white smoke/cold weather-low delta-coolant loss - Diesel Forum - TheDieselStop.com
Old 11-30-2012, 09:40 PM   #1 (permalink)
As title says Im getting white smoke when its cold out (not just at start up) loosing coolant (no puking) Deltas still good.Was in east Tenn.working had to bring 30' TT home and Deltas ran 8 to 11 max. So Ive got all kinds of things running through my head,
??? EGR cooler??? HEAD GASKETS???
no water in oil, not puking,deltas good, are my low coolant temps related?
Do I order studs and gaskets and tear in? What do I do to diagnoise, or tear in and test coolers and do I delete or put in BPD egr cooler if its bad
06 F250 XLT sc sb /w 200,000plus miles
tow pkg.
snow plow pkg.
upfitter /w
high idle mod
back up camera
rear back-up lights
Blue spring and banjo bolt mod
Edge insite cts
new interstate batteries / may have hurt FICM
only Ford filters
Flushed/ CAT coolant
low coolant temps
two new thermostats
new coolant senser/ still LOW COOLANT TEMPS
mobile one oil/ going back to rotella T-6
REV-X / helped stiction
ARCH OIL AR 9100 /stiction cured so far 27*
ARCH OIL AR 6200 / @ 2 mpg increase
2stroked out is offline   Reply With Quote
Old 12-01-2012, 01:09 PM   #2 (permalink)
Any sugestions guys. can it be diagnoised or do I have to tear in. Help
tow pkg.
snow plow pkg.
upfitter /w
high idle mod
back up camera
rear back-up lights
Edge insite cts
only Ford filters
low coolant temps
two new thermostats
Old 12-01-2012, 07:45 PM   #3 (permalink)
Feedback Score: 2 reviews
What kind of numbers do you have, how low is the coolant temps should be 190-192* EOT 196-198* these are my number then when pull my 14k 5er add 10* to eack on average. Running cold is not good. Does the smoke smell sweet antifreeze or like fuel.
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS with Expandable pyro
AutoMeter Fuel Pressure Gauge 0-100
Sinister Fuel Pressure Adapter
Updated Fuel Reg. Kit 3C3Z-9T517-AG
WOT 58lbs Idle 62-64lbs Just Right
HFCM Water Separator Drain Plug Upgrade
Ford Cetane boost every fillup
Amsoil By-Pass(Amsoil 5w40)
Fumoto Oil Drain Valve
Dieselsite Coolant Filtration System
Dieselsite Boots
Delo ELC Coolant
Tow Command
Upfitter Switches
Pulling a 14,000 lb Alpenlite 5er
Roll-N-Lock bed cover
97 F350 4x4 PSD CC LB (sold it)
1700 Super Chip
PacBrake&ATS converter lockup
3" dp-4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A pillar EGT,Boost,Trans
2 Stroker is offline   Reply With Quote
Old 12-01-2012, 08:55 PM   #4 (permalink)
Supporting Member
GIJOE0916's Avatar
Just wondering!
What are you refering to when you say Deltas?
GIJOE0916 is offline   Reply With Quote
Old 12-01-2012, 09:20 PM   #5 (permalink)
GI JOE Delta = the difference between ECT, engine coolant temp and EOT, engine oil temp. Ect runs as low as mid 160s when in upper tweenties to about 185 when in the eighties. exhaust has a funny smell dont know if its coolant or fuel additives. To me diesel dont smell like it did before ULSD, just like ethonal gas dont smell the same. If it was auto antifreeze I think I could smell the difference but not sure about this Cat coolant. Oh need to add to signature degas cap replaced this summer ,When I was chasing the low temps , ( not loosing coolant then.) 2 stroker how would you procede ?
tow pkg.
snow plow pkg.
upfitter /w
high idle mod
back up camera
rear back-up lights
Edge insite cts
only Ford filters
low coolant temps
two new thermostats
Old 12-02-2012, 12:00 AM   #6 (permalink)
To start with if it is coolant it will smell sweet it not could be a bad injector (fuel) and your coolant temps are way to LOW stuck open. A stock Ford t/stat STARTS to open at 192.2* and is FULLY open at 219.2*. You could pull the egr valve and check when it is cold if it is damp or wet you have a bad egr cooler.
2 stroker
Dieselsite Boots
Delo ELC Coolant
Tow Command
Upfitter Switches
1700 Super Chip
3" dp-4" exhaust
Tymar Intake
Old 12-03-2012, 12:56 AM   #7 (permalink)
Got a wiff of coolant in exhaust to day. Have ran the tank low and only added small amounts of fuel,with no additives, then filled it today, and got the smell. I guess cetane booster was masking smell. So I have coolant in exhaust. Been searching boards and watching you tube vids. Trying to get a handle on what all I need to do. Thinking studs and gaskets. Not sure how I want to handle the egr. If money was no object I would do something similar to the IRP kits, W/full flow coolant filter before oil cooler. THen centrifical oil filter. But may go cheaper route.I like the idea behind the IRP kit. But not sure. Got a lot of part numbers, dummy plugs,gaskets, sct fitting. Did'nt find anything for turbo drain or oil tube. Need a list of all that stuff, preventive maintance stuff and how much is really needed and what is just fluff.Wish Ford had fixed more of that kind of stuff. On the ECT I know its to low. But cant figure it out. Changed thermostat (twice) changed temp senser, have new degas cap. when I did my flush , I put in new water pump. just cant figure out what else could be causing it. Also can put card board in front of radiator and get temps up but has to be almost completly covered.This was when I was doing my flush,and when temp went up deltas went to 2 or 3 degrees. I will order another thermostat when I place an order to Tousley for all the ford stuff I'll need . I'm planning on doing the work myself. tempted to dig in and test as I take stuff out. Just afraid EGR cooler would be one of those craks that only leak when the superheated exhaust goes through. Hell I had a leak in a car that would let the antifreeze by but not the water.would put 50/50 in and it would delute till it was almost all water. So I'm used to wierd stuff happening.
tow pkg.
snow plow pkg.
upfitter /w
high idle mod
back up camera
rear back-up lights
Edge insite cts
only Ford filters
low coolant temps
two new thermostats
