Where to get block heater cord? - Diesel Forum - TheDieselStop.com
Old 11-01-2009, 10:22 AM   #1 (permalink)
Eli
Does anyone have a link of where to get a block heater cord for an 06 6.0? I have a truck that came from the south with no cord!
Thanks so much in advance....
Eli
06 XL 250 6.0 Auto 4x4 Shortbox, Ex-Cab, 94k miles, SCT with Magnaflow cat-back. Studs, oil cooler, egr cooler at 93k.
95 XLT SC 4X4, 3.55, 5 spd, 290k miles, Bullydog extreme chip, Maddog Stage II injectors, Bullydog Propane, Tymar Intake, 4" exhaust, Walker BTM,H-Max DP, exhaust brake, LUK, 2.5 lift with 285's on 8 Weld Typhoons/air bags.
Eli is offline
Old 11-01-2009, 12:35 PM   #2 (permalink)
Diesel Girl's Avatar
Eli
I bought mine from ebay it was around $10 if you order it from Ford it will cost $100. Actually I was told that the trucks didn't come with one that you had to buy one even if you bought it new. The guy I bought mine from didn't have one, he said it didn't come with one so then I bought one last winter. Good Luck, let me know if you need help finding one.
Cindy
2006 Ford F250 Powerstroke crewcab with 30,000 miles. 6" rough country lift with 4 link suspension, 20" Mickey Thompson wheel with simulated bead lock, 35" Mickey Thompson Tires with sidebitter. ARP Head Studs.
Diesel Girl is offline
Old 11-01-2009, 02:03 PM   #3 (permalink)
are you sure it isn't just tucked up thight behind the bumper. I couldn't find mine, and didnt' think I had one till someone showed me.
rujaynes is offline
Old 11-01-2009, 07:13 PM   #4 (permalink)
rock_doctor's Avatar
If you have the cord it will be behind the passenger tow hook. If you need to install one you can get it from any truck dealer, farm store or off ebay. Just order the one for the dodge Cummins. It is the same cord used in everything from Detroit Diesels to the Dodge Cummins to some of the John Deer tractors. Here is a link to install it although i would put it into a wire loom. Walmart has 3/8in loom that works nicely. Diesel Technician Society
Easy install, i did the one on my 6.4 and it took less then 10min.
2005 Excursion w/ 6.0L PSD
2008 FX4 F250 CCSB w/ 6.4L PSD
rock_doctor is offline
Old 11-01-2009, 07:18 PM   #5 (permalink)
ALR1955's Avatar
Send a message via AIM to ALR1955
Take a look at the lower right side of the engine for the heater probe. There is an amphenol plug on the side of the block where the heater cord plugs into. If there is a cap on the plug then you do not have the cord in the truck. I ordered mine from my local Ford dealer and got it in 3 days for about $70.00. My truck came from Florida originally and did not have one installed.
2006 F350 Lariat SDSC 4X4 DRW
4" Lift system w/ airbag leveler system
Bilstein 5150 shocks
Ameritrac LT235/80R17 tires
Banks turbo back 4" Monster exhaust system
AirAide Intake Filter
Accufab Polished Intake tube
AgriCover Bed cover
Romik SS Grill/Brush guard w/ PIAA Driving Lights
Kenwood 5120 Series Entertainment/Navigation system
Kenwood Sirius/XM Satellite Radio system
ALR1955 is offline
