Whooshing Noise On Heavy Acceleration 05 6.0 - Diesel Forum - TheDieselStop.com
Old 02-25-2009, 01:09 AM   #1 (permalink)
I have a 05 powerstroke on which i just installed PPE tuner and a 4" MBRP exhaust.
When I "encourage" the truck to go fast, it makes a loud whooshing noise, it does not do this unless i really get on the throttle. It also seems to lose acceleration whenever this noise is present, but the boost gauge doesn't change. A buddy of mine told me it was the wastegate, but I figured I would get an expert opinion. Has anyone else encountered this issue? It is normal? Or is something wrong?Before anyone says its a leak, I have checked and re-checked all clamps and pipes and it sounds as if it is coming right from the turbo. Thanks!
mylawn03 is offline
Old 02-25-2009, 10:53 PM   #2 (permalink)
i dont think the 6.0 has a waste gate. i herd its just a varible geomatry turbo.
odools is offline
Old 02-26-2009, 02:33 PM   #3 (permalink)
dbennett48's Avatar
You have a leaking hose in the intake tract. Check the big hose clamps for tight and look at the blue hoses for splits. You generate boost when you are on the throttle and what you are hearing is the boosted air. You should not hear this.
Dave
2004 F-350. Standard Cab, 4X4, 6.0 with Torqshift, 3.73 w/LS. <font color="red">(((XM))) Satellite Radio.</font> Lo Jack, 6608 lbs wet. Born on 8/4/2003. Engine 07/23/2003. 3" Lift. Grover Air Horns!!!
http://community.webshots.com/album/85108545NlXNsD
1993 F-350 4X4 7.3 IDI with 5 spd. Gone now.
1976 Kenworth C-500 with Detroit Diesel 8V92TA with 3 spd Jake, SQHD's and RTO 12513 10 Wheel Dump Truck. Sold.
dbennett48 is offline
Old 02-27-2009, 04:31 PM   #4 (permalink)
Ok, so i've checked everything. I tried putting the computer back to stock and it no longer makes the noise..wondering if maybe this programmer does more harm then good. It seems the higher level I put the programmer, the louder the noise gets. Any ideas?
mylawn03 is offline
Old 02-28-2009, 01:00 PM   #5 (permalink)
As Dave has said, you have a leak on the pressure side of the system. Check all of the hoses and clamps again. Also, check the intercooler as it may have a split in a tank seam.
'06 F350 Lariat SRW X-cab,4X4,Torqshift 5-speed Auto,w/23000lb GCVWR and many other options, Vandal Alert Cyclops, Pressure Pro TPMS, Extang Tuff TonnoIII, Duraflap mud flaps and Roadwing mud flap system, towing a Hitchhiker 33' Discover America 5'er and a Lund boat. Stock and doing fine. Coolant filter, Fuel regulator upgrade.
bobsherrie is offline
Old 03-02-2009, 01:49 PM   #6 (permalink)
Took the truck to the dealer and when they couldn't find a problem or any codes, I personally inspected all the intercooler tubes and the intercooler itself and I could not find a leak. I'm stumped. I did however order an SCT livewire from innovative diesel and I'll see if it does a better job of tuning the truck then the PPE.
2005 F-250 4X4 Crew Cab Powerstroke all black
2" Lift
35" cooper all-terrains
4" stainless MBRP
PPE Tuner
1997 F-250 4X4 Ext. Cab Powerstroke white
2" lift
285 Toyo Open Countrys
Ol' Reliable
Straight-Piped
Edge Tuner + a few other mods
mylawn03 is offline
Old 03-03-2009, 08:48 AM   #7 (permalink)
hottip's Avatar
Vgt
I think Odools has the answer. Most likely it is the VGT and that prevents the turbo from overboost.
