Whine/whistle - Diesel Forum - TheDieselStop.com
post #1 of 24 (permalink) Old 06-30-2011, 10:08 AM Thread Starter
fordnatic68's Avatar
Whine/whistle
Ive picked up a new sound Im not 100% sure what it is. While driving under load boost aroud 10 psi+ I get a whiney type of whistle. If I step on it more it increases, back off it disappears. Ive de tuned my truck but leave the Edge in for monitoring as I have my dash apart moving guages off the a pillar to the dash to eliminate that big blind spot. I dont have the issue when in low tune modes. The other thing is recently while dragging my 27" travel trailer home I noticed my coolant temp rose dramatically on hills but would quickly come down. While driving normal with no load it stays at normal temp 180-190. My EOT stayed down low and only rose slightly in those circumstances. Im gonna just say I think my headgaskets are starting to let go but just wanted to hear if anyone else had a similar experience.
Thanks, Ron
03 F350 6.0 XLT Lariat Born 12/21/02 Crew cab short box loaded to the nuts
Autometer Guages - Pyro, Boost, Tranny, Oil Temp, Oil pressure,F & R Diff Temp,Voltage, Fuel & HPOP
Custom dash mods to clear up clutter ontop and eliminate blind spot at A pillar
Edge juice w/ attitude ( unlocked)
Banks Intercooler, Hi ram intake n tubes
Twin Optima yellow tops
BD 5" exhaust
Snow Performance Water/Methanol injection w 7 gallon tank (water only)
EGR Delete Kit
Silverline twin 8" slash cut stacks
New stock Ford Hpop
New stock Ford oil cooler (waiting for BD's version of remote cooler filter kit)
Garrett Powermax GT3788VA Turbo
Airaid cold air intake
Zoodad mod
10.5 " Procomp lift (really 8.5 w some mods)
42" good year wranglers w Kevlar sidewalls
5" Bushwacker cut out Flares
Goodhood Dual ram air fiberglass hood from US body
90 F250 Extended cab long box 460 auto
57 Mercury stepside
fordnatic68 is offline
post #2 of 24 (permalink) Old 06-30-2011, 08:06 PM
speedrcr78's Avatar
Yeah thats what it sounds like. That sucks.
speedrcr78 is offline
post #3 of 24 (permalink) Old 06-30-2011, 08:42 PM
the deguas coolant Cap can make a noise , also slight rip in intercooler boots.
2000 f350 7.3 ccab 4x4 auto , DpTuner, AIH Delete, 4" Magnaflow . Only 130,000 miles on it.
and
2001 Ram 2500 auto w/cummins
24hrsparkey is offline
post #4 of 24 (permalink) Old 07-02-2011, 11:41 AM Thread Starter
Im hopin its the cap or boots, Ive had it apart so many times a boot would be likely. but if it was the cap that would also be an indicater of the head gaskets going, would it not? I show no signs of oil in coolant or coolant in oil. It runs good operates at proper temps, only thing is the whistle and higher than normal temps when pulling hills. I wonder if my fan is coming on when its supposed to? I havnt heard it recently and you can usually hear it.
BD 5" exhaust
EGR Delete Kit
New stock Ford Hpop
Zoodad mod
57 Mercury stepside
post #5 of 24 (permalink) Old 07-02-2011, 12:07 PM
dieselmac's Avatar
A boot or cap wouldn't really explain the quick rise in coolant, though. I'm guessing your rise in coolant temps trended along with rises/falls in EGT's?
Might use one of those tester kits to see if you have had exhaust in the coolant.
Scott
SOLD -- 2006 F-250 PSD, Lariat
Mods: All the usual stuff
2015 F350, 4x4, Platinum
"Let us endeavor so to live that when we come to die even the undertaker will be sorry" - Mark Twain
dieselmac is offline
post #6 of 24 (permalink) Old 07-02-2011, 12:07 PM
when you say higher than normal temps pulling a hill how high of temps are you talking about?also how long and steep of a hill?
