Where are the ECT/EOT sensors located? - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 02-19-2011, 09:20 PM Thread Starter
Where exactly is the ECT monitored in relation to the oil cooler and coolant path? Same for the EOT, is it pre or post cooler? I ask because I see a much larger delta (11-13 compared to 7-8) if I cruise at 75 compared to 65 mph, loaded or unloaded. I'm wondering if my original 03 water pump might have some cavitation issues or loss of pumping capacity. My oil cooler is probably due for replacement but I'm still curious where exactly my Insight is pulling the data from.
03 F250 SD Crew, Fx4, Lariat-160K
02 F150 XLT Super Cab-135K
07 Toyota Highlander-35K
2Tight is offline
post #2 of 3 (permalink) Old 02-19-2011, 10:00 PM
ex mounty's Avatar
My Photos: (19)
Your ECT sensor (03 model) is just to the left of the thermostat housing on the front cover (looking at the engine from the front of the truck).
The EOT sensor is on the oil filter base . If you can find where the coolant hose for the egr cooler connects on that cover, the sensor is closer to the oil filter housing than that hose connector. The "oil pressure switch" is also located in that same area. The EOT has a larger oblong rectangle connector.
No longer a member of this forum
ex mounty is offline
post #3 of 3 (permalink) Old 02-20-2011, 08:39 AM
I believe the EOT has two wires and oil pressure switch has one wire??
06 F-250 x/c 4X4 sb 17" alloy wheels. Tri-fold tonneau cover, weathertech vent visor,Ford floormats and splash guards. HarleyD headlights, Duplicolor bedliner coated bumpers, 08 rear bumper and taillights, herculiner rocker panels, XM radio, bosch wipers, Recon smoked cab lights, Edge Insight w/EGT probe, winter front.
06/10 ARP studs, turbo back silverline, new head gaskets, new oil cooler, upgraded turbo drain, fuel pressure reg upgrade, coolant filter, high idle mod, harpoon mod, pre-pump spin on fuel filter,ELC coolant, 6.4 banjo bolts, CCV reroute.
Truck weight empty fueled up, 4440 Front, 3040 rear, 7480 gross. Hex VXCF4,
SCT w/customs tunes from Vivian at Quick Tricks and Matt @ gearhead
worldwide73 is offline