2005 Lariat 6.0 LWB fourx4 3:73 Silver Metalic, Heated Captains chairs, Tow Command, Reverse Sensor, Intergrated Brake Control, Power Rear Window
MBRP Turbo back exhaust, Glasstite Canopy, billet grill, 145K+
Scan Gauge 2
Lucy - Wife
Bear - Flat Coated Retriever
2000 HD Road King
1998 Campion 542 Explorer fishing machine
I started out with nothing and still have most of it left....
hottip is offline
Old 03-03-2009, 08:59 AM   #8 (permalink)
WDP
Haven't heard a boost leak yet, I had a whistle (swoosh) on hard running. Turned out to be the coolant resevoir cap not holding pressure. Cheap and easy stopped the whistle.
WDP
WDP is offline
Old 03-03-2009, 10:23 AM   #9 (permalink)
dwc032's Avatar
Im sure you know this, but puting a tuner, even the lightest of tune and the 6.0 will be blowing headgaskets, turbos and lots of other things. Like hottip said its probably the VGT which prevents the turbo from overboost. My buddies 6.0 has an edge tuner on level 1 and it has completly eaten that motor up. Probably doesnt help that he is on it all the time.
Never shall I fail my comrades. I will always keep myself mentally alert, physically strong and morally straight, and I will shoulder more than my share of the task, whatever it may be. One hundred percent and then some.
dwc032 is offline
Old 03-04-2009, 01:09 AM   #10 (permalink)
Is it possible that it could be the exhaust back pressure valve closing? Has anyone encountered this?
2" Lift
4" stainless MBRP
PPE Tuner
2" lift
Ol' Reliable
Straight-Piped
mylawn03 is offline
Old 04-02-2009, 02:34 AM   #11 (permalink)
WDP
This!! It is the cap on the Degas bottle blowing off pressure.....which means you most likely not only need to get a new cap, but a new bottle too.
2004 6.0Powerstroke ExtraCab. Indigo Blue over Tan, Super Chip, AT's
2007 6.0Powerstroke CrewCab. Silver, Chrome package, SuperChip, MBRP Cool Duels Turboback
Burper/Puker
2 Degas Bottles, 3 Degas caps, 1 EGR Cooler, 1 Oil Cooler, 2 O-rings.....still puking.....
Also, two speed sensors, and about 13 damn tail light bulbs.....
StrokinTiger is offline
Old 04-02-2009, 02:36 AM   #12 (permalink)
Your buddies edge only ate the motor up faster than it would have eaten itself up......
With the Edge Platinum you get the turbo cool down timer....which even with the extra hp is better on that turbo than straight stock is when you cut off the truck with a hot turbo and motor.
Burper/Puker
Old 04-02-2009, 12:48 PM   #13 (permalink)
tvandyck7's Avatar
I love the "death by tuner" speech. I have had a Bully Dog PMT on my '04 6.0L since Dec. 2007 and have run the living dog crap out of my truck. I haven't given it much mercy and it has has no issues caused by the downloader. It really depends on the truck. Most people get a good one and the unlucky ones get the bad apples. If you are having issues before you decide to add a tuner, chances are you probably should refrain from adding one. Otherwise, be sensible with one and chances are you won't have issues. Personally, I'd be quite unhappy with my PSD if it weren't for my PMT.
2009 F-250 6.4L PSD CC SB Lariat Ultimate FX4, 3.73LS
Mod List:
-51 gal RDS direct fill auxillary fuel tank
-SEIC High Idle
-H&S Black Maxx Running the Hot Damn +300 Tune
-S&B Dry CAI
-Diamond Eye 5" Turbo Back Race Exhaust
-Custom 10" Sub Box Behind the Center Console
-Coastaltech SYNC-LP1 Lockpick
-Westin Bull Bar
-Westin Taillight Guards
-Recon LED Smoked Dodge Cab Marker/Clearance Lights
-Billet Fender Vent Inserts
-Zone Offroad 4" Lift
-20x10 BMF Novakane 8's
-35x12.50r20 Nitto Trail Grapplers
-'11 Super Duty Rear Seat Cargo Tray w/410W Power Inverter
tvandyck7 is offline
Old 04-03-2009, 05:17 PM   #14 (permalink)
dwc032's Avatar
Not really a speech. Im just basing it on the info the I have read and the info I have received from various diesel mechanics.
dwc032 is offline