2005 F-350 6.0 XLT crew cab FX4 4x4
51k on New motor,123k on truck
scangauge II as guages
Blue spring upgrade
4" turbo back MBRP
Zerex CAT EC-1 coolant
K&N cold air intake
Build date of 01/2005
2008 30' zinger TT
neal8809 is offline
post #7 of 24 (permalink) Old 07-02-2011, 08:42 PM
does it sound like this?
if so, your turbo is done.
2007 F250 CC Lariat
SCT X3 with Matt's custom tunes
ARP Head Studs
Black Onyx Head Gaskets
Sinister EGR Delete
Sinister Coolant Filter
Powermax Turbo
Edge Insight w/pyro & Fuel PSI
MBRP 4" Straight pipe
Rotella ELC and T6
sly1types is offline
post #8 of 24 (permalink) Old 07-03-2011, 01:03 PM Thread Starter
Ya very much like that.
BD 5" exhaust
EGR Delete Kit
New stock Ford Hpop
Zoodad mod
57 Mercury stepside
post #9 of 24 (permalink) Old 07-03-2011, 11:51 PM
Double check your up pipes for leaks, but from what I found out it's usually your turbo on it's last leg.
Mine was only making the noise at 13lbs or more.
Did your Powemax always make this noise or did it just start?
There were a few people that told me my whistle could be leak up pipes, but it turned out the turbo was done on my truck.
How old is your powermax?
2007 F250 CC Lariat
ARP Head Studs
Sinister EGR Delete
Powermax Turbo
Rotella ELC and T6
post #10 of 24 (permalink) Old 07-04-2011, 10:28 AM Thread Starter
This is a new turbo maybe 2500km or less, im gonna look over up pipes and boots real closely. temps are strange tho too my fan doesnt seem to be coming on.
BD 5" exhaust
EGR Delete Kit
New stock Ford Hpop
Zoodad mod
57 Mercury stepside
post #11 of 24 (permalink) Old 07-09-2011, 12:27 PM
My Whine/whistle
I have a 2005 F-250 and had a simular problem. When towing my rv, the engine temp would clime when pulling a hill. The fan would engage with
a loud fan noise then the fan noise would stop then and I would hear a loud whistle. This would cycle about every 20 sec. until I topped the hill and engine temp went down. The truck had done this since new and the
dealer could not find anything wrong.
I took it to a local dealer in AZ. and he said the belt was slipping. I did not think this was the problem as the whistle did not sound like a belt
noise. He pluged in his laptop and brought rpm to 2500 and fan to
full engagement and this was the whistle I was hearing.
Ford replaced the water pump pulley and belt. No more problems!!!!
(f)5c3z8509A Pulley - water
JK81267A (V-Belt)
1diesel_dog is offline
post #12 of 24 (permalink) Old 07-09-2011, 01:42 PM Thread Starter
Did the waterpump last year but belt is due forsure, ill look at it closer and see what I can find. Driving in town or on the highway is fine, it runs at proper temp unless i put my foot into it. Only when under load ie towing, pulling hills or hard acceleration does it climb. It loses no coolant from degas or anywhere else. It idles at proper temp sitting in the driveway. A buddy of mine has an 04 and is having issues with his fan not engaging period. Mine does spin at a low speed but I havnt heard it come on at a high speed. Odd forsure. thanks again for any info.
BD 5" exhaust
EGR Delete Kit
New stock Ford Hpop
Zoodad mod
57 Mercury stepside
post #13 of 24 (permalink) Old 07-09-2011, 05:01 PM
dieselmac's Avatar
Is your EGR valve still plugged in?
Scott
post #14 of 24 (permalink) Old 07-09-2011, 05:06 PM Thread Starter
its plugged in but coolers deleted
BD 5" exhaust
EGR Delete Kit
New stock Ford Hpop
Zoodad mod
57 Mercury stepside
post #15 of 24 (permalink) Old 07-09-2011, 05:08 PM Thread Starter
this is a very recent issue, noticed when bringin my trailer up from vancouver. 300 miles through mountainous terrain. The whine has been there since I did the turbo, i just have been detuned so didint notice it.
BD 5" exhaust
EGR Delete Kit
New stock Ford Hpop
Zoodad mod
57 Mercury stepside
