Where's the oil sending unit? - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 10-03-2005, 02:00 PM Thread Starter
I need to find the oil sending unit on my 05 6.0L. Can anyone point me in the right direction? I've checked THE BIBLE and can't find any reference to the sending unit. Thanks.
2005 (Built 07/04) F-250 6.0L PSD Lariat/SRW/CC/4x4.
(Almost Stock: SEIC, Oil Bypass, Coolant Bypass,...)
ShotWho is offline
post #2 of 7 (permalink) Old 10-03-2005, 03:09 PM
My Photos: (21)
Re: Where's the oil sending unit?
Right here, item 5
O
02/03 built
6L, DRW,
, 4" DPPI Exhaust, UltraLites on the
and
, Firestone Bags & Compressor,
, 50 Gallon Transfer Flow, Racho 9000's, Leveled 2.5/0,
, XM Commander.
ozhoo is offline
post #3 of 7 (permalink) Old 10-03-2005, 06:08 PM
Its easy to confuse the sending unit with the pressure switch. The sender is on the firewall side of the oil filter. The switch is left or toward the passenger side. There threaded different too. The pressure switch is some hybrid thread no one I know has every seen. Pressure sender is #4 "hydralic" thread.
Wekiwa
2005 F250 CC SB 4x4 6.0 auto
Banks Big Hoss & K&N air kit & Xcal2 tuned.
Reg Return system with slighty larger injectors
A little turbo tweaking
Modified V-pipe and up-pipe assemble
Ceramic coated most stuff
Bypass oil filter kit
Black on Black
Wekiwa is offline
post #4 of 7 (permalink) Old 10-04-2005, 03:16 PM
Sorry, but I am a little confused as to the terminology being used here. I know where the oil pressure switch is located (see above link to Bible part #5), but where and what is the oil sending unit located?
Thanks,
Chris Turrisi
05 Excursion Ltd 6.0 - PSD Door Badges, BFG T/A KO 285/75-R16 Tires, C-Bet'r Mirrors, Catch-All Mats, ISSPRO EGT/Boost A-Pillar Mntd Guages, The Diesel Site Coolant Filter, Underhood Insulation & Weather Strips, Factory Mud Flaps, 22" Wipers, Valentine 1, Over Mirror Mntd ISSPRO Oil Temp, Oil Press, Volts, Diff/Tranny Temp Gauges, Custom Carling Switch Panel, KC back-up lights, Super-Springs, Custom 12v Power Outlets, Door Courtesy Lights, Vinyl Tubed Door Seals, Dynamat Extreme Everywhere, LED's in Door Handles, Amber Turn Signal Tail Lamps, PML diff & tranny covers, Fluiddampr, AFE Stage II Intake, LED TMI Tail Lamp & Rear Amber Turn Signal Bulbs, Cab Lights, Rancho Steering Stabilizer, RS9000 Shocks, V-Code Front & S-Code Rear Springs, 4.30 Gears, Edge Attitude, MBRP 4" Exhaust.
cturrisi is offline
post #5 of 7 (permalink) Old 10-05-2005, 01:10 PM Thread Starter
Thanks Wekiwa. Found it.
I'm thinking about tapping into the sending unit with a "T" fitting to pickup a supply for bypass oil filtration. I'm a little concerned about the ECM getting accurate oil pressure readings after installing the "T". Any thoughts?
ShotWho is offline
post #6 of 7 (permalink) Old 10-01-2010, 07:30 PM
stripped threads
I have a 2005 F250 6.0 that when I went to change the oil presure sending unit I found the threads inside the plate are stripped. Any suggestions?
skofca is offline
post #7 of 7 (permalink) Old 10-02-2010, 06:58 AM
Someone correct me if I'm wrong, but I don't believe that the ECM monitors low-pressure oil pressure. The sender is simply an on-off switch that activates when it reaches 7 psi and directly connects to the oil gauge on the dash.
2004 F-250 Lariat CC, Short Bed, 4x4, 6.0L, TorqShift, FX4, Metallic Green/Arizona Beige, Medium Parchment Leather, Fumoto, B&W Turnover, A.R.E. LSX Tonneau, Built 4/01/04
MoeB is offline
