White Smoke after Exhaust Installed???
I installed a 5" Magnaflow Exhaust on my Truck 2 weeks ago and deleted the Meeowww, ever since been noticing white smoke coming out of the tail pipe, mainly when warming up bit still some occasionally here and there. Prior to install, never noticed a hint of white smoke. Exhaust emits a funky smell that doesn't quite smell like the diesel i've been accustomed to smelling. Hoping it has something to do with a drop in back pressure affecting the computer inability to adjust. Picking up a 6-Gun, any possibility this may help to cure the computer not being able to adjust if this is the problem? I appreciate your input....Mahalo
1996 Ford F350 4x4, Crew Cab, 8' Bed, 5spd, 7.3 Powerstroke with 141K Miles as of January 2012.
Current Mods:
Custom DP Tuner 60/80/120/EB
Magnaflow Downpipe Back 4" SS Exhaust w/5" Tip
Upgraded Stock 15Deg to 17Deg HPOP by Terminator Engineering.
Upgraded Viton O-Rings/Fuel Lines from Diesel Orings
FPR Upgrade to California Spring Kit
Poly Body Mounts.
SKY Man. 3" RSK, Bilstein 5100's, Adjustable Panhard Rod, Pitman Arm.
35x12.50 BFG T/A KO's All Terrains on 16.5x9.75 Eagle Wheels.
Steel Braided Brake Lines, Ceramic Brakes.
Planned Mods:
Custom Paint, 3" Downpipe, Intercooler, Larger Injectors, Turbo, Custom Grille, NFab Cab Steps, Interior ReDo, Gauges, Bed Spray, Rebuild Trans, Stage 2 or 3 Clutch and More...
