Where is the Starter Solenoid? - Diesel Forum - TheDieselStop.com
post #1 of 14 (permalink) Old 11-05-2011, 06:36 PM Thread Starter
On a 2004 F-350 6.0L Powerstroke.
Mebbe I'm missing something, but I can't find it.
Is it part of the starter itself?
I can hear it click, but I can't track it down.
Truck clicks once on turning the key, and nothing else happens, batteries are fine, I have a power controller in the cab and it reads 12.5-13.2v.
It's gotta be either the solenoid or the starter, and the solenoid is the cheaper solution first.
Thanks in advance.
2004 6.0L F350 Super Duty FX4
2009 Head Gasket
2010 Full Injectors
2011 Starter
Greatfoot is offline
post #2 of 14 (permalink) Old 11-05-2011, 09:40 PM
Yes its on/part of the starter.
06 F-250 x/c 4X4 sb 17" alloy wheels. Tri-fold tonneau cover, weathertech vent visor,Ford floormats and splash guards. HarleyD headlights, Duplicolor bedliner coated bumpers, 08 rear bumper and taillights, herculiner rocker panels, XM radio, bosch wipers, Recon smoked cab lights, Edge Insight w/EGT probe, winter front.
06/10 ARP studs, turbo back silverline, new head gaskets, new oil cooler, upgraded turbo drain, fuel pressure reg upgrade, coolant filter, high idle mod, harpoon mod, pre-pump spin on fuel filter,ELC coolant, 6.4 banjo bolts, CCV reroute.
Truck weight empty fueled up, 4440 Front, 3040 rear, 7480 gross. Hex VXCF4,
SCT w/customs tunes from Vivian at Quick Tricks and Matt @ gearhead
worldwide73 is offline
post #3 of 14 (permalink) Old 11-05-2011, 09:58 PM Thread Starter
Thanks.
I just wanted to be sure, some people were telling me it was on the fender, but from what I could see, it wasn't.
I thought it was that bit on the starter.
Further to the description:
I was in a parking lot and went to start the truck, it turned over for a very brief second, as in I could hear everything turning that turns in a normal start, then nothing, even with the key still turned over.
A normal start - whirr-rrr-rrr-vroom!
What I got - whirr-(then nothing)
I cycled the key, and got only the single click.
Is the 'single click' indicative of starter, or solenoid failure?
It's dark here now, so in the AM I will crawl under the truck and check all the wires and leads before I pull it, and I will check back here as well.
I assume the solenoid can be removed/replaced on the starter without having to replace the whole starter.
Like I said, beginning with the cheaper fix first.
Thanks again.
2009 Head Gasket
2010 Full Injectors
2011 Starter
post #4 of 14 (permalink) Old 11-06-2011, 11:33 AM Thread Starter
So, I've read in the Hayne's Book that there might be a Starter Relay as well.
(And I'll probably get flamed for reading Hayne's)
But, do I have one on this truck?
And if I do, where is it?
I wanted to ask before I pulled the starter off.
In terms of solving this starting problem, is this the path I want to follow:
Relay (if there is one)
Solenoid
Starter
Thanks again.
I was just under the truck and it is definitely the single click at the solenoid.
2009 Head Gasket
2010 Full Injectors
2011 Starter
post #5 of 14 (permalink) Old 11-06-2011, 03:02 PM
klhansen's Avatar
My Photos: (180)
Yes you have a starter relay. Before the 02 models, it was mounted on the passenger side fender (that's the solenoid people were telling you to look for). In 02 and later trucks, the starter relay moved to the fuse/relay panel under the dash. Should be in your owner's manual (if you can't locate yours, check here: http://www.thedieselstop.com/faq/949...20Printing.pdf - it's for an 03, but should be the same).
You should also check your shifter position. Try moving it to neutral instead of park, or shove it further up past park while trying the key. Sometimes they get out of whack, and will prevent the starter from energizing. (assuming you have an auto trans here - probably an 80% chance.)
