:59 PM   #6 (permalink)
Black05's Avatar
I've changed mine every 35K miles. I drive in dusty dirt road conditions every weekend. At each change, the filter minder had not moved (even though it works)and I could have waited longer. My personal take is that 35k in dusty conditions is long enough, and I would rather err on the side of cleanliness!
Black/05/F350/XLT/CC/LWB/FX4/SRW/3.73/6.0L PSD/ TorqShift/Updated TBC/Upfitter Switches/SEIC Mod/Diesel Site Coolant Filter/Fumoto Valve/ITEC HFCM Drain Plug/Bilstein Shocks/BFG A/T 28565R18/Built September of 2004
Texas Proud.
God Bless our Armed Forces.
Black05 is offline
Old 11-27-2007, 05:55 PM   #7 (permalink)
I have seen a number of people talk about it, but I have never seen a 6.0L manual that states you should change the filter every "X" number of miles. Every manual I have seen says you should check the filter minder at every oil change interval and to replace the filter as necessary.
As far as taking it apart to "see" if it is dirty, well that is impossible by the design of the filter unless you want to get out a knife and literally start cutting it apart. The only real way to tell if the filter is dirty would be the filter minder or to do a flow test on the filter.
With all that said, I can assure you that the average person will get at least 60K - 80K out of the filter. Myself, I currently have over 97K on my filter. It will need replacement soon though.
All I can say is trust your filter minder, they do work. Here is a explanation on how the filter minder works and why it never seems to move.
http://www.filterminder.com/hfmw_air.asp
'04 F-250 Harley-Davidson 6.0L CC SB
PowerStrokeHD is offline
Old 11-27-2007, 07:23 PM   #8 (permalink)
your truck sounds like my 2006. I can tell you if you get this filter out when you put it back in make sure rubber is around the inlet tube, instead of in front of inlet blocking air. I had a ford dealer's shop do mine after motor change. Also if you take filter off I took clips all the way off because they get knock off while you are fighting this thing and they are really hard to find again.
kyjeeper is offline
Old 11-27-2007, 07:46 PM   #9 (permalink)
Going_Going_Gone's Avatar
I had new filters installed at 25,000 miles and again at 60,000 miles. This latest time, I weighed the new filter and the used one was less than a quarter pound heavier. I probably could have safely gone another 15,000 miles, but it is such a pain to install that I left the new one on. I think that I read somewhere that the factory filter will hold over 2 pounds of dirt.
December, '02 build F-250 CC 4X4 Lariat 6.0/Torqshift,Toreador Red over Arizona Beige 4X4 FX4 w/ moon roof. Stull grill insert, chromed tow hooks/bed tie downs, painted door handles, King Ranch flares, '08 aluminum differential cover, Inyati bed liner, Edge 3" lift Bonspeed eight spoke wheels w/BFG AT KO 305/65R18s Pics http://community.webshots.com/user/going_going_gone
Going_Going_Gone is offline
Old 11-28-2007, 01:16 AM   #10 (permalink)
Lightningfast01's Avatar
I have 65K plus on mine. I was thinking it was a 50-75K filter depending on your environment. The minder will do its job if you get a real clog. My truck still pulls 30 lbs of boost and burns clean and clear so I figure it is getting enough air. At 80 bucks a pop I am getting all the miles I can.
2005 F250 FX4 SuperCab SWB in DSG
Buckstop rear bumper American steel!
Daystar baja bar with PIAA Racing 80's
Quad pillar Air, trans temp, pyro, boost
Magnaflow 15954, ATS studs
Transfer Flow 46gal midship tank
Firestone Airbags 2400 kit ViAir 250C compressor
Eaton TruTrac, Rancho 9000's, Skyjacker 1.5" rings
ViAir 380C@200psi, 5gal tank, Siege Anvil train horns say move *****!
Lightningfast01 is offline
Old 11-28-2007, 01:26 AM   #11 (permalink)
Did mine at 10k, but had driven in a sandstorm and got worried----Supercrew632
2004 F250 Crewcab PSD FX4 Lariat--Oxford White--18" Stock wheels--Loaded--Grey leather--Bedliner--Chrome fender flares--3.73 rear end--6/21/04 build date--Custom Harley Flames just added!!
My other rides.....
2002 F150 XLT Supercrew, FX4 5.4l all stock
2001 F150 Lariat Supercrew 2wd 5,4l all stock
1995 Saturn SC1 SOHC 4 cyl.
1993 GMC Safari XT 4.3l 6 cyl.
1968 Chevy Camaro w/1989 Corvette 350 w 700r4 trans w/overdrive, Holley demon carb, mostly original.
2002 Wanderer Glidelite TT w/slideouts 26ft.
1974 Reinell Tri-hull openbow 165 horse OMC.
Cadillac Technician-A.S.E. Master and GM Master
Supercrew632 is offline
Old 11-28-2007, 10:29 AM   #12 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Going_Going_Gone</div><div class="ubbcode-body">I think that I read somewhere that the factory filter will hold over 2 pounds of dirt. </div></div>
It will hold 1300 grams or just shy of 3 lbs.
Old 11-28-2007, 03:05 PM   #13 (permalink)
JIM_C's Avatar
My Photos: (5)
I changed mine at 40k and that was way too soon.
2003 F250 XLT CC Long Bed 4x4, 6.0 w/Auto
JIM_C is offline
Old 11-28-2007, 06:09 PM   #14 (permalink)
37500 on mine and no sign of restriction, still running the factory blue media
wawrd1 is offline
Old 11-28-2007, 07:53 PM   #15 (permalink)
Check Mine at 15K. Air hose on white paper. Very litte and again at 30K. Same time just a little more.
As to coming out. Take out in one piece, by the Maps first big clamp, and it's know big deal. Re move return water hose and presser gauge on the back. Lift up for pins on the bottom. Comes right out. 3 min tops.
As fast has many after market. A better filter then most. Cheaper at 59.00 every 60k vs 400 after market box and filter. Plus warranty guys love it. Never any dirt in turbo pipe intake, and this is a winner on 6.0L. Zoodoo open open up in the grill for more flow.
06 Black Lariat Loaded /Auto/CC/SB/ChromePkg/TowCom/ Ordered 5/06/ BGF 325/60/20 on Jesse James 20"/ Harley Emblems.
BLEnt is offline