Good luck with it.
[on edit] Just saw that you verified the solenoid on the starter was clicking, so that or the starter is your problem. You can disregard the relay and shifter.
), AIS,
regulated return,
klhansen is offline
post #6 of 14 (permalink) Old 11-07-2011, 09:10 AM Thread Starter
Well, gonna pull the starter this morning, at $90/hr+ shop rates, I'll suffer. But they certainly didn't do anyone any favours with that top bolt. Gotta see if I have a knuckle for my wratchet somewhere, if not, one click at a time to get that bolt out.
I'll keep that 'neutral start' thing in mind for future reference, though, good stuff to know.
Thanks, I'll let you all know how I make out.
2009 Head Gasket
2010 Full Injectors
2011 Starter
post #7 of 14 (permalink) Old 11-08-2011, 08:22 AM
Bully Joe's Avatar
Any progress made?
klhansen-thanks for the neutral tip.
Bully Joe is offline
post #8 of 14 (permalink) Old 11-08-2011, 01:35 PM Thread Starter
The starter is done. Aside from that pain-in-the-butt top bolt, it was a straight forward swap out.
Starts like nobody's business now. 7 years on the original starter I guess is good enough.
Thanks for all the help.
2009 Head Gasket
2010 Full Injectors
2011 Starter
post #9 of 14 (permalink) Old 01-24-2014, 02:39 PM
2004 6.0 F-350 Diesel Dually
When I try to start my truck, all I hear is the relays in the fuse box clicking and that's it. Pulled starter and had it tested at O'Rielly's...good. Replaced positive battery to battery cable, cleaned posts on batteries, replaced fuel filters, checked all the fuses and relays and still nothing. This is my first diesel and had about 1.5 yrs now and had issues with injectors first month I owned it then again 6 months later. Not sure what to do...any help would be very appreciated!
2004 6.0 VICTIM is offline
post #10 of 14 (permalink) Old 01-24-2014, 05:52 PM
dieselmac's Avatar
Have you had your batteries tested?
Scott
SOLD -- 2006 F-250 PSD, Lariat
Mods: All the usual stuff
2015 F350, 4x4, Platinum
"Let us endeavor so to live that when we come to die even the undertaker will be sorry" - Mark Twain
dieselmac is offline
post #11 of 14 (permalink) Old 04-23-2015, 07:53 PM
This same thing has happened to me, I am new to the diesel world and I don't want to pull the starter, if I don't have to was there ever a solution?
Cojack is offline
post #12 of 14 (permalink) Old 07-04-2015, 03:06 PM
Happened to me yesterday as well. I drove to a store and turned off the car. Came back in less than 5 mins, turned the ignition, and just got a audible click (may be relay?) but nothing turning from the starter. Had it towed back to my house last night.
This morning, I replaced the starter (+solenoid) w/ a Napa Premium Starter (new w/ lifetime warranty) thinking that was it. To my surprise, it still won't start (same exact thing). I bridged the positive posts on the starter motor and solenoid and it does spin/engage.
I've verified the batteries and connections are good.
Anyone with ideas what else to check?
2005 Excursion Eddie Bauer 4x4 6.0l PSD
jackles is offline
post #13 of 14 (permalink) Old 07-04-2015, 03:27 PM
Did you reattach the solenoid signal wire from the ignition switch. Small wire on a terminal by itself on the solenoid head.
dannyboy950 is offline
post #14 of 14 (permalink) Old 11-05-2015, 09:46 AM
Same thing happened to my wife last night. Drove fine down to horse show and went to start to leave and nothing. Luckily friends were there to help. They jumped the solenoid to get it to start so she could make it home. So at least i know the starter is good. I would assume that leaves the relay, the solenoid, and the shifter position switch, is that about it or is there something else i should check? Is it possible to just change the solenoid or do you have to change the whole starter? If it is the shifter position switch, how do you get to it to check the alignment? By the way, i have a 2007 F350 6.0L
Steved80 is offline
